Still looking for these, any help?OK, I have posted a lot of new items today, here is a list of MPMS that are newer than what I have.
Please look at list and see if you have these, pay close attention to the editions and dates. We don't need the older ones.
MPMS Ch. 4.5 Master-Meter Provers 3rd 2011
MPMS Ch. 4.7 Field Standard Test Measures 3rd 2009
MPMS Ch. 4.8 Operation of Proving Systems 2nd 2013
MPMS Ch. 4.9.3 Methods of Calibration for Displacement and Volumetric Tank Provers, Part 3—Determination of the Volume of Displacement Provers by the Master Meter Method of Calibration 1st 2010
MPMS Ch. 4.9.4 Methods of Calibration for Displacement and Volumetric Tank Provers, Part 4—Determination of the Volume of Displacement and Tank Provers by the Gravimetric Method of Calibration 1st 2010
MPMS Ch. 5.8 Measurement of Liquid Hydrocarbons by Ultrasonic Flow Meters 2nd 2011
MPMS Ch. 6.4 Metering Systems for Aviation Fueling Facilities 2nd 2007
MPMS Ch. 7.3 Temperature Determination—Fixed Automatic Tank Temperature Systems 2nd 2011
MPMS Ch. 9.1 Standard Test Method for Density, Relative Density (Specific Gravity), or API Gravity of Crude Petroleum and Liquid Petroleum Products by Hydrometer Method 3rd 2012
MPMS Ch. 9.2 Standard Test Method for Density or Relative Density of Light Hydrocarbons by Pressure Hydrometer 3rd 2012
MPMS Ch. 9.3 Standard Test Method for Density, Relative Density, and API Gravity of Crude Petroleum and Liquid Petroleum Products by Thermohydrometer Method 3rd 2012
MPMS Ch. 10.1 Standard Test Method for Sediment in Crude Oils and Fuel Oils by the Extraction Method 3rd 2007
MPMS Ch. 10.2 Standard Test Method of Water in Crude Oil by Distillation 3rd 2013
MPMS Ch. 10.3 Standard Test Method for Water and Sediment in Crude Oil by the Centrifuge Method (Laboratory Procedure) 4th 2013
MPMS Ch. 10.5 Standard Test Method for Water in Petroleum Products and Bituminous Materials by Distillation 5th 2013
MPMS Ch. 10.6 Standard Test Method for Water and Sediment in Fuel Oils by the Centrifuge Method (Laboratory Procedure) 5th 2013
MPMS Ch. 10.9 Standard Test Method for Water in Crude Oils by Coulometric Karl Fischer Titration 3rd 2013
MPMS Ch. 11.2 Data File of Chapters 11.2.2 and 11.2.2M 1st 1984
MPMS Ch. 11.2.2M Compressibility Factors for Hydrocarbons: 350–637 Kilograms per Cubic Meter Density (15 °C) and –46 °C to 60 °C Metering Temperature 1st 1986
MPMS Ch. 11.3.2.1 Ethylene Density 2nd 2013
MPMS Ch. 11.3.3 Miscellaneous Hydrocarbon Product Properties—Ethanol Density and Volume Correction Factors 1st 2011
MPMS Ch. 11.3.3.2 Propylene Compressibility 1974
MPMS Ch. 12.1.1 Calculation of Static Petroleum Quantities, Part 1—Upright Cylindrical Tanks and Marine Vessels 3rd 2012
MPMS Ch. 14.3.1 Orifice Metering of Natural Gas and Other Related Hydrocarbon Fluids—Concentric Square-Edged Orifice Meters, Part 1: General Equations and Uncertainty Guidelines 4th 2012
MPMS Ch. 14.5 Calculation of Gross Heating Value, Relative Density, Compressibility and Theoretical Hydrocarbon Liquid Content for Natural Gas Mixtures for Custody Transfer 3rd 2009
MPMS Ch. 14.7 Mass Measurement of Natural Gas Liquids 4th 2012
MPMS Ch. 14.9 Measurement of Natural Gas by Coriolis Meter 2nd 2013
MPMS Ch. 17.5 Guidelines for Voyage Analysis and Reconciliation of Cargo Quantities 3rd 2012
MPMS Ch. 17.9 Vessel Experience Factor (VEF) 2nd 2012
MPMS Ch. 17.11 Measurement and Sampling of Cargoes On Board Tank Vessels Using Closed and Restricted Equipment 1st 2009
MPMS Ch. 17.12 Procedure for Bulk Liquid Chemical Cargo Inspection by Cargo Inspectors 1st 2008
MPMS Ch. 19.1 Evaporative Loss from Fixed-Roof Tanks 4th 2012
MPMS Ch. 19.2 Evaporative Loss from Floating-Roof Tanks 3rd 2012
MPMS Ch. 19.4 Evaporative Loss Reference Information and Speciation Methodology 3rd 2012
MPMS Ch. 19.5 Atmospheric Hydrocarbon Emissions from Marine Vessel Transfer Operations 1st 2009
MPMS Ch. 20.3 Measurement of Multiphase Flow 1st 2013
MPMS Ch. 21.1 Flow Measurement Using Electronic Metering Systems—Electronic Gas Measurement 2nd 2013
MPMS Ch. 22.1 Testing Protocols—General Guidelines for Developing Testing Protocols for Devices Used in the Measurement of Hydrocarbon Fluids 1st 2006
