Page 2 of 2 FirstFirst 1 2
Results 13 to 21 of 21
Thread: Geosoft Oasis Montaj 8.3.1!!!!
  1. #13
    Re: Geosoft Oasis Montaj 8.3.1!!!!
    Thank you very much.
    I have already install and run. But don't work MAGMAP tools, coordinate system and some other. Maybe i don't understand installing process.
    Please help me, Thanks, you all
    Quote Originally Posted by Ulzii View Post
    After succesful install .. go to the main folder and find Oasismontaj.exe in my case it is
    in the folder C:\Program Files (x86)\Geosoft\bin
    .. create a shortcut for it.. then when you run oasis montaj by click the shortcut you will show that you
    are running oasis montaj in a standard version .. all the gx ext should be running .. hope this explanation helpful..
  5. Re: Geosoft Oasis Montaj 8.3.1!!!!
    Error message "The specified account already exist". Installation halted. How to overcome this?
  6. Re: Geosoft Oasis Montaj 8.3.1!!!!
    Quote Originally Posted by mnasir View Post
    I think you forgot about the Internet connection. All connections must be disabled before you start to install OM.
    I think now you need to clean your registry after the failed installation. Use one of reg cleaners (or manually - longer, but better). After you've deleted all OM paths and keys from your PC you may try to install it again. And also note that this soft can be updated up to 8.4.2 only because the greedy Ge*soft revoked the "license"( which you will install) starting from OM 8.5.
    Installation should be a little bit different on the various Wins (7,8,10 - may be you'll need to use command prompt to launch ***.exe) - it depends on the security policy applying in your company or your PC security settings.
    Also you'd better know that some antiviruses mark ***.exe as a virus, so you've to disable your antivirus software.
  7. Re: Geosoft Oasis Montaj 8.3.1!!!!
    Hi Aziq* I think I miss out the password to open the zip file* and the web has been disable* can you pm me the password for to unlock the zip? Thanks.
  9. #18
    Could you update the links please? Can't download.
  10. #19
    Thanks for the nice program
  11. #20
    please provide rar-password for OM883
  12. #21
    Hi.
    I'm wondering if people still has the link for oasis montaj? I want to apply job for UXO detection and want to familiarize myself with the software.
