Hi people i've received a lot of requestes and what is more currently i do'nt have enough time, i'm really sorry if you don't receive a quick reply. Please request for a specific standard, in this way we'll get more efficiently process.
regards
I've got all of this standars and i would like share with only you. Only you have to send me a email to
waltherc82@hotmail.com
Thank for yours shared files
ASME
ASME STANDARDS STATUS
ASME B1.1: Unified Inch Screw Threads (Un And Unr Form) – 1990.
ASME B1.5: Acme Screw Threads – 1997.
ASME B1.8: Stub Acme Screw Threads – 1988.
ASME B1.13M: Metric Screw Threads: M Profile – 2001.
ASME B1.20.1: Pipe Threads, General Purpose (Inch) – 1983.
ASME B1.20.3: Dryseal Pipe Threads – 1976.
ASME B1.20.7: House Coupling Screw Threads.
ASME CODES FOR STANDARDS OF PIPES AND FITTINGS
ASME B16.1: Cast Iron Pipe Flanges And Flanged Fittings – Classes 25, 125 And 250 – 1998.
ASME B16.3: Malleable Iron Threaded Fittings Classes 150 And 300 – 1998.
ASME B16.4: Gray Iron Threaded Fittings – Classes 125 And 250 – 1998.
ASME B16.5: Pipe Flanges And Flanged Fittings Nps ½ - 24 – 1996.
ASME B16.5-2&3: Interpretation To Asme B16.5. 1987 - 1997.
ASME B16.10: Face To Face And End To End Dimensions Of Valves - 1992.
ASME B16.21: Nonmetallic Flat Gaskets For Pipe Flanges – 1992.
ASME B16.34: Valves – Flanged, Threaded, And Welding End – 1996.
ASME B16.34-2: Interpretation To Asme B16.34. 1990-1995.
ASME B16.47 Ser. A, Ser. B: Industry Standard And Awwa Flanges - .
ASME 16.48: Steel Line Blanks – 1997.
ASME B16.50: Wrought Copper And Copper Alloy Braze-Joint. Pressure Fittings – 2001.
ASME CODES FOR FIELD FASTENER
ASME B18.2.1: Square And Hex Bolts And Screws (Inch Series) – 1996.
ASME B18.2.1a:Adenda – 1999.
ASME B18.12: Glossary Of Term For Mechanical Fasteners – 1962.
ASME B18.21.1: Lock Washers (Inch Series) – 1999.
ASME FOR SAFETY STANDARD FOR CABLEWAYS, CRANES, DERRICKS, HOISTS, HOOKS, JACKS, AND SLINGS
ASME B30.2: Overhead And Gantry Cranes (Top Running Bridge, Single Or Multiple Girder, Top Running Trolley Hoist) – 2001.
ASME B30.3: Construction Towers Cranes – 1996.
ASME B30.4: Portal, Tower, And Pedestal Cranes – 2003.
ASME B30.5: Mobile And Locomotive Cranes – 2000.
ASME B30.9: Sling – 1996.
ASME B30.10: Hooks – 1999.
ASME B30.16: Overhead Hoists (Underhung) – 2003.
ASME B30.17: Overhead And Gantry Cranes (Top Running Bridge, Single Girder, Underhung Hoist) – 2003.
ASME B30.20: Below The Hook – Lifting Devices – 1999.
ASME B30.22: Articulating Boom Cranes – 2000.
ASME CODES FOR PRESSURE PIPING
ASME B31.1: Power Piping – 2001.
ASME B31.2: Fuel Gas Piping – 1968.
ASME B31.3: Process Piping – 2004
ASME B31.3b: Addenda – 2001 To B31.3 1999.
ASME B31.3-17: Interpretations No. 17 – 1998-1999.
ASME B31.3-18: Interpretations No. 17 – 1999-2001.
ASME B31.4: Pipeline Transportation System For Liquid Hydrocarbons And Other Liquids – 2002.
ASME B31.4a: Addenda – 2001.
ASME B31.4-4: Cases Nº 4 – 1997.
ASME B31.4-5: Interpretation Nº 5 1994-1997.
ASME B31.5: Refrigeration Piping And Heat Transfer Components- 2001.
ASME B31.5-5: Interpretation Nº 5 – 1991-1994.
ASME B31.8: Gas Transmission And Distribution Piping Systems – 2000.
ASME B31.8: Interpretations No. 11 – 1993-1999.
ASME B31.8S: Managing System Integrity Of Gas Pipelines – 2004.
ASME B31.9: Building Services Piping – 1996.
ASME B31G: Manual For Determining The Remaining Strength Of Corroded Pipelines – 1991.
ASME B36.10: Welded And Seamless Wrought Steel Pipe – 2000.
ASME B36.19: Stainless STEEL PIPE – 1994.
ASME B46.1: Surface Texture (Surface Roughness, Waviness, And Lay) – 1995.
ASME BOILER AND PRESSURE VESSEL CODE
ASME I: RULES FOR CONSTRUCTION OF POWER BOILERS – 2003.
ASME II: MATERIALS - 2003
Part A – Ferrous Material Specifications
Part B – Nonferrous Material Specifications
Part C – Specifications for Welding Rods, Electrodes, and Filler Metals
Part D – Properties
ASME V: NONDESTRUCTIVE EXAMINATION – 2001.
ASME VIII: DIVISION 1 – RULES FOR CONSTRUCCION OF PRESSURE VESSELS
ASME IX: STANDARD FOR WELDING AND BRAZING PROCEDURES, WELDERS, BRAZERS, AND WELDING AND BRAZING OPERATORS – 2004.
Subsection A General Requirements
Part UG General Requirements for All Methods of Construction and
All Materials
Subsection B Requirements Pertaining to Methods of Fabrication of
Pressure Vessels
Part UW Requirements for Pressure Vessels Fabricated by Welding
Part UF Requirements for Pressure Vessels Fabricated by Forging
Part UB Requirements for Pressure Vessels Fabricated by Brazing
Subsection C Requirements Pertaining to Classes of Materials
Part UCS Requirements for Pressure Vessels Constructed of Carbon and
Low Alloy Steels.
Part UNF Requirements for Pressure Vessels Constructed of Nonferrous
Materials
Part UHA Requirements for Pressure Vessels Constructed of High Alloy
Steel.
Part UCI Requirements for Pressure Vessels Constructed of Cast Iron
Part UCL Requirements for Welded Pressure Vessels Constructed of
Material With Corrosion Resistant Integral Cladding, Weld Metal
Overlay Cladding, or With Applied Linings
Part UCD Requirements for Pressure Vessels Constructed of Cast Ductile
Iron.
Part UHT Requirements for Pressure Vessels Constructed of Ferritic
Steels With Tensile Properties Enhanced by Heat Treatment.
Part ULW Requirements for Pressure Vessels Fabricated by Layered
Construction.
Part ULT Alternative Rules for Pressure Vessels Constructed of Materials
Having Higher Allowable Stresses at Low Temperature.
Tables
Mandatory Appendices.
Nonmandatory Appendices
SI Units
Index
ASME CASE 1896-2: Design of Safety Valve Connections Section I.
EUROPEAN STANDARD
THE EUROPEAN STANDARD EN 13445 - Unfired pressure Vessels – PART 1 GENERAL – 2002.
THE EUROPEAN STANDARD EN 13445 - Unfired pressure Vessels – PART 3 DESING – 2002.
THE EUROPEAN STANDARD EN 13445 - BACKGROUND: Unfired pressure vessels – 2004.
AMERICAN WELDING SOCIETY
AWS A3.0: STANDARD WELDING TERMS AND DEFINITIONS – 2001.
AWS A5.1: SPECIFICATION FOR CARBON STEEL ELECTRODES FOR SHIELDED METAL ARC WELDING – 1991.
AWS A5.4: SPECIFICATIO FOR STAINLESS STEEL ELECTRODES FOR SHIELDED METAL ARC WELDING – 1992.
AWS A5.5: Specification For Low-Alloy Steel Electrodes For Shielded Metal Arc Welding – 1996.
AWS A5.7: SPECIFICATION FOR COPPER AND COPPER ALLOY BARE WELDING RODS AND ELECTRODES – 1984.
AWS A5.9: Specification For Bare Stainless Steel Welding Electrodes And Rods – 1993.
AWS A5.10: SPECIFICATION FOR BARE ALUMINUM AND ALUMINUM – ALLOY WELDING ELECTRODES AND RODS – 1999.
AWS A5.11: Specification for nickel and nickel-alloy welding electrodes for shielded arc welding – 1997.
AWS A5.14: SPECIFICATION FOR NICKEL AND NICKEL-ALLOY BARE – 1997.
AWS A5.17: Specification for Carbon Steel Electrodes and Fluxes for submerged arc welding – 1997.
AWS A5.18: SPECIFICATION FOR CARBON STEEL ELECTRODES AND RODS FOR GAS SHIELDED ARC WELDING – 2001.
AWS A5.22: SPECIFICATION FOR stainless steel electrodes for flux cored arc welding and stainless steel flux cored rods for gas tungsten arc welding – 1995.
AWS B4.0: STANDARD METHODS FOR MECHANICAL TESTING OF WELDS – 2000.
AWS B5.2: SPECIFICATION FOR THE QUANLIFICATION OF WELDING INSPECTOR SPECIALISTS AND WELDING INSPECTOR ASSISTANTS – 2001.
AWS D1.1 : Structural Welding Code—Steel – 2004.
AWS D1.1 : Structural Welding Code—Steel – 1996.
AWS D1.5 : Bridge welding code – 2002.
AWS D3.6: Specification For Underwater Welding – 1999.
AWS D1.6: Structural Welding Code Stainless Steel – 1999.
AWS D10.9: Specification For Qualification Of Welding Procedures And Welder For Piping And Tubing – 1980.
AWS QC1-96: Standard For Aws Certification Of Welding Inspectors – 1996.
SSPC - THE SOCIETY FOR PROTECTIVE COATING
SSPC-PA1: Paint Application Specification Nº 1 – Shop, Field, And Maintenance Painting Of Steel – 2000.
SSPC-VIS 2: Standard Method Of Evaluating Degree Of Rusting On Painted Steel Surfaces – 2000.
SSPC-SP2: Surface Preparation Specification For Nº 2 - Hand Tool Cleaning – 2000.
SSPC-SP3: Surface Preparation Specification For Nº 3 - Power Tool Cleaning – 2000.
SSPC-SP5: White Metal Blast Cleaning – 2000.
SSPC-SP6: Commercial Blast Cleaning – 2000.
SSPC-SP7: Brush-Off Blast Cleaning – 2000.
SSPC-SP10: Near White Metal Blast Cleaning – 1999.
SSPC-SP11: Power Tool Cleaning To Bare Metal – 2000.
SSPC-SP12: Surface Preparation And Cleaning Of Metals By Waterjetting Prior To Recoating – 2000.
NFPA: NATIONAL FIRE PROTECCION ASSOCIATION:
NFPA 58 LPG: STANDARD FOR THE STORAGE AND HANDLING OF LIQUEFIED PETROLEUM GASES – 1992.
NFPA 59A: PRODUCTION, STORAGE, AND HANDLING OF LIQUEFIED NATURAL GAS (LNG) – 1994.
NFPA 59: STANDARD FOR THE STORAGE AND HANDLING OF LIQUEFIED PETROLEUM GASES AT UTILY GAS PLANTS – 1992.
NFPA 1963: NONTHREADED CONNECTIONS – 1963
NFPA 110: ERRATAS – STANDARD FOR EMERGENCYAND STANDBY POWER SYSTEM – 2002.
API
API 2A - Planning, Designing and Constructing Fixed Offshore Platforms--Load and
Resistance Factor Design – 1st Edition 1993.
API 5B - Threading, Gauging, and Thread Inspection of Casing, Tubing, and Line Pipe
Threads – 14th Edition 1996.
API 5L – Specification for Line Pipe – 42nd edition 2000.
API 6D – Specification for pipeline valves (Gate, Plug, Ball and Check Valves)
21th Edition 1994.
API 6FA – Specification for fire test for valves – 30 edition 1999.
API 6H – Specification on End Closure, Connectors and Swivels – 2nd 1998.
API 11 – Manual of Petroleum Measure Standards Chapter - 11 Physical properties Data – Section 4 - Properties of Reference Materials - Part 1—Density of Water and Water Volumetric Correction Factors for Water Calibration of Volumetric Provers – 1st 2003.
API 11PGT - Recommended Practice for Packaged Combustion Gas Turbines – 1st Edition 1992.
API 12R1 - Setting, Maintenance, Inspection, Operation, and Repair of Tanks in Production Service – 5th Edition 1997.
API 12GDU - Specification for Glycol-Type Gas Dehydration Units – 1st Edition 1990.
API 14C - Recommended Practice for Analysis, Design, Installation, and Testing of Basic Surface Safety Systems for Offshore Production Platforms - 7th Edition 2001.
API 14E - Recommended Practice for Design and Installation of Offshore Production Platform Piping Systems – 5th Edition 1991.
API 14G - Recommended Practice for Fire Prevention and Control on Open Type Offshore Production Platforms – 3rd Edition 1993.
API 14J - Recommended Practice for Design and Hazards Analysis for Offshore Production Facilities – 2nd Edition 2001.
API 15LE - Polyethylene (PE) Line Pipe – 3rd Edition 1995.
API 15LR - Low Pressure Fiberglass Line Pipe – 7th Edition 2001.
API 15LP - Thermoplastic Line Pipe – 5th Edition 1981.
API 50 - Natural Gas Processing Plant Practices for Protection of the Environment – 2nd Edition 1995.
API 51 - Onshore Oil and Gas Production Practices for Protection of the Environment – 3rd Edition 2001.
API 500 – Recommended Practice for Classification of Locations for Electrical Installations at Petroleum Facilities Classified as Class 1, Division 1 and Division II – 2nd Edition 1997.
API 510 - Pressure Vessel Inspection Code: Maintenance Inspection, Rating, Repair, and Alteration – 8th 2003.
API 520 - Sizing, Selection, and Installation of Pressure-Relieving Devices in Refineries (Part I—Sizing and Selection 7th Edition 2000 & Part II—Installation 5th Edition 2003)
API 521 - Guide for Pressure-Relieving and - Depressuring Systems – 4th Edition 1997.
API 526 - Flanged Steel Pressure Relief Valves – 5th Edition 2003.
API 530 - Calculation of Heater Tube Thickness in Petroleum Refineries – 5th 2003.
API 535 – Burners for Fired Heaters in General Refinery Services – 1st Edition 1995.
API 537 - Flare Details for General Refinery and Petrochemical Service – 1st Edition 2003.
API 541 – Form-Wound Squirrel Cage Induction Motors – 250 Horsepower and Latrger – 3rd Eition 1995.
API 551 - Process Measurement Instrumentation – 1st Edition 1993.
API 552 - Transmission Systems – 1st Edition 1994.
API 553 - Refinery Control Valves – 1st Edition 1998.
API 554 - Process Instrumentation and Control – 1st Edition 1995.
API 556 – Instrumentation and Control System for Fired Heaters and Steam generator – 1st 1997.
API 560 - Fired Heaters for General Refinery Service – 3rd Edition 2001.
API 570 - Piping Inspection Code – 2nd Edition 2001.
API 570 - Piping Inspection Code – 2nd Edition 2006.
API 571 - Damage Mechanisms Affecting Fixed Equipment in the Refining Industry – 1st Edition 2003.
API 572 - Inspection of Pressure Vessels (Towers, Drums, Reactors, Heat Exchangers, and Condensers) – 2nd Edition 2001.
API 573 - Inspection of Fired Boilers and Heaters – 2nd Edition 2003.
API 574 - Inspection Practices for Piping System Components – 2nd Edition 1998.
API 575 - Inspection of Atmospheric and Low-Pressure Storage Tanks – 1st Edition 1995.
API 576 - Inspection of Pressure-Relieving Devices – 2nd Edition 2000.
API 578 - Material Verification Program for New and Existing Alloy Piping Systems – 1st Edition 1999.
API 579 - Fitness-for-Service – 3rd Edition 2000.
API 580 - Risk-based Inspection – 1st Edition 2002.
API 581 - Risk-Based Inspection Base Resource Document – 1st Edition 2000.
API 591 - Process Valve Qualification Procedure – 3rd Edition 2003.
API 594 - Check Valves: Wafer, Wafer-Lug, and Double Flanged Type – 5th Edition 1997.
API 598 - Valve Inspection and Testing – 7th Edition 1996.
API 599 – Metal Plug Valves – Flanged and Welding End – 4th Edition 1994
API 600 – Steel Gate Valves – Flanged and Butt Welding Ends, Bolted and Pressure Seal Bonnets – 11th Edition 1998.
API 602 - Compact Steel Gate Valves— Flanged, Threaded, Welding, and Extended-Body End – 7th Edition 1998.
API 603 - Corrosion-Resistant, Bolted Bonnet Gate Valves—Flanged and Butt-Welding End – 6th edition 2001.
API 607 – Fire Test for Seated Quarter-Turn Valves – 4th Edition 1993.
API 608 - Metal Ball Valves-Flanged, Threaded, and Welding End – 2nd Edition 1995.
API 609 – Butterfly Valves: Double Flanged Lug and Wafer Type – 5th Edition 1997.
API 610 - Centrifugal Pumps for Petroleum, Petrochemical and Natural Gas Industries
9th Edition 2003.
API 611 - General-Purpose Steam Turbines for Petroleum, Chemical, and Gas Industry Services – 4th Edition 1997.
API 612 - Special Purpose Steam Turbines For Petroleum, Chemical, and Gas Industry Services – 4th Edition 1995.
API 613 - Special Purpose Gear Units for Petroleum, Chemical and Gas Industry Services – 5th edition 2003
API 614 – Lubrication Shaft-Sealing and Control-Oil Systems and Auxiliaries for Petroleum, Gas and Chemical Gas Industry Services - 4th edition 1999.
API 616 - Gas Turbines for the Petroleum, Chemical, and Gas Industry Services – 4th Edition 1998.
API 617 - Centrifugal Compressors for Petroleum, Chemical, and Gas Service Industries – 6th Edition 1995.
API 618 - Reciprocating Compressors for Petroleum, Chemical, and Gas Industry Services – 4th Edition 1998.
API 619 - Rotary Type Positive Displacement Compressors for Petroleum, Chemical, and Gas Industry Services - 3rd Edition 1997.
API 650 - Welded Steel Tanks for Oil Storage – 10th Edition 2003.
API 653 - Tank Inspection, Repair, Alteration, and Reconstruction – 3rd Edition 2003.
API 660 - Shell-and-tube Heat Exchangers for General Refinery Services – 7th Edition 2003.
API 661 - Air-Cooled Heat Exchangers for General Refinery Services – 4th Edition 1997.
API 676 - Positive Displacement Pumps—Rotary – 2nd Edition 1994.
API 682 - Pumps—Shaft Sealing Systems for Centrifugal and Rotary Pumps – 2nd Edition 2002
API 750 - Management of Process Hazards – 1st Edition 1990.
API 941 - Steels for Hydrogen Service at Elevated Temperatures and Pressures in Petroleum Refineries and Petrochemical Plants – 6th Edition 2004.
API 945 - Avoiding Environmental -----ing in Amine Units – 3rd Edition 2003.
API 1102 - Steel Pipelines Crossing Railroads and Highways – 6th Edition 1993.
API 1104 - Welding of Pipelines and Related Facilities – 19th Edition 1999
API 1109 - Marking Liquid Petroleum Pipeline Facilities – 2nd Edition 1993.
API 1110 - Pressure Testing of Liquid Petroleum Pipelines – 4th Edition 1997.
API 1111 - Design, Construction, Operation, and Maintenance of Offshore Hydrocarbon Pipelines (Limit State Design) – 3rd Edition 1999.
API 1117 - Movement of -Service Pipelines – 2nd Edition 1996.
API 1130 – Computational Pipeline Monitoring – 1st Edition 1995.
API 1149 - Pipeline Variable Uncertainties and Their Effects on Leak Detectability – 1st Edition 1993
API 1155 – Evaluation Methodology for Software Based Leak Detection System – 1st Edition 1995.
API 1161 - Guidance Document for the Qualification of Liquid Pipeline Personnel – 1st Edition 2000
API 1632 – Cathodic Proteccion of Underground Petroleum Storage Tanks and Piping Systems – 3rd Edition 1996.
API 1165 - Evaluation Methodology for Software-Based Leak Detection Systems – 1st 1995
API 2000 - Venting Atmospheric and Low-Pressure Storage Tanks: Nonrefrigerated and Refrigerated – 5th Edition 1998.
API 2001 - Fire Protection in Refineries – 7th Edition 1998.
API 2003 - Protection Against Ignitions Arising Out of Static, Lightning, and Stray Currents – 6th Edition 1998.
API 2015 - Requirements for Safe Entry and Cleaning of Petroleum Storage Tanks – 6th Edition 2001.
API 2016 - Guidelines and Procedures for Entering and Cleaning Petroleum Storage Tanks – 1st Edition 2001.
API 2030 - Application of Water Spray Systems for Fire Protection in the Petroleum Industry – 2nd Edition 1998.
API 2200 - Repairing Crude Oil, Liquefied Petroleum Gas and Product Pipelines – 3rd Edition 1994.
API 2201 - Safe Hot Tapping Practices in the Petroleum & Petrochemical Industries - 5th Edition 2003.
API 2218 - Fireproofing Practices in Petroleum and Petrochemical Processing Plants – 2nd Edition 1999.
API 2517D - Evaporation Loss from External Roof Tanks – 1st Edition 1993.
API 2519D – Evaporation Loss from Internal Roof Tanks – 1st Edition 1993.
API 2531 – Mechanical Displacement Meter Proves – 1st Edition 1963.
API 2534 - Manual of Petroleum Measure Standards Chapter 5 – Liquid Metering – Section 4 Accessory Equipment for Liquid Meters – 2nd Edition 1987.
API 2534 - Manual of Petroleum Measure Standards Chapter 5 – Metering – Section 5 Fidelity and Security of Flow Measurement Pulsed-Data Transmission Systems – 1st Edition 1992.
API 2534 - Manual of Petroleum Measure Standards Chapter 6 – Metering Assemblies – Section 7 Metering Viscous Hydrocarbons – 2nd Edition 1991.
API 2551 - Method for Measurement and Calibration of Horizontal Tanks – 1st Edition 1965.
API 2552 - Method for Measurement and Calibration of Spheres and Spheroids – 1st Edition 1965.
API 2554 - Method for Measurement and Calibration of Tank Cars – 1st Edition 1965.
API 2555 - Method for Liquid Calibration of Tanks – 1st Edition 1966.
API 2556 - Correction Gauge Tables for Incrustation – 2nd Edition 1993.
API 4653 – Fugitive Emission Factors for Crude Oil and Product Pipeline Facilities - 1997
API “Manual of Petroleum Measurement Standards” Chapter 1 to 21:
Chapter 1: Manual of Petroleum Measurement Standards – 2nd Edition 1994.
Chapter 2: Tank Calibration.
Section 2A: Measure and Calibration of Upright Cilindrical Tanks by the Manual Tank Strapping Method – 1st Edition 1995.
Section 2B: Calibration of Upright Cilindrical Tanks using the Optical Reference Line Method Measure – 1st Edition 2002.
Chapter 3: Tank Gauging.
Section 1A: Standard Practice for the Manual Gauging of Petroleum and Petroleum Products – 1st Edition 1994.
Section 1B: Standard Practice for Level Measurement of Liquid Hydrocarbons in Stationary Tank by Automatic Tank Gauging – 1st Edition 1992.
Section 2: Standard Practice for Gauging Petroleum and Petroleum Products in Tank Cars – 1st Edition 1995.
Section 3: Standard Practice for Level Measurement of Liquid Hydrocarbons in Stationary Pressurized Storage Tanks by Automatic Tank Gauging – 1st Edition 1996.
Chapter 4: Proving System.
Section 1: Introduction – 2nd Edition 1998.
Section 2: Conventional Pipe Provers – 1st Edition 1998.
Section 3: Small Volume Provers – 1st Edition 1998.
Section 4: Tank Provers – 2nd Edition 1998.
Section 5: Master-Meter Provers – 1st Edition 1988.
Section 6: Pulse Interpolation – 2nd Edition 1999.
Section 7: Field Standard Test Measures – 2nd Edition 1998.
Section 8: Operation of Proving Systems – 1st Edition 1995.
Chapter 5: Metering
Section 1: General Consideration for Measurement by Meters – 3rd Edition 1995.
Section 2: Measurement of Liquid Hydrocarbons by Displacement Meters – 2nd Edition 1987.
Section 3: Measurement of Liquid Hydrocarbons by Turbine Meters – 4th Edition 2002.
Section 4: Accessory Equipment for Liquid Meters – 3rd Edition 1995.
Section 5: Fidelity and Security of Flow Measurement Pushed-Data Transmission Systems – 1st Edition 1982.
Section 6: Measurement of Liquid Hydrocarbons by Coriolis Meters – 1st Edition 1992.
Chapter 6: Metering Assembling
Section 1: Lease Automatic Custody Transfer (LACT) Systems – 2nd Edition 1996.
Section 2: Loading – Rack and Tank-Truck Metering Systems for non-LPG Product – 2nd Edition 1994.
Section 3: Service Station Metered Fuel – Dispending Systems – 2nd Edition 1994.
Section 4: Metering Systems for Aviation Fuelling Facilities – 1st Edition 1996.
Section 5: Metering System for Loading and Unloading Marine Bulk Carries – 2nd Edition 1994.
Section 6: Pipeline Metering System – 2nd Edition 1996.
Chapter 7: Temperature Determination – 1st Edition 2001.
Section 1: Static Temperature Determination Using Mercury-in-Glass Tank Thermometers – 1st Edition 1991.
Section 2: Dynamic Temperature Determination – 2nd Edition 1995.
Section 3: Static Temperature Determination Using Portable Electronic Thermometers – 1st Edition 1985.
Section 4: Static Temperature Determination Using Fixed Automatic Tank Thermometers – 1st edition 1993
Chapter 8: Sampling
Section 1: Standard Practice for Manual Sampling of Petroleum and Petroleum Products – 3rd Edition 1995.
Section 2: Standard Practice for Automatic Sampling of Liquid Petroleum and Petroleum Products – 2nd Edition 1995.
Section 3: Standard Practice for Mixing and Handling of Liquid Samples of Petroleum and Petroleum Products – 1st Edition 1995.
Section 4: Manual Sampling and Handling of Fuels for Volatility Measurement – 1st Edition 1995.
Chapter 9: Density
Section 1: Hydrometer Test Method for Density, Relative Density (Specific Gravity), or API Gravity of Crude Petroleum and Liquid Petroleum Products – 1st Edition 1992.
Section 2: Pressure Hydrometer Test Method for Density or Relative Density – 1st Edition 1987.
Section 3: Thermohydrometer Test Method for Density and API Gravity of Crude Petroleum and Liquid Petroleum Products – 1st Edition 1994.
Chapter 10: Sediment and Water
Section 1: Determination of Sediment in Crude Oils and Fuel Oils by the Extraction Method – 1st Edition 1993.
Section 2: Determination of Water in Crude Oil by Distillation – 1st Edition 1993.
Section 3: Determination of Water and Sediment in Crude Oil by the Centrifuge Method (Laboratory Procedure) – 1st Edition 1981.
Section 4: Determination of Sediment and Water in Crude Oil by the Centrifuge Method (Field Procedure) – 2nd Edition 1988.
Section 5: Determination of Water in Petroleum Products and Bituminous Materials by Distillation – 2nd Edition 1994.
Section 6: Determination of Water and Sediment in Fuel Oils by the Centrifuge Method (Laboratory Procedures) – 2nd Edition 1995.
Section 7: Standard Test Method for Water in Crude Oil by Karl Fischer Titration (Potentiometer – 1st Edition 1996.
Section 8: Standard Test Method for Sediment in Crude Oil by Membrane Filtration – 1st Edition 1993.
Section 9: Standard Test Method for Water in Crude Oils by Coulometric Karl Fischer Titration – 1st Edition 1993.
Chapter 11: Physical Properties Data - Viscosity – 5th Edition 1992.
Chapter 11.2.1-Compressibility Factors for Hydrocarbons: 0-90º API Gravity and 638-1 074 Kilograms per Cubic Metre Range – 1st Edition 1984.
Chapter 11.2.1 M-Compressibility Factors for Hydrocarbons: 0-90º API Gravity and 638-1 074 Kilograms per Cubic Metre Range – 1st Edition 1984.
Chapter 11.2.2-Compressibility Factors for Hydrocarbons: 0.350-0.637 Relative Density (60°F/600F) and - 50°F to 140°F Metering Temperature – 2nd Edition 1986.
Chapter 1 1.2.2M-Compressibility Factors for Hydrocarbons: 350-637 Kilograms per Cubic Metre Density (15ºC) and - 46°C to 60°C Metering Temperature – 1st Edition 1986.
Chapter 11.2.3M-Water Calibration of Volumetric Provers – 1 st Edition 1984.
Section 4: Properties of Reference Materials
Part 1—Density of Water and Water Volumetric Correction Factors for Water Calibration of Volumetric Provers - 1st Edition 2003.
Chapter 12: Calculation of Petroleum Quantities
Section 2: Calculation of Liquid Petroleum Quantities Measured by Turbine or Displacement Meters – 1st 1981.
Section 2 - Calculation of Petroleum Quantities Using Dynamic Measurement Methods and Volumetric Correction Factors
Part 1 - Introduction – 2nd Edition 1995.
Part 2 - Measurement Tickets – 2nd Edition 1995.
Part 3 - Proving Reports – 1st Edition 1998.
Part 4 - Calculation of Base Prover Volumes
by the Waterdraw Method – 1st Edition 1997.
Chapter 13: Statistical Aspects of Measuring and Sampling
Section 1: Statistical Concepts and Procedures in Measurement – 1st edition 1985.
Section 2: Methods of Evaluating Meter Proving Data – 1st Edition 1994.
Chapter 14: Natural Gas Fluids Measurement
Section 1: Collecting and Handling of Natural Gas Samples for Custody Transfer – 5th Edition 2005.
Section 3: Concentric, Square – Edged Orifice Meters
Part 4 - Background, Development, Implementation Procedures and Subroutine Documentation – 3rd Edition 1992.
Section 4: Converting Mass of Natural Gas Liquids and Vapors to Equivalent Liquid Volumen – 1st Edition 1991.
Section 5: Calculation of Gross Heating Value, Specific Gravity, and Compressibility of Natural Gas Mixtures from Compositional Analysis – 2nd Edition 2002.
Section 6: Continuous Density Measurement – 2nd Edition 1991.
Section 7: Mass Measurement of Natural Gas Liquids – 2nd Edition 1995.
Section 8: Liquefied Petroleum Gas Measurement – 2nd Edition 2002.
Chapter 15: Guidelines for the Use of the International System of Units (SI) in the Petroleum and Allied Industries – 2nd Edition 1980.
Chapter 16: Measurement of Hydrocarbon Fluids by Weight or Mass
Section 2: Mass Measurement of Liquid Hydrocarbons in Vertical Cylindrical Storage Tanks by Hydrostatic Tank Gauging – 1st Edition 1994.
Chapter 17: Marine Measurement
Section 9: Vessel Experience Factor - IP Hydrocarbon Management HM 49 – 1st Edition 2005.
Chapter 18: Custody Transfer
Section 1: Measurement Procedures for Crude Oil Gathered From Small Tanks by Truck – 2nd Edition 1997.
Chapter 19: Evaporative Loss Measurement.
Section 1: Evaporative Loss From Fixed Roof Tanks – 2nd Edition 1991.
Section 1D: Documentation File for API Manual of Petroleum Measurement Standards Chapter 19.1—Evaporative Loss From Fixed Roof Tanks – 1st Edition 1993.
Section 2: Evaporative Loss From Floating Roof Tanks-1st Edition 1997.
Section 4: Recommended Practice for Speciation of Evaporative Losses – 1st Edition 1994.
Chapter 20: Allocation Measurement
Section 1: Allocation Measurement – 1st Edition 1993.
Chapter 21: Flow Measurement Using Electronic Metering Systems
Section 1: Electronic Gas Measurement – 1st Edition 1993.
Section 2: Electronic Liquid Volume Measurement Using Positive
Displacement And Turbine Meters – 1st Edition 1998.
API TECHNICAL DATA BOOK – Chapter 6: Density – 4th Edition 1983.
