Page 33 of 36 FirstFirst ... 23 31 32 33 34 35 ... LastLast
Results 385 to 396 of 423
  1. #385
    Re: Excel library for process calc's including distillation
    Hi friends
    Hope everything goes well with you
    I have provided a huge collection of newest petroleum software like: Petrel 2013.3, Eclipse 2013.1, Geoframe 2012, Paradigm 2011.3, Olga 7.2, OSP4.0.3, Mepo 4.2, Techlog 2013.2, RoXar RMS 2013.1, Ecrin 4.2.07, CMG 2013.1, S/M/T K/ingdom 8.8, Rokdoc 6.0.0.107, Desicion Space Desktop r5000.8.1.1, Drillworks 5000.8.1.1, Openworks r5000.8.1, VIP-Nexus 5000.4.4.0, Skua Gocad 2011.3, IPM 8.0, PetroMod 2013.1, Interactive Petrophysics 4.1, Openflow 2012.2, Pipesim 2013.1, Que$tor 3013Q1, FractPro 2013, Vista 13, Jason 8.4, GeoGraphix Discovery 2013, and so many other things ...
    if anybody need Please contact me I will share with you. Also I need some applications hope you can kindly help me.
    My E-mail is: slbsoft33@gmail.com
    Cheers.
    matrenel wrote
    "I was in contact with PRODE, a commercial licence is required for the vapor-liquid-liquid column,
    actually the free version 1.2b does include only the vapor-liquid column,
    I decided to upgrade and I have tested the VLL column, no problems to solve my specific application."
    thank you for your contribute,
    Carlo
  5. Re: Excel library for process calc's including distillation
    Carlo,
    have you utilized the depressuring module for a fire case ?
    Actually my licence doesn't activate the module,
    I would be interested to include it providing it calculates the fire case with vaporizing liquid in the vessel
  6. #388
    yes, it does both fire case and the so called cold depressuring,
    what do you wish to know ?,
  7. Re: Excel library for process calc's including distillation
    I have to evaluate a fire case for a three phase separator (gas+liquid)
    do you think I can go with depressuring module in PRODE ?
  9. #390
    yes,
    I select API formulation to estimate heat exchanged (fire case, wetted surface area).
    and BDV + RO to control fluid flow,
    do you have some specific request or codes to apply ?
  10. #391
    tinom,
    as said by Carlo for fire case you can estimate the heat absorbed with different methods including API (you need to define vessel's geometry)
  11. #392
    by the way to activate the module you need to contact Prode and obtain a new lic file which includes the activation key,
    as far as I know the last release of depressuring utility is may 2013
  12. #393
    I have several control valves in two-phase service (flashing liquid)
    can I use HEM model available in PRODE PROPERTIES to verify sizing ?
  13. #394
    with PRODE PROPERTIES you have different options,
    you can model a valve with a flash operation or a predefined model as HEM or HNE,
    the selection depending from the specific application,
    Carlo
  14. Re: Excel library for process calc's including distillation
    very helpful, thanks
  16. #396
    for those interested to Mathcad Thermodynamic applications
    including distillation this blog may be interesting,
    'http://www.harveyhensley.com/blog-che-old-school-and-new-school'
    Pat
  1. Replies: 29
  2. Replies: 2
  3. Replies: 7
  4. Replies: 18
