Page 42 of 56 FirstFirst ... 32 40 41 42 43 44 52 ... LastLast
Results 493 to 504 of 667
Thread: ETAP v11.0
  1. Re: ETAP v11.0
    Thank you wardhana
  3. Re: ETAP v11.0
    Dear fr.wardan,
    I am really appreciated to you for this kind effort........working good.
    Regard's
  5. Re: ETAP v11.0
    Hi everyone!
    Fist of all, thanks a lot to Mr. Wardana for not only giving us the "solution" for ETAP 11.0.0c, but for also compile all steps in one post. It is working 100%!!! Thanks a lot.
    Now, listen. I already have a copy of ETAP 11.1.1 SP (in spanish). So what I decided to do was to test the method for ETAP 11.0.0c in ETAP 11.1.1, i did the same steps, introduced the act. code and i did not get a message of wrong code, but instead got a message of "Local language package not authorized". Any ideas about that? Thanks in advance.
    And the best for last.... last week i managed to get a copy of ETAP 12.5 (i believe ETAP 12.6 was released last week also), so if anyone is interested just tell me, i can upload it and share it here. However i don't have the "solution" for that version. I will try the 11.0.0c method in 12.5 but i don't think it will work. If anyone have any ideas about that, i'm all ears.
    Best Regards,
    Cosme.
  6. #496
    Please upload it on 4shared if possible. Thanks in advance. I think you have to install it in english language that's only my opinion.
    Sent from my GT-I9082 using Tapatalk
  7. Re: ETAP v11.0
    Is anyone having etap 12
  9. #498
    Re: ETAP v11.0
    Many thanks for fx007 and all. Fr. Wardana, manuel_CV I followed your steps by installing RunAsDate and put the name with extension bat. But I got warning " the date format is invalid". Could you please help me..thanks in advance
  10. Re: ETAP v11.0
    Ok, I will uptload ETAP 12.5 tonight on 4shared, I'll post links here when ready. But we will have to get a ----ck for it.
  11. Re: ETAP v11.0
    Hi guys,
    Same as box; I followed all step, but at the end", I got warning " the date format is invalid 1 "
    Needs some advice rectify this.
  12. #501
    Re: ETAP v11.0
    Cosme Lord, could raise the etap in Spanish version, it would be greatly appreciated.
  13. Re: ETAP v11.0
    I have successfully installed ETAP 11, following the steps for 'Runasdate' method. It works fine for about 35minutes, then there is a warning saying - ETAP failed License validation and will terminate in 15 minutes after clicking OK. Error message=The EXTEND authorization reply from the ETAP License Manager is not granted.
    What is the problem and how to solve it?
    Thanks in advance
  14. Re: ETAP v11.0
    thank you very dear cosme_fulano i'm interested in etap 12.6 could u plz upload it
  16. Re: ETAP v11.0
    [QUOTE=fr.wardana;269723]Thank you very much for all who's been contributing so great to engineering community in this forum.
    I have finally installed and run ETAP 11 in my laptop (Win 7 Home Premium 64-bit) successfully, again thank you for all the explanations and guides found all over this thread. In this post I will try to re-enact the path I took to install ETAP in my laptop, off course I just reorganized all of the infos found in all over this thread, much credits go to fx007, fperea, manuel_cv, surgeArrester, pushead, raj, and all who has been actively contributing to this thread:
    1. First things first, make sure you have installed :
    - A software to mount virtual DVD drive for .iso files such as Daemon, Alcohol120%, ultraiso, etc
    - WinRar to extract the ETAP Installation iso file from the archive
    2. Download links for ETAP .iso installation files:
    For part 1-16, each file is 97.657 KB in size, whereas part 17 size is 89.397 KB --> after download each .rar file, make sure to open it with WinRar to check if your downloaded file is not corrupted (WinRar opens without any warning/alert message)
    3. Extract the archive using the password:
    ¦¦¦¦¦¦¦¦, Sorry!
    4. All those files will merge into single .iso file. Before proceeding to install, you must first create a virtual ECP Port:
    Right Click My Computer --> Properties --> Device Manager --> Ports (COM & LPT) --> in the Action Tab, click “Add legacy hardware” --> click Next --> choose "Install hardware manually (Advanced)” --> Choose Ports (COM & LPT) --> Click Next --> Choose Manufacturer : (Standard), Model : ECP Printer Port --> click Next --> Finish --> Right click on new ECP Port --> on the "Port Setting" tab, Change setting to Never use an interrupt, check Enable legacy Plug and Play, and select LPT1 --> on the "Resources" tab, uncheck Use automatic setting --> click Change Setting --> input 03BC - 03BE for I/O Range
    This I/O range will initially conflict with existing PCI Bus on some hardware, if yes just ignore it and proceed to restart your computer, the BIOS will take care of it
    I can not see the manufacture and model list
    kindly help
  1. ETAP v12
    By smzakaullah in forum Electrical & Power Engineering
    Last Post: 02-20-2015, 04:19 PM
  2. Etap 7
    By Sarmad Imtiaz Awan in forum Electrical & Power Engineering
    Last Post: 09-07-2014, 01:35 PM
  3. Need etap --------
  4. Etap 7.1
    By Rudi Tua in forum Electrical & Power Engineering
    Last Post: 07-06-2011, 12:02 PM
  5. Etap 7.0
    By pdms.ir in forum Electrical & Power Engineering
    Last Post: 08-19-2010, 10:44 PM
