Thank you
reupload pls.
Dear Qalander,
Could you provide the rar pass please.
Thanks...
Emin Tugluoglu
emintugluoglu@gmail.com
reupload please
Page 155
Overturning loads and uplift loads.
Overturning loads can be induced by either of two possibilities:
Wind loads. Overturning moments induced by wind on empty
tanks with a large height-to-diameter ratio can be significant.
Although often specified by the purchaser of a tank, wind loads can be
assumed to exert pressures of 18 psf on the projected area of a tank
shell and 15 psf on the projected area of tank roofs. This is based on a
100 mi/h wind speed. For different wind speeds, these pressures can
be factored by (V/100)2, where V is the wind speed in miles per hour.
To maintain a factor of safety of 1.5, for unanchored tanks, the
overturning moment should not exceed two-thirds of the dead load
resisting moment according to this equation:
Mw=2/3 (WD/2)
where Mw = wind load overturning moment, ft.lb
W = weight of tank shell and portion of roof supported by it,
lb
D = diameter of tank, ft
The other possibility is seismic, if I have time later I will try to present that. It is complicated.
Handbook_Of_Storage_Tank_Systems_-_Codes_Regulations_And_Designs.rar
icin rar sifresi...
Dear
D = Nominal tank dia., ft
H2 = Height of tank shell, ft
V = Wind velocity, miles/hr.
but we slove the equation : Z = 0.0001 D2 H2 (V / 100)2
Z = f3
f2 x f x (miles/hr)/(miles/hr) = f3
How to arrive in.3
Dear Sir
Please share the password of Handbook_Of_Storage_Tank_Systems_-_Codes_Regulations_And_Designs.rar
Thank you
Handbook Of Storage Tank Systems - Codes Regulations And Designs - Geyer
