Page 24 of 89 FirstFirst ... 14 22 23 24 25 26 34 74 ... LastLast
Results 277 to 288 of 1065
Thread: ASTM Book Volume 2015
  1. #277
    Jun 2008
    Karachi, Pakistan
    Re: ASTM Book Volume 2015
    Dear Marty,
    First of all Thanks (English), Shukran (Arabic), Grazie (Italian), Spaciba (Russian), Shukria (Urdu), Thuadi Meherbani (Punjabi) in all the languages I know. Still I feel I cannot convey my gratitude.
    I hope you will like another way of saying it:
    Accept my thanks Marty
    That is from my Hearty
    Prior to this version of ASTM I had the 2004 version, that I not only used myself extensively but assisted and guided many of my colleagues in Design and Engineering. I believe from this collection the ASTMs on Coal/Environment/Water/Steel/Welding etc etc will be utilized almost immediately.
    As part of my work, I use Standards and other reference data regularly, and to do that it must be organized, indexed and categorised. The same need to be followed for this collection, as was done with the ASTM 2004. As the first step I have developed an index of ASTM section 15, that is attached herewith as xlxs file. More metadata will be added to it before it will be put to professional use.
    This index has been developed from the actual files names received from you, that would be reason or the gaps.
    My request is:
    Can I get a similar index as xlsx for the entire ASTM?
    I have removed the MacOS directories and files as much as I can, while a few are still refusing to be deleted. My query is considering them as duplicates of their windows counterparts, by removing them, will there be any files lost?
    Attached Files Attached Files
    Section 3 new 12-11-2015
    3.01 new
    E2218-15 Standard Test Method for Determining Forming Limit Curves
    E2248-15 Standard Test Method for Impact Testing of Miniaturized Charpy V-Notch Specimens
    E2298-15 Standard Test Method for Instrumented Impact Testing of Metallic Materials
    3.02 new
    G30-97(2015) Standard Practice for Making and Using U-Bend Stress-Corrosion Test Specimens
    G33-99(2015) Standard Practice for Recording Data from Atmospheric Corrosion Tests of Metallic-Coated Steel Specimens
    G35-98(2015) Standard Practice for Determining the Susceptibility of Stainless Steels and Related Nickel-Chromium-Iron Alloys to Stress-Corrosion *****ing in Polythionic Acids
    G40-15 Standard Terminology Relating to Wear and Erosion
    G50-10(2015) Standard Practice for Conducting Atmospheric Corrosion Tests on Metals
    G58-85(2015) Standard Practice for Preparation of Stress-Corrosion Test Specimens for Weldments
    G75-15 Standard Test Method for Determination of Slurry Abrasivity (Miller Number) and Slurry Abrasion Response of Materials (SAR Number)
    G92-86(2015) Standard Practice for Characterization of Atmospheric Test Sites
    G100-89(2015) Standard Test Method for Conducting Cyclic Galvanostaircase Polarization
    G101-04(2015) Standard Guide for Estimating the Atmospheric Corrosion Resistance of Low-Alloy Steels
    G106-89(2015) Standard Practice for Verification of Algorithm and Equipment for Electrochemical Impedance Measurements
    G107-95(2015) Standard Guide for Formats for Collection and Compilation of Corrosion Data for Metals for Computerized Database Input
    G108-94(2015) Standard Test Method for Electrochemical Reactivation (EPR) for Detecting Sensitization of AISI Type 304 and 304L Stainless Steels
    G112-92(2015) Standard Guide for Conducting Exfoliation Corrosion Tests in Aluminum Alloys
    G116-99(2015) Standard Practice for Conducting Wire-on-Bolt Test for Atmospheric Galvanic CorrosionG123-00(2015) Standard Test Method for Evaluating Stress-Corrosion *****ing of Stainless Alloys with Different Nickel Content in Boiling Acidified Sodium Chloride Solution
    G139-05(2015) Standard Test Method for Determining Stress-Corrosion *****ing Resistance of Heat-Treatable Aluminum Alloy Products Using Breaking Load Method
    .b1 pass: egpet.net
    Section 4 new 12/11/2015
    4.01 new
    C1278C1278M-07a(2015) Standard Specification for Fiber-Reinforced Gypsum Panel
    4.02 new
    C1580-15 Standard Test Method for Water-Soluble Sulfate in Soil
    C512C512M-15 Standard Test Method for Creep of Concrete in Compression
    C387C387M-15 Standard Specification for Packaged, Dry, Combined Materials for Concrete and High Strength Mortar
    4.04 new
    E2398E2398M-15a Standard Test Method for Water Capture and Media Retention of Geocomposite Drain Layers for Vegetative (Green) Roof Systems
    D6694D6694M-15 Standard Specification for Liquid-Applied Silicone Coating Used in Spray Polyurethane Foam Roofing Systems
    D6136D6136M-15 Standard Test Method for Kerosine Number of Unsaturated (Dry) Felt by Vacuum Method
    D5405D5405M-98(2015) Standard Test Method for Conducting Time-to-Failure (Creep-Rupture) Tests of Joints Fabricated from Nonbituminous Organic Roof Membrane Material
    D4637D4637M-15 Standard Specification for EPDM Sheet Used In Single-Ply Roof Membrane
    D4074D4074M-11(2015) Standard Test Method for Bitumen and Aggregate Content of Bitumen-Aggregate Mixtures From Roofing Samples
    D3423D3423M-15 Standard Practice for Application of Emulsified Coal-Tar Pitch (Mineral Colloid Type)
    4.05 new
    C1818-15 Standard Specification for Synthetic Fiber Reinforced Concrete Culvert, Storm Drain, and Sewer Pipe
    4.06 new
    C518-15 Standard Test Method for Steady-State Thermal Transmission Properties by Means of the Heat Flow Meter Apparatus
    C1321-15 Standard Practice for Installation and Use of Interior Radiation Control Coating Systems (IRCCS) in Building Construction
    C1710-15 Standard Guide for Installation of Flexible Closed Cell Preformed Insulation in Tube and Sheet Form
    C1729-15a Standard Specification for Aluminum Jacketing for Insulation
    C1729M-15 Standard Specification for Aluminum Jacketing for Insulation
    C1767-15 Standard Specification for Stainless Steel Jacketing for Insulation
    C1767M-15 Standard Specification for Stainless Steel Jacketing for Insulation
    C1785-15 Standard Test Method for Concentration of Pinhole Detections in Moisture Barriers on Metal Jacketing
    E336-15 Standard Test Method for Measurement of Airborne Sound Attenuation between Rooms in Buildings.pdf
    4.07 new
    C120C120M-15 Standard Test Methods of Flexure Testing of Slate (Breaking Load, Modulus of Rupture, Modulus of Elasticity)
    C217C217M-15a Standard Test Method for Weather Resistance of Slate
    C509-06(2015) Standard Specification for Elastomeric Cellular Preformed Gasket and Sealing Material
    E176-15ae1 Standard Terminology of Fire Standards
    E1537-15 Standard Test Method for Fire Testing of Upholstered Furniture
    E2061-15 Standard Guide for Fire Hazard Assessment of Rail Transportation Vehicles
    E2067-15 Standard Practice for Full-Scale Oxygen Consumption Calorimetry Fire Tests
    E2816-15a Standard Test Methods for Fire Resistive Metallic HVAC Duct Systems
    4.08 new
    D1241-15 Standard Specification for Materials for Soil-Aggregate Subbase, Base, and Surface Courses
    D5143-06(2015)e1 Standard Test Method for Analysis of Nitroaromatic and Nitramine Explosive in Soil by High Performance Liquid Chromatography
    D5473D5473M-15 Standard Test Method for (Analytical Procedure for) Analyzing the Effects of Partial Penetration of Control Well and Determining the Horizontal and Vertical Hydraulic Conductivity in a Nonleaky Confined Aquifer
    D5519-15 Standard Test Methods for Particle Size Analysis of Natural and Man-Made Riprap Materials
    D5716D5716M-15 Standard Test Method for Measuring the Rate of Well Discharge by Circular Orifice Weir
    D5785D5785M-15 Standard Test Method for (Analytical Procedure) for Determining Transmissivity of Confined Nonleaky Aquifers by Underdamped Well Response to Instantaneous Change in Head (Slug Test)
    4.09 new
    D6000D6000M-15e1 Standard Guide for Presentation of Water-Level Information from Groundwater Sites
    D6459-15 Standard Test Method for Determination of Rolled Erosion Control Product (RECP) Performance in Protecting Hillslopes from Rainfall-Induced Erosion
    D6884-03(2015)e1 Standard Practice for Installation of Articulating Concrete Block (ACB) Revetment Systems
    D7380-15 Standard Test Method for Soil Compaction Determination at Shallow Depths Using 5-lb (2.3 kg) Dynamic Cone Penetrometer
    4.10 new
    D2555-15 Standard Practice for Establishing Clear Wood Strength Values
    D4442-15 Standard Test Methods for Direct Moisture Content Measurement of Wood and Wood-Based Materials
    4.12 new
    E3035-15 Standard Classification for Facility Asset Component Tracking System (FACTS)
    F2462-05(2015) Standard Practice for Operation and Maintenance of Sewers with Optical Fiber Systems
    .b1 pass: egpet.net
  6. #280
    Sajid Ali Khan, the MAC os files can be deleted without any problem to the original files, they are used by Mac users only. Your xls file is interesting, but that is one of the reasons that I use Mac, I can have long names and just search them, not some extra directory. I downloaded these for my use first and just shared them for everyone else. I plan on slightly shortening some and reposting with new files added but do not plan on cutting the names short to PC needs, sorry, someone else can do that for others if they like. I know everyone can't do it but I strongly suggest if you have the option to purchase a MAC. Not to start an argument here but they are far superior. The problems are caused by the limitations of the ancient PC-DOS system.
  7. #281
    This is only a test,, active files 12/12/2015
    Volume 1.01 numbers and date only
    in zip, pass: egpet.net
  9. #282
    Volume 1.02 numbers and date only, active files 12/12/2015
  10. #283
    Volume 1.03 numbers and date only, active files 12/12/2015
  11. Re: ASTM Book Volume 2015
    Dear Marty,
    May you please kindly share these: ASTM STP 1526, ASTM STP 1546, ASTM STP 1539, ASTM STP 1461, ASTM STP 948, ASTM STP 969, ASTM STP 993, ASTM STP 1020, ASTM STP 1042 and ASTM STP 995V1&V2.
  12. #285
    Volume 1.04 numbers and date only, active files 12/12/2015
  13. #286
    Volume 1.05 numbers and date only, active files 12/12/2015
  14. Re: ASTM Book Volume 2015
    Dear Marty,
    Good morning. It is difficult to explain the feelings in words , as the amount of efforts you put in to clean and post such a large number of files. Really you are great.
    God bless you.
  16. #288
    STP 948 - Fractography of Modern Engineering Materials - Composites and Metals 1987
  1. ASTM D1250 - Volume 07 Tables 53A & 54A
    By el hassan in forum Laboratory Measurements
    Last Post: 02-12-2019, 02:05 PM
  2. ASTM Handbook Volume 3.02 and 3.03
    By id24_band@yahoo.com in forum Materials Science &Corrosion
    Last Post: 07-21-2017, 10:23 PM
  3. Astm a780 / a780m - 09(2015)
    By kavita_00 in forum Mechanical Engineering
    Last Post: 03-16-2016, 05:23 AM
  4. ASTM Volume 08.03 (D4097 , D3299)
    By Virgule in forum Mechanical Engineering
    Last Post: 02-16-2013, 06:00 PM
