Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 37 to 48 of 60
Thread: Bs iso 10816 required
  1. please can u upload any material related to Diagnostics of Rotating Equipement and ADRE and System 1 training material.........
  3. Re: Bs iso 10816 required
    Mr. Luqman,
    Links are not active anymore. I'm very interested with ISO 10816-6 could you please upload it again ?
  5. Re: Bs iso 10816 required
    Achmad Nur Eddin
    can u please upload the pdf in
  6. Re: Bs iso 10816 required
    Quote Originally Posted by luqman View Post
    ur welcome. its not a big deal frens. i am just sharing the docs that i have here. maybe some day i will need your helps too.
    dear marx,
    i have only these following standards. i dont have ISO 18436 Sub Parts under development for oil analysis and thermal imaging. Please find the links as below:
    iso 13379
    iso 13381
    iso 17359
    iso 18436-2
    ISO 1925-2001 Mechanical vibration — Balancing —Vocabulary.pdf
    ISO 2954-1975 Mechnical Vibrations for Rotating & Reciprocating Machinery.pdf
    Please upload these standards, because links are dead. THanks in advance.
  7. Re: Bs iso 10816 required
    Dear Mr. Achmad, no links are working. Can you please uploa the same again. Thanks a lot.
    Kavita.
    Achmad Nur Eddin Very Active Member
    Mar 2009
    2
    ISO VIBRATION
    1. ISO 10816 - Evaluation of Mechanical Vibration.rar 2.864 MB
    consist of :
    ISO10816-1 General Guideline 1995.pdf
    ISO10816-1AMD1 2009.pdf
    ISO10816-2 Steam turbine & Generator more 50 MW 2009.pdf
    ISO10816-3 Industrial Machine more than 15 KW 2009.pdf
    ISO10816-4 Gas Turbine 2009.pdf
    ISO10816-5 Hydraulic power generating & pumps 2000.pdf
    ISO10816-6 Reciprocating machine above 100 KW 1995.pdf
    ISO10816-7 Rotodynamic pump and measurement on shaft 2009.pdf
    2. ISO 7919 - Evaluation of Shaft Vibration.rar 2.514 MB
    consist of :
    BS ISO 7919-1 1996 General Guideline.pdf
    BS ISO 7919-2 2001 Steam turbine & Generator more 50 MW.pdf
    BS ISO 7919-3 1996 Coupled Industrial Machine.pdf
    BS ISO 7919-4 1996 Gas Turbine Set.pdf
    BS ISO 7919-5 2005 Hydraulic power generating & pumps.pd
    3. ISO 13373 Vibration condition Monitoring.rar 1.288 MB
    consist of :
    ISO13373-2 Data processing, analysis, diagnostics, display and general vibration 2005.pdf
    ISO13373-1 General Procdure 2002.pdf
    4. ISO 1925-2001 Mechanical vibration — Balancing —Vocabulary.pdf 0.348 MB
    5. ISO 2954-1975 Mechnical Vibrations for Rotating & Reciprocating Machinery.pdf 0.322 MB
    6. ISO 15242-Rolling bearings — Measuring methods for vibration.rar 0.984 MB
    consist of :
    ISO 15242-1-2004 Fundamentals
    ISO 15242-2-2004 Radial ball bearings with cylindrical bore and outside surface
    ISO 15242-3-2006;Radial spherical and tapered roller bearings with cylindrical bore and outside surface
    7. ISO 1940 Mechanical vibration — Balance quality requirements for rotors.rar 1.410 MB
    Consist of :
    ISO 1940-1 - 2005-01 Specification and verification of balance tolerances
    ISO 1940-2 - 1997-06 Balance error
    Read more:
  9. Re: Bs iso 10816 required
    Looks like links are not working .. pl check
  10. #43
    Dear all,
    Please share the ISO10816-3 Industrial Machine more than 15 KW 2009.pdf.
    Thanks in Advance
  11. #44
    Dear all,
    Thanks in Advance
  12. #45
    Mar 2011
    Bontang, Kalimantan Timur, Indonesia, Indonesia
    Dear Sir,
    Links are not working..can you please reupload.
    Quote Originally Posted by Achmad Nur Eddin View Post
    ISO VIBRATION
    consist of :
    consist of :
    consist of :
    consist of :
    Consist of :
  13. Re: Bs iso 10816 required
    please reupload
  14. Re: Bs iso 10816 required
    Quote Originally Posted by Nabilia View Post
    Heres another link
    Hi Nabilia,
    Can you upload this standard again? Thanks
  16. Re: Bs iso 10816 required
    for 7919 & 10816 goto following link:
  1. VDI 3832 and ISO 10816
    By YSH in forum Mechanical Engineering
    Last Post: 05-29-2013, 07:24 AM
  2. Need ISO 10816 and API 684
    By apri_dianto@yahoo.com in forum Mechanical Engineering
    Last Post: 12-10-2010, 09:52 AM
