Page 5 of 7 FirstFirst ... 3 4 5 6 7 LastLast
Results 49 to 60 of 77
Thread: HTRI v 5 SP2 or v 6 Required
  1. Dear maeng,
    files from HTRI 5.0 cr**k are not running in HTRI 6.0 (Xist for example) even if I use layout.dll and HtriSribd.dll from Val100 ********.
    Could you explain it?
    Regsrds
    Superandy
    Quote Originally Posted by superandy View Post
    Please note this in post # 45 in this thread:
    Important things, layout.dll and HtriSrbrs.dll are very important to runing for HTRI V6.0.
    layout.dll and HtriSrbrs.dll are attached in to the Xsuit_by_VALS(only_Xace).rar.
    These files are not from HTRI 5 files.
  5. Dear Henj,
    I used HtriSrbrs.dll attached in to the Xsuit_by_VALS(only_Xace).rar but the result it's the same. If you start a new shell and tube HX (design) and run the program to find the solution of your case, the message window displays a message about incompatibility of files for ver. 5 and ver. 6 system: this causes the program to fail.
    Superandy
  6. #52
    Superandy,
    Does HTRI 6 work okay for Xace case?
    If so and it is "only" say Xist case that gives problems, then try copy the cr**** files for the version 5 to the xist folder again.
    You may use some of the example files for testing.
  7. Henj,
    I have done the test you suggest: XACE ver 6.0 with Val100 ******** is running, but XIST ver 6.0 with *.dll files (only those for XIST) from HTRI ver 5.0 cr**k gives an error message.
    Superandy
  9. #54
    the c**** from val 100 is only for the vers. 6.0. another part of the suite are not function.
    Henj please help
  10. #55
    Superandy,
    So the HTRI 6 is okay but the xist files from version 5 does not work.
    Have you copied all the files from the original dll files from say this file for XIST
    from post 10 in this thread:
    And then the Cr**** files from version 5 from the "Unrar_in_XS5.rar" files in your say C:\Program Files\HTRI\XchangerSuite6? for XIST As described in
    Use the use layout.dll and HtriSribd.dll from Val100 ******** / only xace files.
    I hope this help - else I can only say try unistall and delete HTRI 6 folder and try again ..
  11. #56
    Quote Originally Posted by dresden View Post
    Use the original_dll_files for XIST from say this file
    still use the Xsuit_by_VALS(only_Xace).rar.
    Then it should work.
  12. #57
    the cr**k for XIST ver. 5.0 isn't running on XIST ver 6.0.
    henj please help
  13. #58
    Dresden,
    Does HTRI 6 work okay for Xace case as mentioned in above posts?
    If so then you need the original_dll_files for XIST and use the cr**** files from HTRIv5 for xist from the files mentioned above.
    See post #45 by maeng in this thread too.
    I hope this helps.. I am not a IT expert, just got my own HTRI working this way :-)
  14. #59
    have u any documents , videos or cd training for HTRI ...PLZZZ share it ; thks in advance
  16. #60
    Quote Originally Posted by karimo View Post
    Yes it will be good!
    I guess you know the Design manual and XIST help file given in this thread:
    The is a few books - say Robert Serth book: Process Heat Transfer Principles and applications.
    There had been posted some training slides too - but I can't find these at the moment..
  1. Htri v7.0 sn
    By Minfo in forum Electrical & Power Engineering
    Last Post: 09-05-2018, 05:54 AM
