Page 29 of 89 FirstFirst ... 19 27 28 29 30 31 39 79 ... LastLast
Results 337 to 348 of 1065
Thread: ASTM Book Volume 2015
  1. Re: ASTM Book Volume 2015
    Hi Marty,
    Any chance you could share these ones please?
    DS45A Compilation and Index of Trade Names, Specifications, and Producers of Stainless Alloys and Superalloys
    MNL46 Metallographic and Materialographic Specimen Preparation, Light Microscopy, Image Analysis and Hardness Testing
    DS71 ISOCORRAG International Atmospheric Exposure Program: Summary of Results
    Thanks again for the fantastic work you've put in here.
    Cheers, Catweazle
    DS45A 1975 Compilation and Index of Trade Names, Specifications, and Producers of Stainless Alloys and Superalloys
    zip, pass: egpet.net
    DS71 2010 ISOCORRAG International Atmospheric Exposure - Program Summary of Results
  6. #340
    MNL46 - Metallographic and Materialographic Specimen Preparation, Light Microscopy, Image Analysis and Hardness Testing 2007
  7. Re: ASTM Book Volume 2015
    You're a champion Marty, many thanks.
  9. #342
    Section 4 new 12/19/2015
    4.02
    C494C494M-15a Standard Specification for Chemical Admixtures for Concrete
    4.03
    D7228-06a(2015) Standard Test Method for Prediction of Asphalt-Bound Pavement Layer Temperatures
    D7944-15 Standard Practice for Recovery of Emulsified Asphalt Residue Using a Vacuum Oven
    E660-90(2015) Standard Practice for Accelerated Polishing of Aggregates or Pavement Surfaces Using a Small-Wheel, Circular Track Polishing Machine
    E1844-08(2015) Standard Specification for A Size 10 × 4–5 Smooth-Tread Friction Test Tire
    E1890-11(2015) Standard Guide for Validating New Area Reference Skid Measurement Systems and Equipment
    E1960-07(2015) Standard Practice for Calculating International Friction Index of a Pavement Surface
    E2583-07(2015) Standard Test Method for Measuring Deflections with a Light Weight Deflectometer (LWD)
    4.04
    D3746D3746M-85(2015)e1 Standard Test Method for Impact Resistance of Bituminous Roofing Systems
    D6383D6383M-99(2015) Standard Practice for Time-to-Failure (Creep-Rupture) of Adhesive Joints Fabricated from EPDM Roof Membrane Material
    4.06
    C461-81(2015) Standard Test Methods for Mastics and Coatings Used With Thermal Insulation
    C550-15 Standard Test Method for Measuring Trueness and Squareness of Rigid Block and Board Thermal Insulation
    E2963-15 Standard Test Method for Laboratory Measurement of Acoustical Effectiveness of Ship Noise Treatments Laboratory Measurement of Acoustical Effectiveness for Marine Bulkhead and Deck Treatments
    4.07
    C716-06(2015) Standard Specification for Installing Lock-Strip Gaskets and Infill Glazing Materials
    C864-05(2015) Standard Specification for Dense Elastomeric Compression Seal Gaskets, Setting Blocks, and Spacers
    C1083-06(2015) Standard Test Method for Water Absorption of Cellular Elastomeric Gaskets and Sealing Materials
    E1678-15 Standard Test Method for Measuring Smoke Toxicity for Use in Fire Hazard Analysis
    4.08
    D2850-15 Standard Test Method for Unconsolidated-Undrained Triaxial Compression Test on Cohesive Soils
    D2976-15 Standard Test Method for pH of Peat Materials
    D3282-15 Standard Practice for Classification of Soils and Soil-Aggregate Mixtures for Highway Construction Purposes
    D4542-15 Standard Test Methods for Pore Water Extraction and Determination of the Soluble Salt Content of Soils by Refractometer
    D5855D5855M-15 Standard Test Method for (Analytical Procedure) for Determining Transmissivity and Storage Coefficient of Confined Nonleaky or Leaky Aquifer by Constant Drawdown Method in Flowing Well
    4.09
    D6023-15 Standard Test Method for Density (Unit Weight), Yield, Cement Content, and Air Content (Gravimetric) of Controlled Low-Strength Material (CLSM)
    D6635-15 Standard Test Method for Performing the Flat Plate Dilatometer
    4.10
    D198-15 Standard Test Methods of Static Tests of Lumber in Structural Sizes
    D3957-09(2015) Standard Practices for Establishing Stress Grades for Structural Members Used in Log Buildings
    D4445-10(2015) Standard Test Method for Fungicides for Controlling Sapstain and Mold on Unseasoned Lumber (Laboratory Method)
  10. Re: ASTM Book Volume 2015
    Dear Marty,
    Your kind assistance is requested to get these:
    DS70 - Handbook of Steel Data: American and European
    DS59 - Evaluations of the Elevated Temperature Tensilde and Creep-Rupture Properties of 12 to 27 Percent Chromium Steels
    DS50 - Evaluation of the Elevated Temperature Tensile and Creep-Rupture Properties of 1/2Cr-1/2Mo, ICR-1/2Mo, and I1/4Cr-1/2MO-Si Steels
    MPC15V4N2 - Materials Performance and Characterization Special Issue on Advances in Fatigue and Fracture Mechanics
    MPC14V3N2 - Materials Performance and Characterization Special Issue on High Temperature Fatigue
    MPC14V3N3 - Materials Performance Characterization Special Issue on Fracture Toughness
    ASTM STPs 1207, 1208, 1210, 1211
    Thank you.
  11. #344
    DS70, MPC15V4N2, MPC14V3N2, & MPC14V3N3 are not available for download
    DS50 1973 Evaluation of the Elevated Temperature Tensile and Creep Rupture Properties of .5Cr .5Mo, ICR .5Mo, and I.5Cr .5MO Si Steels
    in zip, Pass: egpet.net
  12. #345
    DS59 1980 Evaluations of the Elevated Temperature Tensilde and Creep Rupture Properties of 12 to 27 Percent Chromium Steels
  13. #346
    STP 1207 Fracture Mechanics; Twenty-Fourth Volume 1994
  14. #347
    STP 1208 Automation of Mechanical Testing 1993
  16. #348
    STP 1210 Slow Strain Rate Testing for the Evaluation of Environmentally Induced *****ing; Research and Engineering Applications 1993
  1. ASTM D1250 - Volume 07 Tables 53A & 54A
    By el hassan in forum Laboratory Measurements
    Last Post: 02-12-2019, 02:05 PM
  2. ASTM Handbook Volume 3.02 and 3.03
    By id24_band@yahoo.com in forum Materials Science &Corrosion
    Last Post: 07-21-2017, 10:23 PM
  3. Astm a780 / a780m - 09(2015)
    By kavita_00 in forum Mechanical Engineering
    Last Post: 03-16-2016, 05:23 AM
  4. ASTM Volume 08.03 (D4097 , D3299)
    By Virgule in forum Mechanical Engineering
    Last Post: 02-16-2013, 06:00 PM
