Page 2 of 2 FirstFirst 1 2
Results 13 to 14 of 14
Thread: Pressure Equipment Directive
  1. Re: Pressure Equipment Directive
    thanks mariog
  3. Re: Pressure Equipment Directive
    Quote Originally Posted by lochandadhich View Post
    Thanks a lot dude...
    I have one question...
    We are supplying volume bottles where the design is as per ASME VIII Division 1 and Inspection and testing as per ASME IX.
    The client has asked that Radiography and MT shall be as per PED 94/97/EC and also the WPS and PQR shall be as per PED.
    What I know is, there is no specific guide line for RT/MT and WPS/PQR as per PED.
    As per Annexure 1, 3.1.3, PED says, the Personnel performing the NDT shall be approved by inspector or Third part.
    Also for welding, the joint efficiency is same as ASME.
    Can some one tell me if there is any particular requirement in PED for RT/MT, like we have in ASME 8 division 1.
    Best regards
    Lochan
    All requirements depend on the category of your vessel.
    Welding and NDT must be conform to your Code (ASME here).
    However, PED requires :
    - for pressure equipment in categories II, III and IV, operating procedures and personnel must be approved by a NoBo or a third-part recognized by a Member State.
    - for pressure equipment in categories III and IV, the personnel must be approved by a third-part recognized by a Member State.
    Moreover, for welding and welders qualifications, the third party must perform examinations and tests as set out in the appropriate harmonized standards or equivalent examinations and tests or must have them performed. It means that if you have ASME WPS and PQR, you must add additional examinations like in the harmonized standards.
    And finally, don't forget to hire a NoBo for PED assessment ! (Categories II to IV)
    see you,
    Pierre
  1. Looking for info about PED directive pressure test value
    By giorgino in forum Mechanical Engineering
    Last Post: 02-18-2014, 03:30 PM
  2. Pressure Equipment.
    By Mr Welder in forum Mechanical Engineering
    Last Post: 06-24-2011, 08:43 AM
  3. PED - European Pressure Directive
    By EJeng in forum Mechanical Engineering
    Last Post: 11-27-2009, 01:08 AM
  4. Pressure Equipment Directive EC 97/23
    By praphulla.phirke in forum Mechanical Engineering
    Last Post: 02-06-2009, 10:38 PM
