Page 32 of 36 FirstFirst ... 22 30 31 32 33 34 ... LastLast
Results 373 to 384 of 423
  1. #373
    Re: Excel library for process calc's including distillation
    in my experience Lee Kesler gives indeed accurate results for HC mixtures,
    not to use for other chemicals, though.
    in some cases you can select the Lee Kesler Plocker model
    which has been designed to handle very asymmetric mixtures
  5. Re: Excel library for process calc's including distillation
    does someone know where to find good VLE data sets for C2-H2O, C3-H2O, H2S-H2O etc.
    I wish to use PRODE PROPERTIES to regress temeperature dependent BIPs for these pairs...
  6. Re: Excel library for process calc's including distillation
    thanks a lot
  7. Re: Excel library for process calc's including distillation
    where is the link??
  9. #378
    mohammed,
    look for PRODE PROPERTIES with Google
    or go directly to
    'http://www.prode.com/en/properties.htm'
  10. #379
    mohammed,
    or go directly to
  11. Re: Excel library for process calc's including distillation
    thank you Carlo, got it.
  12. Re: Excel library for process calc's including distillation
    Does the distillation column in PRODE PROPERTIES allow to solve VLL (vapor-liquid-liquid) ?
    I have a three phase distillation to simulate.
  13. #382
    matrenel,
    yes, the column model in PRODE PROPERTIES can solve
    vapor-liquid
    vapor-liquid-liquid
    liquid-liquid
    separations, you can specify reflux,
    heat, purity, recovery etc.
  14. #383
    Matrenel,
    yes, I have solved both VL and VLL columns with PRODE PROPERTIES,
    (no direct experience with LL but that depends from my field of application)
  16. Re: Excel library for process calc's including distillation
    thanks Carlo and cbadia,
    I was in contact with PRODE, a commercial licence is required for the vapor-liquid-liquid column,
    actually the free version 1.2b does include only the vapor-liquid column,
    I decided to upgrade and I have tested the VLL column,
    no problems to solve my specific application.
  1. Replies: 29
  2. Replies: 2
  3. Replies: 7
  4. Replies: 18
