Hello to all,
For those who are having problem with SPLM, I found a simple solution, follow the tutorial below:
From step 4 onwards follow the guidelines in your program.
Hello to all,
Hello to all,
n step 4 only follow:
3) Open Control Panel > View by Small Icons > click Device Manager > Open Network
Adapters list.
4) Click View on the menu bar > click Show Hidden Devices.
5) Right-click on the adapters and disable ALL network adapters EXCPT the Microsoft
Loopback Adapter in the list.
6) Select Start > All Programs > Intergraph SmartPlant License Manager > Generate
Machine ID and save to a text file such as c:\MachineID.TXT.
Adapters list.
Thanks a lot.
i am repeatedly getting error: Error Code – 401 Please contact Intergraph Support.
Can anyone guide me? I am using win 8.1-64 pro
Thanks in advance
Nice work - thanks
Can anyone let me know whether we can install this SPLM based PV Elite on Windows XP service pack 3???
You can try but I don't think it will work. I got errors when i tried, mainly the key generator said it couldn't find some dll's
Sent from my ALCATEL ONE TOUCH 7041X using Tapatalk
I keep getting the Invalid Key - Not Within Installation Period. It's driving me crazy. I have followed everything as per the instructions, yet I can't get this bloody thing to work. PLEASE HEEELP...
Yes, of course I confirm follow this instruction It works
Install SPLM using 'License Machine' option.
Run 'Generate Machine ID' (GenMachineGUI.exe)
and generate ID to the text file.
Run \******\******.exe and \******\SP******.exe
Copy 'Hardware fingerprint' from SP******.exe
to the HWID field of the ******.exe and input0303
'Name' either. Serial number will be generated.
Copy 'Name' and generated 'Serial' to the
SP******.exe's fields - 'Name' and 'Key'.
Press OK.
In a few seconds you will see popup window
'Key is valid and has been stored', press OK.
Restart \******\SP******.exe
Now you will see another window. Copy
generated in the first step your 'Machine ID'
to the first field of the ******.
Press 'PVElite' button and enter number of
seats in the 3 fileds (for ex. 100) and press
'Done' button, input license expiray day
(for ex. 500).
Press 'Generate' button. Your license will be
generated in the bottom field. Copy it.
Start SPLM (license.exe), choose 'Install and
remove' option, choose 'Install License Key'
option and paste copied license in the field
'License key', press OK.
In the root menu of the SPLM choose option
'Configure and test -> Select License Machine
for Client', enter your PC Name in the field
'License machine', press OK.
In the root menu choose option 'Display ->
Show key status' and test stored keys.
Install PV Elite and run it.
PS Installer ir pre------ed with .msi, which
does not need any serial during installation.
Original .msi is in the /******/ folder.
