Page 21 of 53 FirstFirst ... 11 19 20 21 22 23 31 ... LastLast
Results 241 to 252 of 626
Thread: Manual of Petroleum Measurement Standards
  1. #241
    Thank you very much!
  3. Thanks alot for providing me AGA report 7
  5. Hi gents
    Can someone provide MPMS chapter 11 vol VIII, tables 54A and 54B?
    Thanks in advance
  6. Good afternoon,
    I would kindly ask you to upload the below mentioned standards.
    Thanks in advance!
    RK
    Quote Originally Posted by Achmad Nur Eddin View Post
    API MPMS 11.2.1 ACTV 1/1/1984 (R 1996) Manual of Petroleum Measurement Standards Chapter 11.2.1 - Compressibility Factors for Hydrocarbons: 0-90 Degrees API Gravity Range
    API MPMS 11.2.1M ACTV 1/1/1984 (R 1996) Manual of Petroleum Measurement Standards Chapter 11.2.1M - Compressibility Factors for Hydrocarbons: 638-1074 Kilograms per Cubic Metre Range Erratum - February 1985;
    API MPMS 11.2.2 ADDENDUM ACTV 12/1/1994 (R 1997) Manual of Petroleum Measurement Standards Chapter 11 - Physical Properties Data Addendum to Section 2, Part 2 - Compressibility Factors for Hydrocarbons, Correlation of Vapor Pressure for Commercial Natural Gas Liquids First Edition; Errata 1996
    API MPMS 11.2.2 ACTV 10/1/1986 Manual of Petroleum Measurement Standards Chapter 11.2.2 - Compressibility Factors for Hydrocarbons: 0.350-0.637 Relative Density (60 Degrees F/ 60 Degrees F) and -50 Degrees F to 140 Degrees F Metering Temperature Second Edition; GPA 8286-86; Errata:June
    API MPMS 11.2.2M ACTV 1/1/1986 (R 1997) Manual of Petroleum Measurement Standards Chapter 11.2.2M - Compressibility Factors for Hydrocarbons: 350-637 Kilograms per Cubic Metre Density (15 Degrees C) and -46 Degrees C to 60 Degrees C Metering Temperature GPA 8286M-86; (R 1992)
    API MPMS 11.2.3 ACTV 1/1/1984 (R 1996) Manual of Petroleum Measurement Standards Chapter 11.2.3 - Water Calibration of Volumetric Provers
    API MPMS 11.2.3M ACTV 1/1/1984 (R 1996) Manual of Petroleum Measurement Standards Chapter 11.2.3M - Water Calibration of Volumetric Provers
    API MPMS COMP INAC 1/1/1984 Manual of Petroleum Measurement Standards Chapter 11.2.1 and 11.2.1M; Chapter 11.2.3 and 11.2.3M; Computer Tape Information and Documentation Erratum - October 1984
  7. Could anyone please sahre API Chapter 5.3
    Thnaks in advance
  9. #246
    mudassar587:
    Here you go --
  10. Thanks you very much Buddy.
    Could u please provide me API 5.2 and API Chapter 18.
    Thanking you in advance
  11. I need
    API MPMS 10.4 ACTV 12/1/1999 Manual of Petroleum Measurement Standards Chapter 10 - Sediment and Water Section 4 - Determination of Water and/or Sediment in Crude Oil by the Centrifuge Method (Field Procedure)
    If any one has please post it thanks
  12. #249
    Greetings from Colombia.
    Thank you much Achmad Nur Eddin.
    I invite you to create a Global Engineering Network. You can read about this project on the pdf in the beginning of the following page:
  13. Many thanks for MPMS 5.5
    Can you upload again the MPMS 5.2 server said not found.
    Thanks a lot
  14. Many thanks for MPMS 5.5
    Thanks a lot
    Dear Mr Shankarmathur,
    Sorry I never checked the remaining 2 items. Here are the rest :
    API MPMS 5.5 1st Ed 2002.pdf 545.22 KB
    API MPMS 5.2 2nd Ed 2002.pdf 636.97 KB
  16. Thanks you very much Buddy.
    Could u please reupload API MPMS 3.4 old link say no file found.
    API MPMS 3.5 1st Ed 1997.pdf 112.81 KB
    API MPMS 3.4 1st Ed 1995.pdf 131.95 KB
    API MPMS 3.6 1st Ed 2001.pdf 316.74 KB
    API MPMS 3.3 1st Ed 1996.pdf 119.33 KB
  1. Petroleum Measurement
    By HUGH12345 in forum Laboratory Measurements
    Last Post: 01-25-2015, 12:19 AM
  2. need "API manual of petroleum measurement standards"
    By hhlion in forum Petroleum Refining
    Last Post: 11-29-2013, 10:24 AM
  3. IP Petroleum Measurement Manual
    By bataraguru in forum Laboratory Measurements
    Last Post: 03-18-2011, 05:15 PM
  4. Can anyone please provide API Manual of petroleum standards chapter 5
    By shakeel_ahmed in forum Instrumentation & Control
    Last Post: 08-26-2009, 08:43 AM
