Page 27 of 36 FirstFirst ... 17 25 26 27 28 29 ... LastLast
Results 313 to 324 of 423
  1. #313
    Re: Excel library for process calc's including distillation
    thanks tmander,
    is that a cloud or local network ?
  3. Re: Excel library for process calc's including distillation
    actually we have Prode Properties installed on a local server,
    we have developed std. input forms for solving a range of problems as
    -vapor-liquid or liquid-liquid separator sizing/rating
    -PSV sizing/rating
    -blowdown simulation
    -pipeline sizing / rating
    -compressor simulation
    -other procedures are under development
    I think it should be possible to install the Prode Properties library on a web server,
    however that is not (at present) our case.
    thanks,
    it seems a interesting application,
    are you storing in a database (SQL) or Prode Properties files ?
  6. Re: Excel library for process calc's including distillation
    this thread interests me, too.
    Actually we have PRODE PROPERTIES on (3) stand alone computers but we plan to move to a network application.
  7. #317
    I have PRODE PROPERTIES 64 bits working with EXCEL 2010 and Windows 7,
    also I have MATLAB (working with PRODE PROPERTIES),
    when moving from 32 to 64 bit Windows 7 I decided to update all the software so I have not many problems to report,
    I would suggest the same to avoid conflicts (32 vs. 64 bit versions of the library)
  9. #318
    "when moving from 32 to 64 bit Windows 7 I decided to update all the software so I have not many problems to report"
    indeed, when possible, that is a good practice,
    unfortunately working with 32 and 64 bit applications I have to manage both 32 and 64 bits versions of Prode Properties :-(
  10. #319
    we have PRODE PROPERTIES 64 bits,
    according my tests the speed is about twice the 32 bits version.
  11. #320
    I have to size several PSV for two phase flow case,
    procedure is based on HEM (the isentropic nozzle model included in PRODE PROPERTIES),
    my question is about discharging piping,
    I have calculated (with PRODE PROPERTIES) the critical speed for gas+liquid in discharging line,
    my problem is that in discharging line I have values about 50% of calculated speed of sound, could that be a problem ?
    Should that mean that we have to redesign the piping ?
    Could you advise ?
  12. #321
    with those speeds and densities you may go into troubles,
    have you verified energy values in critical sections as elbows etc.?
    Std. practice is to keep match number in main header below 0.5
    but this is a general indication (must be verified for specific cases as said)
  13. #322
    thanks,
    could you suggest a criteria to calculate maximum stress in lines when a PSV discharges ?
    Is the criteria to limit match number in main header below 0.5 based on maximum allowable stress on piping ?
  14. Re: Excel library for process calc's including distillation
    mpor,
    perhaps you have noticed the answer by Carlo on another group, I paste here for interested readers
    while a value of 0.5 may be acceptable (that depends from several factors as density etc.)
    you may evaluate F on a determined section of piping as
    F = p*area + dens*area*v*v/g
    as you see there is a static component (p*area)
    and a dynamic component (dens*area*v*v/g)
    from this you can calculate the stress.
    To what said by Carlo I would add that API std. is a good source of information about this topic.
  16. #324
    thanks rense
    "perhaps you have noticed the answer by Carlo on another group, I paste here for interested readers
    To what said by Carlo I would add that API std. is a good source of information about this topic."
  1. Replies: 29
  2. Replies: 2
  3. Replies: 7
  4. Replies: 18
