thanks dduck.. I will check it... any idea or links for PVTsim ?
Sorry guys, I stand corrected.
You DO need a ***** to run simulations (thanks to wmpstl). In my case the GUI wouldn't start at all before I pointed to the license from my previous post.
This software is really wierd, like it has a mind of its own. On one machine behaves in one way on the other differently.
Again, I appologize for my mistake from the previous post.
Dear All, I have tested my -----. There is no problem about it. The problem may comes from Your Windows setting. Some problem may be caused by windows Vista (if You use it).
Some Problem my come from other OLGA (old) version that You might have installed stand by OLGA 6.0.
wmpstl+dduck,
Appreciate your efforts.
I have Windows XP SP2 and I have tried both license and ***** file. The GUI works; as I can see the OLGA6 windows with the list of tab files but the components are not visible meaning the OLGA case does not load.
I have tested all permutations and it does not seem to work. Could you advise how have you installed and run a case.
wmpstl,
are you the same guy in lavteam forum using nickname as "black sea"?
To get it work nicely download this file:
it fits to the published license and put into C:\WINDOWS\system32-folder. Thank to Lz0.
Regi![]()
Regi Max,
Is this the only file required for the OLGA 6 ********.
If possible, it would be great if someone can list down the whole instruction in one post.
polaris44,
Olga 6.0 needs the license from imeagor (post #52) and the file ibfs...
HAPPY NEW YEAR !.!.!
Regi
thank you so much regi max
The links to download full package are there:
Happy new year !!!
Regi![]()
good man, Happy new year !!!
