Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 25 to 36 of 54
Thread: EPRI books
  1. #25
    Re: EPRI books
    Evaluation of Filler Materials for Transition Weld Joints Between Grade 91 to Grade 22 Components
    Re: EPRI books
    Effect of Normalization and Temper Heat Treatment on P91 Weldment Properties
    or
    Re: EPRI books
    Weld Metals for P91 – Tough Enough?
  6. #28
    Re: EPRI books
    FLUX CORED ARC WELDING:
    THE HIGH PRODUCTIVITY WELDING PROCESS FOR P91 STEELS
  7. #29
    Re: EPRI books
    Welding consumables for P92 and T23 Creep Resisting Steels
    or
  9. #30
    Re: EPRI books
    Engineering training modules
    or
  10. #31
    Re: EPRI books
    Development of a New Nickel Filler for Dissimilar Metal Welds and Repair
  11. #32
    Re: EPRI books
    Repair Methods for Dissimilar Metal Welds— Development, Weldability, and Properties of EPRI P87 Solid Wire Filler Metal
    or
  12. #33
    Re: EPRI books
    all in one file:
    Weld Overlay Of Waterwall Tubing, ALternative Filler
    The Use of Weld Overlays to Extend the Useful Life of Seam Welded High Energy Piping in Fossil Power Plants
    P-No. 4 and P-No. 5A Temperbead Repair Using the Flux-Cored Arc Welding (FCAW) Process
    Evaluation Of Solid Wire Advanced GMAW For Heavy Sections And Piping Replacement
    Guide For Repair Of Thinned Piping
    Advanced GMAW Process For Pipe Welding Applications
    Repair of Metal Bellows - Fatigue Testing
    Tack Welding Guidelines
    Flue Gas Desulfurization Materials Guidelines Update - Coatings and High Alloys
    Inherently Reliable Boiler Component Design
    Development of Advanced Methods for Joining Low-Alloy Steels
    The Use of Weld Overlays to Extend the Life of Seam Welded High Energy Piping in Fossil Power Plants
    Optimal Hardness of P91 Weldments
    Effects of Cold Work and Heat Treatment on the Elevated Temperature Rupture Properties of Grade 91 Material
    Proceedings: 11th Annual NDE Issues Meeting
    New Steels for Advanced Power Plants II Phase 2: Development of Advanced 9-12 Cr Steels for Thick Section Boiler Applications
    EPRI Conference on 9Cr Materials Fabrication and Joining Technologies
    Productivity Improvement Handbook for Fossil Steam Power Plants: Third Edition
    GENERATORS
    Development of an On-Line Corrosion Advisor (OLCA)
    Conference Proceedings: EPRI-RRAC Fifth International Conference on Welding and Repair Technology for Power Plants
    Fan Repair Guideline
    Welding Best Practices Manual for High-Risk/High-Value Repairs
    PWHT Exemptions for Low Hardenability Materials
    Ultrasonic Testing (UT) of Dissimilar Metal Welds (DSM) Training
    GTAW Flux-Cored Wires for Open Root SS Welding
    Reinstatement of Post-Weld Heat Treatment (PWHT) Exemptions for P Nos. 4 and 5A Socket Welds
    Temperbead Repair Welding of Grade 91 Material
    Heat Exchanger Single Tube Test Device
    Effect of Cold Work and Heat Treatment on the Elevated-Temperature Rupture Properties of Grade 91 Material
    Investigation of Thickness Limits for Post Weld Heat Treatment (PWHT) Exemption
    NDE Training Activities
    Materials Handbook for Nuclear Repair Applications
    Status Review of Initiation of Environmentally Assisted *****ing and Short ***** Growth
    Materials Reliability Program: Selection of Materials and Fabrication of Weldments for Investigation of PWSCC Susceptibility in the Alloy 600 and 690 Weld Heat Affected Zones (MRP-161)
    Flue Gas Desulfurization Systems Component Material Performance and Welding
    Dissimilar Metal Weld Configuration Management Database
    CoalFleet Guideline for Advanced Pulverized Coal Power Plants
    The Grade 22 Low Alloy Steel Handbook
    Materials Reliability Program: Technical Basis for Preemptive Weld Overlays for Alloy 82/182 Butt Welds in PWRs (MRP-169)
    Topical Report Supporting an Expedited NRC Review of the Content of the Code Case needed for Dissimilar Metal Weld Overlay Repairs
    The Grades 11 and 12 Low Alloy Steel Handbook
    Stress Corrosion *****ing of Grade 91 Materials
    Repair and Replacement Applications Center: Investigation of Thickness Limits for Post Weld Heat Treatment (PWHT) Exemption
    Repair and Replacement Applications Center: Stress Corrosion *****ing in Closed Cooling Water Systems
    Industrial Energy Efficient Technology Guide 2007
    Repair and Replacement Applications Center: Topical Report Supporting Expedited NRC Review of Code Cases for Dissimilar Metal Weld Overlay Repairs
    Nondestructive Evaluation: Dissimilar Metal Weld (DMW) Configuration Database
    Carbon Steel Handbook
    Materials Reliability Program: Advanced FEA Evaluation of Growth of Postulated Circumferential PWSCC Flaws in Pressurizer Nozzle Dissimilar Metal Welds (MRP-216)
    Materials Reliability Program: Advanced FEA Evaluation of Growth of Postulated Circumferential PWSCC Flaws in Pressurizer Nozzle Dissimilar Metal Welds (MRP-216, Rev. 1)
    Plant Support Engineering: Information for Use in Conducting Audits of Supplier Commercial Grade Item Dedication Programs
    Materials Reliability Program: Inspection and Evaluation Guidelines for Reactor Vessel Bottom-Mounted Nozzles in U.S. PWR Plants (MRP-206)
    Hexavalent Chromium Air Sampling Data from Welding and Steel Cutting
    Nondestructive Evaluation: Guideline for Conducting Ultrasonic Examinations of Dissimilar Metal Welds
    Handbook of Neutron Absorber Materials for Spent Nuclear Fuel Transportation and Storage Applications
    Welding and Repair Technology Center: Evaluation of Post Weld Heat Treatment (PWHT) Exemption Thickness Limitations
    Materials Reliability Program: Technical Basis for Preemptive Weld Overlay for Alloy 82/182 Butt Welds in Pressurized Water Reactors (PWRs) (MRP-169) Revision 1-A
    Materials Reliability Program: Welding Residual Stress Dissimilar Metal Butt-Weld
    Guidelines and Specifications for High-Reliability Fossil Power Plants Best Practice Guideline for Manufacturing and Construction of Grade 91 Steel ComponentsFinite Element Modeling Handbook (MRP-317)
    Program on Technology Innovation: Environmental and Health Issues Related to Radiofrequency Emissions Relationship Between Alloy Chemistry, Hardenability, and Creep Behavior of Code Case 2199 (T23)from Smart Grid Technologies
    Plant Engineering: Guideline for the Acceptance of Commercial-Grade Design and Analysis Computer Programs Used in Nuclear Safety-Related Applications
    Program on Technology Innovation: Manufacture of Large Nuclear and Fossil Components Using Powder Metallurgy and Hot Isostatic Processing Technologies
    Materials Reliability Program: PWR Reactor Coolant System Cold-Loop Dissimilar Metal Butt Weld Reexamination Interval Extension (MRP-349)
    Critical Issues Report and Roadmap for the Advanced Radiation-Resistant Materials Program
  13. #34
    Jun 2008
    Karachi, Pakistan
    Re: EPRI books
    Dear BTS,
    Thanks for a valuable Collection of EPRI Books, Reports and Papers.
    The pdf files are numbered while the list you have provided is textual titles. Appreciate if the list has titles too.
  14. #35
    Re: EPRI books
    yeah, I know....but I didn't have time to rename all the files from numbers to actually what file is ....
  16. #36
    Re: EPRI books
    more:
    Dissimiliar-Weld Failure Analysis and development program # 8: Design and procedure guide for improved welds
    Materials Gudieline Update: Preliminary Survey Results
    Ambient Temperature Preheat For Machine GTAW temperbead application
    Proceedings: 1983 Workshop On Secondary-Side Stress Corrosion *****ing And Intergranular Corrosion Of PWR Steam Generator Tubing
    Proceedings: 1986 Workshop On Advanced High-Strenght Materials
    NOREM Wear-Resistant, Iron Based Hard-Facing Alloys
    Cobalt Reduction Guidelines
    Inconel Weld-Overlay-Repair for Low-Alloy Steel Nozzle to Safe-End Joint
    Underwater Maintenance Guide: Revision 2
    Welding Best Practices Survey
    SMAW Temperbead Weld Repair Without Grinding
    New Materials For Advances Steam Turbines # 5: Survey Of Superalloy Bolt Failures In High Temperature Service
    Supplemental Guidance for the Application of EPRI Report NP-5652 on the Utilization of Commercial Grade Items
    Magnetic Replicas And The Very Incomplete Meissner Effect
    Temperbead Welding Repair Of Low Alloy Pressure Vessel Steels: Guidelines
    Review Of Steam Generation Girth Weld *****ing
    State-Of-The-Art Weld Repair Technology For High Temperature And Pressure Parts # 2: Repair Guideline
    State-Of-The-Art Weld Repair Technology For High Temperature And Pressure Parts # 5: Weld Repair Of 1-1/4-Cr-1/2 Mo Piping Girth Welds
    State-Of-The-Art Weld Repair Technology For High Temperature And Pressure Parts # 7: Weld Repair Of Aged Piping - A Literature Review
    or
  1. EPRI Publications request
    By abes in forum Electrical & Power Engineering
    Last Post: 04-05-2018, 06:51 PM
  2. Request of EPRI Standard
    By raz in forum Electrical & Power Engineering
    Last Post: 08-11-2015, 07:58 PM
  3. EPRI Ergonomics
    By selmagis in forum Electrical & Power Engineering
    Last Post: 01-05-2015, 02:01 AM
  4. Need of EPRI TR-107397 & EPRI NP-7552
    By mr.allanbrooke in forum Oil And Gas Process
    Last Post: 10-29-2010, 09:42 PM
