Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 25 to 36 of 39
Thread: AD2000 German pressure vessel code
  1. Re: AD2000 German pressure vessel code
    Quote Originally Posted by ThaMaestro View Post
    I think I may have found the exact reference which underlines your statement on hot tensile testing, it is found in W1 section 3.3 and 3.4, W3/1 section 3.1 and 7.1.2. These sections apply to specific product forms, i.e. flat products (plate) and cast iron, respectively.
    THerefore the remark you made has to be within a certain context. As I understand it, it does not apply in general to all types of materials applied within AD2000 ...
    It is applicable to all ductile materials in rolled & forged form used as pressure parts for Pressure vessel components and obviously it wouldnt apply to brittle materials and non pressure parts.
    Also in other cases while using ADM code, it is recommended that hot tensile test be performed if the design allowable stress is based purely on yield strength.
    For other product forms, I would suggest that you read the EN codes testing requirements that are referenced in their respective section in AD code.
  3. Re: AD2000 German pressure vessel code
    Thanks again, but Im not quite sure where you base your statement on. Do you have a reference of AD 2000 backing that up? I.e. a section which mentions that hot tensile testing "is applicable to all ductile materials in rolled & forged form used as pressure parts for pressure vessel components". I have in the W1 section that the design characteristic for austenitic steels is 1% yield strength, but there's no mention to hot tensile testing.
    It's not that I dont want to believe you, in fact, I appreciate your valuable input, but it's just not in my nature to believe you just like that - I need to be convinced based on references which I can check down to the applicable Code (section).
  5. Re: AD2000 German pressure vessel code
    I appreciate your rationale my friend but you wont be able to believe it unless you read & use it and I am sorry i wont be able to explain my point further.
    Please read the testing standard also. It will solve your query.
    Thanks.
  6. Re: AD2000 German pressure vessel code
    hi najam* would u able to share with me ad 2000 merkblatt?
    I am new in this inspection industry and currently work in a NDT company and client's plant were designed in accordance to AD code and built by the german some time back in 2005 as what i remembered.. i have been asking the project manager* ops manager and even inspectors in my company why are they using ASME Sec VIII for the acceptance criteria and not AD 2000 as per the request* they told me all codes are similar and ASME Sec VIII is commonly used* not the German's codes. I am not so convinced in this but i m still a beginner in this field. Would any of you able to share your thoughts?
  7. Re: AD2000 German pressure vessel code
    Please Share AD 2000 Code again need working link
  9. #30
    Hello Team
    Could someone kindly re-share this code. Thank you very much in advance.
  10. Re: AD2000 German pressure vessel code
    Is it possible that someone share working link for AD2000?
  11. #32
  12. Re: AD2000 German pressure vessel code
    Could somebody upload again?
  13. Re: AD2000 German pressure vessel code
    Here you go* hopefully it works :
  14. #35
    Post #32 link is active
  16. Re: AD2000 German pressure vessel code
    Thank you Jack! It helps me a lot!
  1. Australian Pressure Vessel Code
    By praphulla.phirke in forum Mechanical Engineering
    Last Post: 08-21-2017, 02:35 AM
  2. China gb pressure vessel code
    By kafmaidi in forum Mechanical Engineering
    Last Post: 07-27-2017, 10:04 AM
  3. ASME pressure vessel code
    By kunu2011 in forum Mechanical Engineering
    Last Post: 09-05-2013, 12:30 PM
  4. CSA B51-09 Boiler, Pressure Vessel and Pressure Piping Code Need
    By cpchonburi in forum Mechanical Engineering
    Last Post: 08-05-2011, 01:14 AM
  5. CSA B51-09 Boiler, Pressure Vessel and Pressure Piping Code
    Last Post: 07-29-2011, 06:48 AM
