RUNSPEC
-- Title is used as header on output, to identify run
TITLE
Example Simulation
-- Specify dimension of model, NX, NY, NZ
DIMENS
-- NX NY NZ
10 10 3 /
-- Phases included (oil and water, i.e. 2-phase run)
OIL
WATER
-- Units to use, METRIC, FIELD or LAB
FIELD
-- Specify maximum values for well data
WELLDIMS
-- max.wells; max.cell-connections; Next three values are defaulted
4 5 3* /
-- Start date, i.e. “Day 0” in simulation
START
1 'JAN' 2012 /
GRID
-- Definition of grid cells. From DIMENS keyword above, we have:
-- N = NX*NY*NZ = 10*3*3 = 90.
-- In each cell DX = DY = 1000 ft and DZ = 50 ft
-- (Dimension measured in feet since units were defined as FIELD above)
-- The grid cells are then defined by:
DX
300*1000 /
DY
300*1000 /
DZ
300*50 /
--depths which are consistent with the DZ-values defined by:
TOPS
100*5000 100*5050 100*5100 /
-- Permeabilities are constant, so define 300 equal values.
PERMX
300*100 /
PERMY
300*100 /
PERMZ
300*20 /
-- Porosity is constant in each layer, so define 100 values in layer 1, 100 in layer 2, and 100 in layer 3.
PORO
100*0.3
100*0.23
100*0.18 /
PROPS
-- Relative permeability for water and oil,
-- and water-oil capillary pressure, as a function of water saturation
SWOF
-- Sw Krw Krow Pcow
0.2 0.00 1.00 326.2
0.3 0.01 0.99 168.7
0.4 0.02 0.88 101.2
0.5 0.03 0.67 67.4
0.6 0.04 0.56 52.9
0.7 0.06 0.39 42.4
0.8 0.19 0.16 0.00
0.9 0.45 0.00 0.00
1.0 0.78 0.00 0.00
-- PVT properties for water.
-- Pref: Reference pressure for rest of data (psi)
-- Bw: Volume formation factor for water
-- Cw: Water compressibiblity
-- ViscW: Water viscosity
PVTW
-- Pref Bw Cw ViscW
4014.7 1.029 3.13D-6 0.31 0 /
-- PVT properties for oil
PVDO
-- P Bo viscO
3337.0 1.2600 1.042
3725.0 1.2555 1.072
4139.5 1.2507 1.096
4573.2 1.2463 1.118
5053.9 1.2417 1.151
5487.5 1.2377 1.174
5813.9 1.2356 1.2 /
-- Dead oil: Rs (Gas resolution factor) is constant
RSCONST
-- Rs Bubble-point-pressure
0.4 3337.0 /
-- Specify constant rock compressibility.
ROCK
-- Pref Cr
14.7 3.0D-6 /
-- Fluid densities at surface conditions
DENSITY
-- Oil Water Gas
49.1 64.79 0.06054 /
SOLUTION
EQUIL
-- DD = Datum depth, the depth to which all reports will be referenced.
-- DD Pres.at.DD OWC Pcow(OWC) Default rest of data items
5000 4800 6000 0.0 6* /
SUMMARY
-- List data vectors which we want stored for graphics post-processing
-- Field Oil Production Rate
FOPR
-- Field Oil Production Total
FOPT
-- Field Pressure (averaged reservoir pressure)
FPR
-- Field Oil In Place
FOIP
-- Field Water Production Rate
WWPR
-- Field Water Injection Rate
WWIR
-- Well Water Cut for all wells
WWCT
SCHEDULE
-- Specify output of graphics result files for cell data, and times which to write these.
RPTRST
BASIC=5 NORST=1 FREQ=6 /
-- Well specification: Give names, positions (i, j) and main phase of wells
WELSPECS
--wname group i j Z(bhp) prefPhase
'WP1' 'G' 10 2 1* 'OIL' /
-- Completion data, the well is open to the reservoir in cells in layers from k_hi to k_lo.
COMPDAT
--wname ic jc k_hi k_lo open/shut 2*default well_diam 4*default
'WP1' 10 2 1 2 'OPEN' 2* 0.5 4* /
-- Well WP1 will produce with an oil rate of 2000 STB/day constrained by that well’s flowing bottomhole pressure is minimum 3350 psi.
WCONPROD
--wname open/shut ctrlmode orat 4*Default bhpmin Rest default
'WP1' 'OPEN' 'ORAT' 2000 4* 3350 /
-- Milestone dates, e.g. to write results
DATES
1 'FEB' 2012 /
1 'MAR' 2012 /
-- Change production rate to 4000 STB/day
WCONPROD
'WP1' 'OPEN' 'ORAT' 4000 4* 3350 /
DATES
1 'APR' 2012 /
DATES
1 MAY 2012 /
DATES
1 JUN 2012 /
DATES
1 JUL 2012 /
DATES
1 AUG 2012 /
DATES
1 SEP 2012 /
DATES
1 OCT 2012 /
DATES
1 NOV 2012 /
DATES
1 DEC 2012 /
DATES
1 JAN 2013 /
END
