Page 30 of 56 FirstFirst ... 20 28 29 30 31 32 40 ... LastLast
Results 349 to 360 of 667
Thread: ETAP v11.0
  1. Re: ETAP v11.0
    Quote Originally Posted by manuel_cv View Post
    Check older pages my friend.
    For Windows XP:
    You add the ECP printer port from Control Panel, Add Hardware. In XP you click on Yes, i connect the hardware. Then select Add a new hardware disp, at the bottom of the list. Click on Install the hardware in manual... Then select Ports (COM & LPT), and there is the infamous ECP printer port. Finally just follow fx007 intrucctions. Hope it help.
    mohad explained the process for Win 7:
    The procedure to add printer port for win7 (even laptop) is easy:
    control panel --> device manager --> select ports (com & lpt) --> in menu bar press Action --> Add legacy hardware
    --> follow instructions
    My problem is I don't have LPT on my PC.
    So answer is to install LPT Emulator for Windows 7.
    Thank you all!
  3. Re: ETAP v11.0
    Thanks a lot guys
  5. Re: ETAP v11.0
    Please Share ISO File Or Link Etap 11
    Thanks ...
  6. Re: ETAP v11.0
    thank you very much . it is working for windows 7 64 bit home basic edtion
  7. #353
    Re: ETAP v.11.0 and SKM 7.024
    Hi,
    can someone send me the procedure and the key to run etap and skm please? the email is anmassi77@tin.it
  9. Re: ETAP v11.0
    Folks,
    It is bit confusing, the key provider tells it works with window7 64 bit, some people say it is not possible but it is work with window7 32bit.
    windows 8 64bit user also tells it is not possible.
    I have window7 32bit laptop only. let me try it out first. but guys , have you installed in windows8 64 bit so far ? I am ready to buy a new laptop just to install this etap11.
    Many thanks
  10. Re: ETAP v11.0
    Folks,
    Many thanks
  11. #356
    Re: ETAP v11.0
    All ETAPs version higher than 5.5.6 (i.e. 5.5.6 - 6.0 - 7.0 - 7.1 - 7.5 - 11.0 - 12.0 ) are working on win7 32bit & 64bit. (at least for me) if it does not work for you - it is you -ra-k problem
  12. Re: ETAP v11.0
    Success
    It is compatible with 32 as well as 64.
    Thank you fx007 for your great work and shared your effort it here.
  13. Re: ETAP v11.0
    Success
  14. #359
    Yes it is working most reasons why it does not work is due to the printer port
    Sent from my iPhone using Tapatalk
  16. #360
    Re: ETAP v11.0
    Can someone publish here or share anywhere the activation codes for version 11 and 12 (maybe even 12.5 if there is one)...
    Yet, unfortunately personally I have lot of troubles with missing LPT
  1. ETAP v12
    By smzakaullah in forum Electrical & Power Engineering
    Last Post: 02-20-2015, 04:19 PM
  2. Etap 7
    By Sarmad Imtiaz Awan in forum Electrical & Power Engineering
    Last Post: 09-07-2014, 01:35 PM
  3. Need etap --------
  4. Etap 7.1
    By Rudi Tua in forum Electrical & Power Engineering
    Last Post: 07-06-2011, 12:02 PM
  5. Etap 7.0
    By pdms.ir in forum Electrical & Power Engineering
    Last Post: 08-19-2010, 10:44 PM
