Page 31 of 36 FirstFirst ... 21 29 30 31 32 33 ... LastLast
Results 361 to 372 of 423
  1. #361
    Re: Excel library for process calc's including distillation
    yes,
    you have to change only the constant of conversion.
    I wish to calculate the speed of sound for a vapor + liquid mixture,
    the application would be the Mach number in a flare network,
    I know that Prode Properties has a specific method for calculating the speed of sound in mixed phases,
    which are the basis of that method ?
    PRODE PROPERTIES calculates the speed of sound in mixed (vapor + liquid) phase
    with HEM (Homogeneous Equilibrium Model)
    HEM method is reliable for a large range of applications including flare networks,
    note that PRODE PROPERTIES has methods to design/rate pipes / pipelines which can be utilized to simulate a flare network.
  6. #364
    thanks Carlo,
    does HEM method (as coded in PRODE PROPERTIES) assume the same or different velocities for vapor and liquid phases ?
  7. #365
    yes,
    in HEM (Homogeneous Equilibrium Model) vapor and liquid phases form a homogeneous mixture traveling at same speed,
    if you wish to model a fluid forming a non-homogeneous mixture use HNE (Homogeneous Non-equilibrium Model) instead,
    Carlo
  9. #366
    Carlo,
    I have to calculate the speed of sound for a vapor + liquid mixture and I think to use Extended Peng Robinson Model available in PRODE PROPERTIES,
    does that model give consistent results for a natural gas mixture (C1-C9 + CO2..) ?
  10. #367
    yes,
    for natural gas mixtures I would select the Extended Peng Robinson or the Extended Soave Redlich Kwong versions available in PRODE PROPERTIES,
    you may also consider BWR or (when water-alcohools as methanol etc.) present the different variants of CPA.
    For calculating the speed of sound the procedure needs to evaluate density, enthalpy and entropy
    so when selecting the model you should consider the accuracy
    given by the different models for these properties.
  11. #368
    Carlo,
    I see that predicted speed of sound is (very) sensible to selected models for enthalpy and entropy,
    what happens if I mix different models as, say,
    Peng Robinson for fugacity and Lee Kesler for enthalpy ?
  12. #369
    Carlo,
  13. #370
    you can mix models if you think that a model gives better accuracy on some property,
    in PRODE PROPERTIES you can define packages to include
    different models for Fg,H,S,V,Visc, etc.this allows a great flexibility
    to manage mixtures with non-standard behaviour,
    for hydrocarbons I usually select the extended versions (5 parameters) of
    Peng Robinson and Soave Redlich Kwong but other EOS
    can be defined as well.
  14. #371
  16. #372
    thanks Carlo,
    some papers suggest Lee Kesler for enthalpies of natural gas mixtures,
    so I wish to compare and see the results
  1. Replies: 29
  2. Replies: 2
  3. Replies: 7
  4. Replies: 18
