thanks a lot to legend, its function wunderful
Pl help regarding installation - archive has 35 zip folders? thank you very much
Extract the zip f 1 by 1 in 1 folder. Each zip file contains rar file.
Extract the rar files. it will contain "setup.exe" and Legend folder which contain ****** and readme.
hi, I installed the program, but when it launched the program,it directs to the license setup window, but all the "OK" button is grey and unaccessible. I could input the user license number but can not press "OK". What's wrong with it?
P.S. I installed Chemcad 6.0.1 before and uninstalled it befor installing this new version
Thank you very much polaris44
as usual you are very helpful.
loveche:- if the license key is generated properly and copied into the license setup box, the ok button becomes available (from being gray). generate the license key and enter carefully in the text box. it works! all the best.
ChemCAD v6.1.3 ****** and link to setup are available here:
Password: 4t0m1xm4n
hi fnrds i need help..i hav downloaded the software i got problem while extraction...wen i start extractin the file from 'CHEMSTATIONS_CHEMCAD_V6.1.3-LND.part1.rar' that is 'l-cck601zip' it opens the legend n setup file..wen i try to copy or send the setup file to a folder it opens an pop up message that 'u need the followin volume to exctract' in the box the below path will be there 'C:\Documents and Settings\chetan\Local Settings\Temp\Rar$DI00.344\legend.002'...n below this a caption ll be ther that 'insert a disk with this volume and press 'ok' or 'cancel' the extraction 'wether i need to copy this two files that is part1 n 2 into a CD or wat..pl help me.
rajarani87,
the two rar parts (part1 & part2) need not be copied to a CD; just keep all the 35 zip folders in a single folder and extract all together, then 2 files i.e., 1 legend folder with c...k and 1 setup file will be created. good luck!
hi
you people r great its working
thanks n keep it up
endeavor,
thanks for helpin...workin nicely...thanks
