i need Api Spec 7K Please help me
I am working on a few data points where I need to calculate the corrected API (@ 60F) from an observed API which was taken at a different temperature for crude oil. I also need to calcualte corrected volume as well for which I believe I understand I need the VCF (Volume Correction Factors).
I understand that "Adjunct to D1250 Petroleum Measurement Tables – Volume I" contains Table 5A: Generalized Crude Oils, Correction of Observed API Gravity to API Gravity at 60°F and Table 6A: Generalized Crude Oils, Correction of Volume to 60°F Against API Gravity.
I also understand that "Adjunct to D1250 Petroleum Measurement Tables – Volume X" contains Background, Development, and Computer Documentation and that Volume X actually has the algorithms and equations published for calculating and approximating all of the tables published in the 12 volume Adjunct set.
I don't know how many pages there are to Tables 5A and 6A in Volume 1 but that is what I believe I need. Even better would be the algorithms/equations that generate these particular tables for which I understand is published in Volume 10.
Can someone help me with this??
I only need this data for a one time set of calculations..
Thanks to whoever can help me with this!!
Greg
thank you very much
Specification for Drilling Equipment equal to ISO 14693
API SPEC 7K 3rd Ed 2001.pdf 0.645 MB
The new version is API SPEC 7K 4th Ed 2006. Could somebody upload it ?
API SPEC 7K Addendum 1 2006.pdf 0.307 MB
API SPEC 7K Addendum 2 2006.pdf 0.508 MB
Dear @all, please, share:
API RP 581 (2008) - "Risk-Based Inspection Technology"
thanks very much
Can any one pls upload API12J standard.
Thanks in advance
API SPEC 12J 7th Ed 1989.pdf 1.24 MB
Thank
ASTM D-1250 08 please
Does someone know any spec about Gas Odorants and odorizaation?
Thanks…
