Page 26 of 36 FirstFirst ... 16 24 25 26 27 28 ... LastLast
Results 301 to 312 of 423
  1. #301
    Re: Excel library for process calc's including distillation
    >I have a question about HEM and HNE models for PSV sizing/rating,
    >do these models work for non-critical flows ?
    >(I mean a flow where the maximum speed is below critical flow)
    >It may seem a stupid question but I have to size some PSV with
    >Pset = 5 Bar.a and Pdischarge (flare network, dynamic) = 2 Bar.a
    when PSV outlet pressure > Pin / 2
    flow can become subcritical, the method ISPF() in Prode Properties gives reasonable results also in this are within certain limits,
    you may find a discussion in this blog entry
    'http://www.egpet.net/vb/entries/82303-PSV-sizing-with-HEM-%28Homogeneous-Equilibrium-Model%29-limits-of-application'
    thanks Carlo,
    very useful comment !
    I have found a note about using the Constant Volume Flash operation of Prode Properties for estimating the initial condition in the vessel when PSV opens,
    could you provide some details?
    thanks Carlo,
    I have found a note about using the Constant Volume Flash operation for estimating the initial condition in the vessel when PSV opens,
  6. Re: Excel library for process calc's including distillation
    Thank you very much!
    Very useful!!!!
  7. #305
    >I have found a note about using the Constant Volume Flash operation for estimating the initial >condition in the vessel when PSV opens,
    you can calculate the fluid temperature and phase equilibria with a flash operation where you specify the volume and pressure,
    see this blog entry
    'http://www.egpet.net/vb/entries/82307-Calculate-fluid-temperature-and-phase-equilibria-when-a-PSV-opens'
  9. #306
    thanks Carlo,
    the procedure for calculating the conditions when the pressure safety valve (PSV) begins to discharge is useful to decide whether a specific depressurization system is required,
    that is a important point as per API requirements,
    does the procedure for simulating the depressurization system in Pro de Properties allow to specify the heat absorbed / exchanged by vessel ?
  10. #307
    cstaff,
    yes, the procedure to simulate the vessel depressurization in Prode Properties allows to specify the heat exchanged as well other details as mass etc.
    I will provide a short description in a new post.
  11. Re: Excel library for process calc's including distillation
    the procedure for vessel depressurization in Pr ode Properties calculates both fire case and blow down with specified amount of heat exchanged (i.e. with air)
  12. Re: Excel library for process calc's including distillation
    I have a old version,
    however, as said by others, the procedure appears to be capable to simulate both PSV and BDV operations.
  13. #310
    thanks all,
    I wish to simulate a fire case (Blowdown) with Prode Properties,
    actually we do this with a different software which is *very* expensive,
    hence our interest for this specific application.
  14. Re: Excel library for process calc's including distillation
    I see the point :-))
    actually we use Prode Properties in both small and large projects,
    Prode resides in our company server so that data is available to everyone working on a project,
    we have developed std. forms and procedures (in Excel) and Office.
  16. Re: Excel library for process calc's including distillation
    It's useful one. Thank you
  1. Replies: 29
  2. Replies: 2
  3. Replies: 7
  4. Replies: 18
