Nilam,
You can not use economiser it is something else.
It is Air Cooler. You are supposed to have a Hot stream inside tubes.
If your Air inlet temp is 30 deg C and out is 35 deg C.
Tube in what(u have not specified) but if tube out is less than 33 deg C. Then how can it be Air Cooler which is supposed to be used for cooling the other stream.
You can use A Cooler for:
say Cooling the Hot stream in tubes ( Say water from 90 to 50 deg C) or
Condensing a hot stream ( say ethanol at 78 deg C to 78 deg C no subcooling)
but you can not use it for say glycol ( 0 deg in to 20 deg C ) means heating using air
