thanks very much friends
Thanks for the software...........
go to shewe.yolasite.com for mediafire link of every civil engineering softwares
thanx a lot master..![]()
Hello everybody, has anyone tryed to launch latest Staad.PRO V8i on windows 7 64-bit?
Please share Staad.PRO V8i on windows 7 64-bit
is this with c******-c-k-????
Select Series 3 is out. Anyone has M-E-D-I-C-I-N-E for that??????
Kindly shear
Dear friends,..
I'd tried installing,,, it using the provided valuable information.. //
though, it showed initially, that u may use the application now...//
the application is not starting up.. once i click on it.. or double click over d icon..!!
please, tell me what cud hav gone wrong,.. ?? and wat shud b done.. so that the staad pro application can b s
Download Link:
"For working on vista and win 7 simply right click the " setup.exe" file and select "Run as administrator".All other informations are given in it."
1.Open Bentley IEG License Service folder.
2.Run setup.exe[right click the " setup.exe" file and select "Run as administrator"]
3.After finishing it install the other setup file[right click the " setup.exe" file and select "Run as administrator"] present in STAAD Pro 2007 folder.
4.When installation completes Copy the "bentley.liclib.dll" file present in the ----- folder.
5.Paste it on this location "C:\Program Files\Common Files\BentleyShared\IEG\IEGLCS\".
You will get a warning about replacing file.Confirm replace.
6.After that double click the file "spro2007.reg" present in the ----- folder.You will get a message"Are you sure you want to add this file to the registry.Confirm it.
7.Now you can run the staad from desktop shortcut.
~Note: For those on x64 systems you have to change the registry editor file (spro2007_2.reg in ----- folder). open it with notepad, do a search and replace.
search: HKEY_LOCAL_MACHINE\SOFTWARE
replace: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node
~ Or
for those on x64 systems you have to change the registry editor file (spro2007_2.reg in ----- folder). open it with notepad, do a search and replace.
