Dear Mohamad,
Please share when you got it.
thanks in advance
Dear Mohamad,
thanks in advance
Dear Mohamad,
thanks in advance
ASME published print version of BPVC code -2015 from today onwards
as per ASME website
Thanks in advance
Please share it.
thanks in advance
share please'
please share it...
thanks in advvvv....
HI FRIENDS.
Summary of changes for the Boiler Pressure Vessel Code (BPVC) 2015 :
ENJOY- SHEMYY
Summary of Changes
Below is the summary of changes for the Boiler Pressure Vessel Code (BPVC) 2015
BPVC-I 2015 Edition Items
• BPV I; PRV and PARV Capacity Certification and Nameplate Stamping
• Section I, Oxide Growth - Ferritic High Temperature Headers
• Section I PW-36.3, Minimum Thickness For Weld Overlay or Weld Metal Buildup Material Assigned a P Number
• BPV I Intent Interpretation, PG-110(e)(2)
• ASME Code Section I, A-70 - Validity of the statement "The vessel does not qualify for the exception in PG-32 and therefore must comply with PG-26, PG-27, and PG-33."
• Section I, Table A-360, ASTM E 125, E 186, E 280 and E 446
• Section I, P-3 & P-6 Forms
• BPV I Addition of Part PFE - Requirements for Feedwater Economizers
• Section I, PW-43
• Section I, PG-52.6 Nomenclature
• Section I, Parts Fabrication Certificate Program
• Section I Adoption of the ASME CA-1 Standard
• Section I, Appendix A-250.2.3, Revise to Clarify Thickness to be Used For Acceptance Criteria.
• Revision to BPV Section I, PG-26 adding WSRFs for Nickel Base Alloys
• Section I PFT-20.3, Attachment of Furnaces by full penetration welds.
• Section I, Part PL Requirements for Locomotive Boilers
• Construction of box headers and waterlegs
• Section I, Revise Table PG-19 and Table PW-39 to Address Rules for Use of Alloy 800
• Incorporation of Code Case 2328-1 in Section I.
• Clarification of the term Nozzle Diameter [ Inside versus Outside ]
• Section I, PG-26
• Incorporation of Code Case 2359-2, Ni-25Cr-9.5Fe-2.1Al Alloy (UNS N06025)
• Proposed Revisions to PHRSG-3.3
• PG-31.2, Nomenclature For Term "S"
• PG-31.3
• Section I PEB-8.3 Intent Interpretation
• Section I - PL-1 Manufacturers Data Report Form for Locomotive Boilers
• Head to Cylindrical Shell Attachment Details
• Section I, PW-39, Table PW-39-1, General Note (a)(2)(a), Clarify CE Limitations for Weld Basemetals
• Section I, Specification SA-202
• Revise Table PW-39-1, note (a)(1) , Exclude Welded Stays from 200 F Preheat
• Section I, Editorial Changes Existing Table PW-39-9 and Proposed Table PW-39-12
• Section I, Table PG-19 Material 310HCbN
• Revise the definition of terms "t" and "tn", in Section I, PG-33.3
• Section I, Table A-360 Reference to B16.5-2013
• Section I, Table A-360 Reference to B16.34-2013
• Section I, Table A-360 Reference to B16.9-2012
• Section I, Revision to PG-9.3 and Intent interpretation
• Section I, Clarify Requirements for Demonstration versus Qualification of NDE Procedures
• Section I, Review of PG-112 Guidance on use of Data Report Forms
• Section I, PG-48.1 and Figure A-8(g) Section I, Table A-356 Line 19
• Section I, Review of PG-28 and Stiffening Rings
• Section I, Replace A-125 with A-317
• Section I, Revisions to PG-29
• Section I, PG-60.1.2 - Isolation Valves for externally mounted water level sensing devices
• BPV I Preamble, Section I, Addition of Solar Heated Steam Generator
• Section I, Table A-360 Reference to B1.20.1
• Section I, Table A-360 Reference to B16.15
• Section I, Table A-360 Reference to B16.20
• Section I, Table A-360 Reference to B16.25
• Section I, Table A-360 Reference to QAI-1
• Section I, Table A-360 Reference to B18.1.2
• Section I, Table A-360 Reference to ASTM E8/E8M Tension Testing of Metallic Materials
• Section I Editorial, PW-44.1 and Endnote 8
BPVC-IIA 2015 Edition Items
• Section II, Parts A and D; Adoption of European Standard EN 10222-2:1999 as ASME SA/EN 10222-2
• BPV II Section II, Part A; Adoption of ASTM A480/A480M-13b as ASME SA-480/SA-480M
• BPV II SG FS Section II, Part A; Adoption of ASTM A671/A671M-14 as ASME SA-671/SA-671M
• BPV II SG FS Section II, Part A; Adoption of ASTM A484/A484M-13a as ASME SA-484/SA-484M
• BPV II SG FS Section II, Part A; Adoption of ASTM A479/A479M-13b as ASME SA-479/SA-479M
• BPV II SG FS Section II, Part A; Adoption of ASTM A 312/A 312M-13b as ASME SA-312/SA-312M
• BPV II SG FS Section II, Part A; Adoption of ASTM A 450/A 450M-04a as ASME SA-450/SA-450M
• BPV II SG FS Section II, Part A; Adoption of ASTM Specification A249/A249M-14 as ASME SA- 249/SA-249M
• BPV II SG FS Section II, Part A; Adoption of ASTM A688/A688M-12 as ASME SA-688/SA-688M
• BPV II SG FS Section II, Part A; Adoption of ASTM A803/A803M-12 as ASME SA-803/SA-803M
• II SG FS Section II, Part A; Adoption of ASTM A193/A193M-12b
• BPV II SG FS Section II, Part A; Adoption of ASTM A194/A194M-12
• BPV II SG FS Section II, Part A; Adoption of ASTM Specification A307-10 as ASME SA-307
• BPV II SG FS Section II, Part A; Adoption of ASTM A320/A320M-11a
• BPV II SG FS Section II, Part A; Adoption of ASTM A325-10 as ASME SA-325
• BPV II SG FS Section II, Part A; Adoption of ASTM A354-11 as ASME SA-354
• BPV II SG FS Section II, Part A; Adoption of ASTM A437/A437M-12 as ASME SA-437/SA-437M
• BPV II SG FS Section II, Part A; Adoption of ASTM A449-10 as ASME SA-449
• BPV II SG FS Section II, Part A; Adoption of ASTM A453/A453M-12 as ASME SA-453/SA-453M
• BPV II SG FS Section II, Part A; Adoption of ASTM A540/A540M-11 as ASME SA-540/SA-540M
• BPV II SG FS Section II, Part A; Adoption of ASME SA-736/SA-736M-12 as ASME SA-736/SA-736M
• BPV II SG FS Section II, Part A; Adoption of ASTM A832/A832M-10 as ASME SA-832/SA-832M
• BPV II SG FS Section II, Part A; Adoption of ASTM A841/A841M-13 as ASME SA-841/SA-841M
• BPV II SG FS Section II, Part A; Adoption of ASTM A358/A358M-14a as ASME SA-358/SA-358M
• BPV II SG FS Section II, Part A; Adoption of ASTM A1016/A1016M-14 as ASME SA-1016/SA- 1016M
• BPV II SG FS Section II, Part A; Adoption of ASTM A672/A672M-14 as ASME SA-672/SA-672M
• BPV II SG FS Section II, Part A (2013 Edition), Revision to Table A1.1 of SA-480 and Accompanying Intent Interpretation
• BPV II SG SFA Section II, Part D; Increase the Maximum Thickness of SA-841 Plates for SC VIII, Divisions 1, 2, and 3 Code Construction
• BPV II SG IMS Section II, Parts A and B, Nonmandatory Appendix A Sources of Standards
• BPV II SG FS Section II, Part A; Revision of SA-213 Para. 6.2.2 to include S30432
• BPV II SG FS Section II, Part A (1998 Edition); Intent Interpretation of SA-36/SA-36M Product Analysis Requirement
• BPV II SG FS Section II, Part A; Adoption of ASTM A31-14 as ASME SA-31
BPVC-IIB 2015 Edition Items
• BPV II SG NFA Section II, Part B; Adoption of ASTM B366-10a as ASME SB-366
• BPV II SG NFA Section II, Part B; Adoption of ASTM B248-12 as ASME SB-248
• BPV II SG NFA Section II, Part B; Editorial Correction to SB-148 Para. 5.1 Heat Treatment Temperature
• BPV II SG NFA Section II, Part B; Adoption of ASTM B861-10 and ASME SB-861
• BPV II SG NFA Section II, Part B; Adoption of ASTM B249/B249M-12 as ASME SB-249/SB-249
• BPV II SG NFA Section II, Part B; Adoption of ASTM B622-10 as ASME SB-622
• BPV II SG NFA Section II, Part B; Adoption of ASTM B626-10e1 as ASME SB-626
• BPV II SG NFA Section II, Part B; Adoption of ASTM B462-10e1 as ASME SB-462
• BPV II SG NFA Section II, Part B; Adoption of ASTM B564-11 as ASME SB-564
• BPV II SG NFA Section II, Part B; Adoption of ASTM B619-10e1 as ASME SB-619
• BPV II SG NFA Section II, Part B; Adoption of ASTM B363-14 as ASME SB-363
• BPV II SG NFA Section II, Part B; Adoption of ASTM B862-13a as ASME SB-862
• BPV II SG NFA Section II, Part B; Revision to References in SB-395/SB-395M
BPVC-IIC 2015 Edition Items
• BPV IX Section II, Part C, Adoption of AWS A5.16/A5.16M:2013 as SFA-5.16/SFA-5.16M
• BPV IX Section II, Part C, Adoption of AWS A5.11/A5.11M:2010 as SFA-5.11/SFA-5.11M
• BPV IX Section II, Part C, Adoption of AWS A5.34/A5.34M:2013 as SFA-5.34/SFA-5.34M
• BPV IX Section II, Part C, Adoption of AWS A5.01/A5.01M:2013 as SFA-5.01/SFA-5.01M
• BPV IX Section II, Part C, Adoption of AWS A5.1/A5.1M:2012 as SFA-5.1/SFA-5.1M
• BPV IX Section II, Part C, Adoption of AWS A5.4/A5.4M:2012 as SFA-5.4/SFA-5.4M
• BPV IX Section II, Part C, Adoption of AWS A5.9/A5.9M:2012 as SFA-5.9/SFA-5.9M
• BPV IX Section II, Part C, Adoption of AWS A5.22/A5.22M:2012 as SFA-5.22/SFA-5.22M
• BPV IX Section II, Part C, Adoption of AWS A5.5/A5.5M:2014 as SFA-5.5/SFA-5.5M
BPVC-IID-C 2015 Edition Items
• Section II, Part D; Incorporation of Code Case 2418-1
• Section II, Part D; Incorporation of Code Case 2295-3 into Table 5A.
• Section II, Part D; Revision to Table 4; and to Appendix 2 Para. 2-130 and Table 2-100(c).
• Section II, Part D (US Customary and Metric): Revision to Tables 2B, U, and Y-1 for SB-167 UNS N06690
• Section II, Part D; Incorporation of Code Case 2359-2, Ni-25Cr-9.5Fe-2.1Al Alloy (UNS N06025)
• Section II, Part D; Revise Appendix 5 to Create a New II-D Paragraph, to Address Requirements for welding Data for New Base Materials.
• Section II, Part D; Incorporation of Code Case 2328-1
• Section II, Part D; Replacement of N08904 SB Specifications with SA Specifications in Table 1B
• Section II, Part D; Revision to SA/EN 10222-2 Stress Lines
• Section II, Part D; TS/YS Ratio Criteria for Applying the 90% Yield Criterion in Section II, Part D Tables 1A, 1B, 2A, 2B, 5A, and 5B
• Section II, Part D; Editorial Revision to Correct SC VIII-2 References in Notes G11, G12, and H6 of Table 5A
• Section II, Part D; Addition of Ferrous Bolting
• Section II, Part D; Re-evaluate the Cu-Si Alloy Trend Curves and Update Section II Part D Tables
• Section II, Part D; Deletion of SB-283 TQ50 Stress Lines from Table 1B
• BPV II SG Physical Properties Section II, Part D; Correction of Footnotes in Table TCD
• Section II, Part D; Develop Table U and Y-1 Stress Values for Alloys A95052, A95083, A95086
• BPV II Section II, Part D, Revision to Appendix 5, 5-800
• Section II, Part D; Correction to Table 3 Bolting Stress Values for Cu-Si Alloys
• Section II, Part D; Addition of SA-336/SA-336M F91 for SC VIII-2 use up to 1200ºF (649ºC) in Table 5A
➡BPVC-IID-M 2015 Edition Items
• II, Part D; Incorporation of Code Case 2418-1
• Section II, Part D, Revision to Appendix 5
• Section II, Part D; Addition of Ferrous Bolting Yield Strength Values
• Section II, Part D; Increase the Maximum Thickness of SA-841 Plates for SC VIII, Divisions 1, 2, and 3 Code Construction
• Section II, Part D (Metric); Addition of Time Dependent Note to Table 1B
• Section II, Part D; Correction of Footnotes in Table TCD
• Section II, Part D; Addition of SA-336/SA-336M F91 for SC VIII-2 use up to 1200ºF (649ºC) in Table 5A 14-2071
BPVC-III NB 2015 Edition Items
• Stress Indices for Branch Connections for r/R < or = 0.5 15-10
• Editorial Revision to NB-3112.2 (b), NG-3112.2 (a), and NH-3112.2 (a) to replace "Subsection" with "Article" and "Centigrade" with "Celsius".
• NB-3653.6 Meaning of moment term in Equation 13
• BPV III Incorporate the technical content of essential portions of BPV Section III Article NB hopper diagram notes into the body of Code
• Definitions of Local Primary Membrane Stress Intensity and Local Thin Areas
• BPV III Editorial Revisions to ASME BPV III NB-,NC- and ND-3600
• ASME BPV III, Section III changes to implement revised Bolting Sm values
• NB-3224.3 and Figure NB-3224-1 and methods to calculate collapse load
• Incorporation of acceptance of ASNT SNT-TC-1A 2011 into Section III.
• BPV-III-NB, NB-3222.2 "Primary Plus Secondary Stress Intensity (Range)"
• BPV III Section III updated Design by Analysis rules for reversing Dynamic Loads
• BPVC, Section III, Division 1, Organization of Section III
• BPV III Table NB-3681(a)-1, Stress Indices for straight pipe: Proposed Revision to Table NB- 3681(a)-1
• Clarification of Sm, Sh and Sy Temperature in NB/NC/ND-3650
• Pipe Bends in NB/NC/ND-3642.1
• Clarification of ME Definition in NB/NC/ND
• BPV Section III, DIvision 1, NB-3226. Part 1: The intent inquiry with proposed reply. Part 2. The proposed revision to NB-3226.
• **INTENT INTERPRETATION** ASME BPVC, Section III, Division 1, NB-2126.1(e) Fin Tube visual examination
• Relocate reference of applicable Edition for PTC-25 from NB/NC/ND/NE-7000 to Table NCA- 7100-2, Update PTC-25 reference year
BPVC-III NC 2015 Edition Items
• Editorial Revisions to ASME BPV III NB-, NC- and ND-3600
• Revision to NC/ND-3654.2(a) and NC/ND-3655(a)(2)
• BPV Code Section III, Division 1, Subsections NC and ND Design rules for nuclear components; socket welded end and nonwelded end valves; instrument, control, and sampling line valves NPS 1 (DN 25) and smaller
• Correct Metrication Errors in NC/ND 3900
• Editorial Change-Reference to NC-1150 in NC-3432.1(c) 15-10
• BPVC Section III, NC-1120 "Temperature Limits"; ND-1120 "Temperature Limits"; NE-1120 "Temperature Limits"
➡BPVC-III ND 2015 Edition Items
• Figure ND-3436(c)-1 remains, however the subparagraph (c) has been deleted.
• Editorial corrections to ND and NE
• Editorial corrections to ND-2360, NE-4122, NG-3222, and WC-2150.
BPVC-III NE 2015 Edition Items
âž¡• Removal of Sm1 from NE-3000 to be replaced by Sm. Other minor revisions to NE-3000 resulting from this change are also proposed.
➡BPVC-III NF 2015 Edition Items
• Section III; Subsection NF - Incorporation of Code Cases N-71 and N-249 into new Appendix NF-I
• BPV III NRC Regulatory Guide1.124, "Service Limits and Loading Combinations for Class 1 Linear- Type Supports", Revision 2 was issued in February 2007 and presented regulatory positions on design of Linear Supports.
• Appropriate revisions to subarticle NF-3300 and Appendix F are proposed.
• BPV III For pipe clamps supporting vertical loads, current Code words need to be clarified to address applying loads on rigid rod supports.
• Subsubparagraph NF-3321.1(a)
• ASME Section III Div.1, NF-1132(d) 1987 Addenda to the 2013 Edition. Base Plates furnished integral with a Component or Pipe support fabricated in a shop by an NS Certificate Holder.
• Section III Subsection NF Jurisdictional Boundary for baseplates.
• Eliminate alternative way for determining value for Sy when material is not listed in Section II Part D Table Y-1.
➡BPVC-III NG 2015 Edition Items
• Editorial Revision to NB-3112.2 (b), NG-3112.2 (a), and NH-3112.2 (a) to replace "Subsection" with Article" and "Centigrade" with "Celsius".
➡BPVC-III NH 2015 Edition Items
• ASME BPV Code, Section III, Division 1, Subsection NH
➡BPVC-III-2 2015 Edition Items
• BPV III Div 2 Section III, Div 2 Table of Contents, CC-2310, CC-3532.1.2, CC-3533, CC-4300, and CC-5300.
• Code Revision to add detailed code language for material, design, testing and inspection of mechanically anchored headed deformed bars in tension for reinforcing steel systems.
• Revisions to Section III Division 2 CC-2200 and Division 1&2 NCA-Table-7100-3 for the purpose of improving Long-Term Durability of Concrete.
• BPV III Div 2 Section III, Div. 2, Paragraphs CC-2333.1
• Reinforcing Bar Intended for Welding, and D2-VIII-1430, Carbon Equivalent Computation and Preheat and Interpass Requirements, and TABLE D2-VIII-1430-1, Minimum Preheat and Interpass Requirements
• BPV III Incorporation of acceptance of ASNT SNT-TC-1A 2011 into Section III.
• BPV III Div 2 BPVC III, Division 1, Table NCA 7100-3 BPVC III, Division 2, Table CC-2442-1
• BPV III Div 2 14-930 BPVC Section III, Division 2, CC-3521.1.1
• BPV III Resolve negative received from ACI-TAC review of Record 12-1124 by revising Section III, Div 2 CC-2231.3(a)
• Moving the term "Fabricator" from the 2013 Edition ASME Section III, Division 2, MANDATORY APPENDIX D2-II, GLOSSARY OF TERMS AND NOMENCLATURE, to NCA-9200.
• BPV III Div 2 BPVC Section III, Division 2, CC-2131.4 Personnel Qualification
• Revisions to CC-2000, CC-4000 & CC-5000 dealing with prestressing materials and post- tensioning activities.
• Revisions to Table CC-5200-1 in order to correct and clarify requirements 13-449
• BPV III Div 2 14-1629 BPV III, Division 2, CC-5536 Leak Testing
• BPV III Div 2 14-2153 BPVC, Section III, Division 2, CC-4333.4
• BPV III BPV III-2 Editorial Items in CC-2611(a)(2), CC-2612.1.1(b), CC-2613(d), CC-4632.4, CC- 3534.1(a) and Article D2-II-1000.
• BPV-III, Div. 2 Revision to Table CC-5200-1 dealing with Minimum Testing Frequencies for Concrete Constituents and Concrete..
• Revision to BPV III, Division 2, Table CC-2231.7.1-1 and Division 1, Table NCA-7100-3
➡BPVC-III-3 2015 Edition Items
• Section III, Div. 3, WB-3000
• BPVC, Section III, Division 1, Organization ofSection III
• Replace weight limts in WB-3700 and also revise WC-3700 to reflect energy limited definition
• Section III, Division 3, WB-3000
• ASME BPV Code, Section III, Division 3
• BPV Code, Section III, Division 3, Subsection WC-3000
➡BPVC-III-5 2015 Edition Items
• Section III, Division 5, Subsection HB, Subpart B, Nonmandatory Appendix HBB-Y: Guidelines for Design Data Needs of New Materials
• ASME BPV Code, Section III, Division 5, Subsection HG, Subpart B
• ASME BPV Code, Section III, Division 5, Subsection HC, Subpart B
• Technical and Editorial Changes - ASME BPV Code, Section III, Division 5
• Corrections to BPV-III Div 5 HHA.
➡BPVC-III-A 2015 Edition Items
• Update Section III Appendix III to reference Section II Part D Appendices 1 and 2
• BPV Code, Section III, Division 1, Code Case N-62-7; BPV Code, Section III, Appendices
• Change to F-1440 Core Support Structures
• BPV III Appendix F-1334.5 does not provide a correct definition of allowable Level D stress for Linear Supports in Equation (21) of NF-3322.1(e)(1).
• BPV III Section III Appendix XI Table XI-3221.1-1 and Appendix E Table E-1210-1 --- replacement of asbestos material with mineral fiber.
• ASME BPV Code, Section III Appendices, Appendix VI Review.
• Appendix W-2000 update
• BPV III App W-4000 Summary of Other Damage Mechanisms
• BPV III W-3000 Summary of Embrittlement Damage Mecanisms
• Revision to ASME BPV III, Non mandatory Appendix W Article W-1000
• Appendix Review - Nonmandatory Appendix R
• Appendix Review - Mandatory Appendix XXI
• Appendix Review - Nonmandatory Appendix D
• Appendix Review - NonMandatory Appendix M
• BPV III BPV Code, Section III, Appendices, Appendix XXIII
• III BPV Code, Section III, Appendix XXIII, Table B6
• Deletion of duplicated tables in Appendix E
• Incorporate Code Case N-755 into Section III
➡BPVC-III-NCA 2015 Edition Items
• Revise NCA-3855.5(a)(3)(-d) to require on-site verification of compliance with the supplier's identification and traceability procedures at a frequency commensurate with the schedule of production or procurement, but at least once triennially.
• BPV III Section III, Division 1 Paragraph NCA-8322. Core Support Strucuture N Certification At Field sites. The proposal file consists of two parts: Part 1: The intent inquiry with proposed reply. Part 2: The proposed revision to NCA-8322.
• Clarify application of NCA-1140(a) (2)
• BPV III BPV Code Section III, Division 1, Subsections NC and ND Design rules for nuclear components; socket welded end and nonwelded end valves; instrument, control, and sampling line valves NPS 1 (DN 25) and smaller
• III Div 2 BPVC III, Division 1, Table NCA 7100-3 BPVC III, Division 2, Table CC-2442-1
• Revise NCA-3841
• ASME BPVC Section III, Division 1, NCA-3920: Supply of Nonmetallic Material
• ASME BPVC Section III, Division 1, NCA-3970: Supply of Polyethylene Material
• ASME BPVC Section III, Division1, NCA-9200 and NCA-1282 (1998 Edition, 1999 Addenda, and later editions and Addenda through the 2013 Edition)
• Define the Audit frequency for approval of suppliers in NCA-3855.3 (b)(1)
• BPV III Section III, Division 1, NCA-3862.1 (b) (2010 Edition and 2011 a Addenda) Certification requirements for source material for welding material
• BPV III Div 2 Editorial revisions for BPV III Division 2 references listed in NCA Table NCA 7100-3.
• Revision of Table NCA-7100-1 to include previously approved editions of Dimensional Standards
• BPV Section III, Division 1, NCA-8151; Field Operations
• **INTENT INTERPRETATION** ASME BPVC Seciton III NB-6114.2, Edition 1998, Addenda 2000 and NCA-8322 Edition 2010, Addenda 2011
• NCA-5121(a) AIA designation or acceptance by a state of the United States or provice of Canada. Certified verse Accredited.
• BPV III Div 2 BPV III Division 2: Editorial revisions and updates to references listed in NCA Table NCA 7100-3.
• ASME BPV Code, Section III, Division 1, Subsection NCA
• 14-1444
➡BPVC-IV 2015 Edition Items
• BPV IV - Incorportation of Code Cases 2604 and 2469-1; Add pnuematic testing requirements in Section IV
• BPV IV Addition of SA/CSA-G40.21 Grades 44W and 50W to Section IV.
• BPV IV - Review of Table HF-300.2
• Section IV - Mandatory Appendix 2
• BPV IV Section IV; Parts Fabrication Certificate Program
• BPV IV 13-479 Section IV - HW-712 Furnace Attachments
• BPV IV 13-1949 Section IV - Endnote 16 Revision
• BPV IV 13-1989 Section IV - HG-401.1, Safety Valve Sizing
• BPV IV Section IV - Manufacturers with multiple locations
• BPV IV Section IV - Revisions to Table HF-300.2 and Table 300.2M to permit brazing Forging brass (SB283 UNS C37700).
• BPV IV Section IV - New Non-mandatory Appendix A
• BPV IV Section IV - Incorporation of CC 2583 and Annulment six months after publication
• BPV IV Section IV - Incorporation of CC 2614 and Annulment six months after publication of incorporation
• Section IV - Code Case 2800 Incorporation
• BPV IV Section IV - Incorporation of Case 2615 and Annulment six months after incorporation
• Section IV - Revision to Table HF-300.2 and HF-300.2M
• Section IV - HG-403 Heating Surface
• Section IV - HG-307.5 Electric Immersion
• Heating Element Support Plates - Intent Interp + Code Revision
• Section IV - HG-530 Marking of Boilers
• Section IV - Revision to HF-201
• Section IV - Proposed Revision to New Nonmandatory Appendix A100
• Section IV - Incorporation of Code Case 2654-1
• BPV IV - Traceability of Multi-page Data Report Forms
• BPV IV - Mandatory Appendix 2
• Section IV - REVISION - Deletion of specific references to II-D, Appendix A, Metallurgical Phenomena - HF-207
• BPV IV HLW-431.6 Internally Threaded Fittings Attached by Resistance Welding
➡BPVC-V 2015 Edition Items
• BPV V 13-536 Section V: Review Article 13
• Section V: Glossary of Terms
• Section V, Article 6: Define What Steps in the Penetrant Process Are Required to Have Minimum and Maximum Time Limits and Rewrite Requirements for Hydrophilic Emulsifiers to Reflect Current Practice. Revise T-662 to Establish a Maximum Dwell Time Limit and Also Prevent the Penetrant from Drying During the Dwell Time.
• Section V: Article 4; New Paragraph T-462.7 and Nonmandatory Appendix P with accompanying Definition.
• Section V: Definition of "Examination"
• Section V: Adopt E999-10, Standard Guide for Controlling the Quality of Industrial Radiographic Film Processing
• Section V: Evaluate APR Technology
• Section V: Adoption of New Article 18 on Guided Wave UT
• Section V: ASTM E750-10 Standard Practice for Characterizing Acoustic Emission Instrumentation
• Section V: ASTM E1067/E1067M-11 Standard Practice for Acoustic Emission Examination of Fiberglass reinforced Plastic Resin (FRP) Tanks/Vessels
• Section V: ASTM E1118/E1118M-11 Standard Practice for Acoustic Emission Examination of Reinforced Thermosetting Resin Pipe (RTRP)
• V Section V: ASTM E1139-12 Standard Practice for Continuous Monitoring of Acoustic Emission from Metal Pressure Boundaries
• Section V: Revisions to Article 8, Mandatory Appendix VIII Eddy Current Examination of Nonmagnetic Heat Exchanger Tubing
• Section V: Article 4; New Nonmandatory Appendix Q; Alternate Straight Beam Calibration Block Examples
• V Section V: Adopt ASTM E1647 - 09, Standard Practice for Determining Contrast Sensitivity in radioscopy, for update of SE-1647
• Section V:Article 7; T-762, Yoke Technique Requirements
• Section V: Article 4; T-471.4.1 Scanning Sensitivity and recording data.
• Section V: Article 1, T-120 General; Provide an Appendix II Defining Minimum Training and Experience Requirements for Radiographic and Ultrasonic Methods and Their Techniques
• Section V: Review of ASTM A435 / A435M - 90(2012) Standard Specification for Straight-Beam Ultrasonic Examination of Steel Plates for Adoption as SA-435
• V Section V: Article 4; Mandatory Appendices VII and VIII
• Section V: Review of ASTM A745 / A745M - 12 Standard Practice for Ultrasonic Examination of Austenitic Steel Forgings for Adoption as SA 745
• Section V: Review ASTM D129 - 11 Standard Test Method for Sulfur in Petroleum Products (General High Pressure Decomposition Device Method) for Adoption as SD 129
• Section V: Review ASTM D516 - 11 Standard Test Method for Sulfate Ion in Water for Adoption as SD 516
• Section V: Review ASTM D808 â 11 Standard Test Method for Chlorine in New and Used Petroleum Products (High Pressure Decomposition Device Method) for Adoption as SD 808
• Section V: Review ASTM E165 / E165M - 12 Standard Practice for Liquid Penetrant Examination for General Industry for Adoption as SE 165
• Section V: Review ASTM E2096 / E2096M - 10 Standard Practice for In Situ Examination of Ferromagnetic Heat-Exchanger Tubes Using Remote Field Testing for Adoption as SE2096
• Section V: Mandatory Appendix to Article 4 for the Examination of HDPE
• 13-1355
• Section V: Review of ASTM E650 / E650M - 12 Standard Guide for Mounting Piezoelectric Acoustic Emission Sensors for Adoption as SE 650
• Section V: Article 6; Documentation Requirements
• Section V: Article 7; Documentation Requirements
• Section V: Review the Use of the Term "Manufacturer" in Section V
• Section V: Article 4; Revision to Mandatory Appendix II-440
• Section V: Consistent Use of the Term "Through Wall" In All Articles of Section V
• Section V: Review of ASTM E2491 - 13 Standard Guide for Evaluating Performance Characteristics of Phased-Array Ultrasonic Testing Instruments and Systems
• V Section V: Revision of Article 2; Mandatory Appendix VI 14-6
• Section V: Revision of Article 12; Change to T-1224.1
• Section V: Image Brightness Variation Requirements
• Section V: Revision of T-224
• Section V: Article 4, IX-435.4; Weld Joint Configuration and TOFD
• Section V: Review of ASTM A577 / A577M - 90(2012) Standard Specification for Ultrasonic Angle-Beam Examination of Steel Plates for Adoption as SA-577
• Section V: Review of ASTM A578 / A578M - 07 (2012 Standard Specification for Straight-Beam Ultrasonic Examination of Rolled Steel Plates for Special Applications for Adoption as SA-578
• Section V: Review of ASTM A609 / A609M - 12 Standard Practice for Castings, Carbon, Low-Alloy, and artensitic Stainless Steel, Ultrasonic Examination Thereof for Adoption as SA-609
• Section V: Revision of Article 2, Mandatory Appendix V, Definition of "Radiograph"
• Section V: Article 8 Mandatory Appendix; VIII-810 Revision of the Term Nonmagnetic to Nonferromagnetic.
• Section V: Article 13; Revise T-1311
• Section V: Revision of Article 2, Appendices VIII & IX; Paragraphs VIII-287 and IX-287 on Measuring Scale
• Section V: Article 4, Figure T-434.3-1; Revision to the General Notes
➡BPVC-VIII-1 2015 Edition Items
• Section VIII, Division 1; UG-93(d)(3)
• Section VIII, Division 1; UNF-79
• Section VIII, Division 1; U-1(g)(1), UG-116, UG-120 13-487
• Section VIII, Division 1; Incorporation of Code Case 2244-2
• Section VIII, Division 1; Incorporation of Code Case 2401
• Section VIII, Divisions1 and 2; Incorporation of Code Case 2637 for UNS S32205 Material
• Section VIII, Division 1; UG-40(e) Section VIII, Division 2, 4.5.2
• Section VIII, Division 1; Revision to paragraph UG-136(d)(2), UG-137(d)(2), and UG-38(d)(2) Hydrostatic Pressure Test
• Section VIII, Division 1; UW-3(a) and UW-11(a) and Section VIII, Division 2; Table 4.2.1 and Table 7.2
• Section VIII, Divisions 1 and 2; PWHT Exemptions in Section VIII - NPS 4 Limitation
• Section VIII-1, Incorporation of CC 2367
• Section VIII, Division 1; Reassignment of UNS N08904 from SB-674 to SA-249
• Section VIII, Division 1; UG-129 and UG-131 Capacity Certification
• Section VIII, Division 2; Paragraph 3.11.2.2 (b) Section VIII, Division 1; Paragraph UCS-66(f)
• Section VIII, Division 1: UG-37(g) and (h); Section VIII, Division 2: 4.5.3.2(d)
• Section VIII, Division 1; Part UCD
• Section VIII, Division 1; Paragraph UG-45 Allowances for Threading
• Section VIII, Division 1; UW-12-(d) - Seamless Vessel Section Joint Efficiency
• Section VIII, Division 1: UW-27(a); & Section VIII, Division 2: 6.2.1.1 Hybrid Welding Processes
• Section VIII, Divisions 1 and 2; Incorporation of EN 10028-2:2003 Grade 10CrMo9-10
• Section VIII, Division 1; Fig. UW-21 - Weld Size Requirements
• Section VIII, Division 1; Code Case 2560
• Section VIII, Division 1; Appendix S-Test Pressure
• Section VIII, Division 1; UHT-6(b)(2), Division 2, 3.11.3.3(c)
• Section VIII, Division 1; UG-4(d)
• Section VIII, Division 1; U-2(b) & U-2(e); Clarifying Inspector Responsibility for Review of Calculations
• Section VIII, Division 1; Revise Part UHX, Appendix 5 and Appendix 26 to comply with revisions to U-2(g) and consistency with Division 2. Section VIII, Division 2; Revise paragraphs 4.18, 4.19 and 4.20 for consistency with the Division 1 changes relating to U-2(g).
• Section VIII, Division 1; Intent interpretation with revision to UCL-11; and revision to VIII-2; Part 3.3.6.2.
• Section VIII, Division 1; UG-131(e)(2), Metrication unit conversion for 1500 psig
• Section VIII, Division 1; UW-2(a) Lethal Service for Common Elements;
• Section VIII, Division 1; Table UW-12, General Note (a)
• Section VIII, Division 1; Expand the description of Combination Units to include dependent chambers in UG-19 and UG-99. Section VIII, Division 2; Expand the description of Combination Units to include dependent chambers in paragraphs 4.1.8 and 8.1.3
• Section VIII, Division 1; Appendix W: Form U-1P
• Section VIII, Div. 1 & 2; Appendix 26 & 4.19: Correction of membrane stress due to pressure in collar of reinforced bellows and editorial revisions
• Section VIII, Division 1; Referenced Standards in Table U-3
• Section VIII, Division 1 and 2; Part UHX and Paragraph 4.18
• Section VIII, Division 1; UW-53 Technique for Ultrasonic Examination of Welded Joints
• Section VIII, Division 1; Mandatory Appendix 1-4(c)
• Section VIII, Division 1 UHA-51/Div.2 3.11.4 revisions and interpretations
• Section VIII, Division 1; Revision to UG-138(c)(3)
• Section VIII, Division 1; Re-designation of UNS N08904 from SB to SA specifications
• Section VIII, Division 1; Partial Incorporation of Code Case 2418-1.
• Section VIII, Division 1; UG-11(d)
• Section VIII, Division 1; UG-100(e)
• Section VIII, Division 1; Revision to Part UIG-23.
• Section VIII, Division 1; Incorporation of SA-789, SA-790 and SA-815 UNS S32101 into Table UHA- 23
• Section VIII Divisions 1 and 2; Incorporation of Code Case 2270
• Section VIII, Divisions 1 and 2; Table UCS-23 - Withdrawal of Specification SA-202
• Section VIII, Divisions 1 & 2; Appendix 26 & 4.19: Shear Stress in Bellows Under Torsion Load
• Section VIII, Division 1; UIG-3 - Terminology
• Section VIII, Division 1; Appendix 39
• Section VIII, Division 1; Part UIG form CMQ
• Section VIII, Division 1; UIG-116(b)
• Section VIII, Division 1; Part UIG for CCQ and CPQ.
• Section VIII, Division 1; Table UHA-32-2, General Note (a)
• Section VIII, Division 1; UG-37(a) - Use of Welded Product Form Specifications
• Section VIII, Division 1; Fig. UG-118 ); Division 2, Paragraph 2-F.1(h),Fig. 2.F.1; Division 3, Fig. KS- 132
• Section VIII, Divisions 1 and 2; References to SC IX, Part QG
• Section VIII, Division 1; UG-11(d)(5)
• Section VIII, Division 1; App 26 and Division 2, Part 4.19, Maximum Design Temperature
• Section VIII, Divisions 1 and 2; Operating Load Cases
• Section VIII, Division 1; UG-45 and UG-53(j)
• Section VIII, Division 1; Caution Note in Figure L-11-3.
• Section VIII, Division 1; Table UHA-23 - Addition of SA-403 N08904
• Section VIII, Divisions 1 and 2; Incorporate S31266
• Section VIII, Division 1; NDE Procedure Qualification Requirements
• Section VIII, Division 1, 2013 Edition; Editorial Corrections to UG-11, UW-5, UW-18, and UCS-66
• Section VIII, Division 1; Appendix 26: Yield Strength Values
• Section VIII, Division 1; U-2(a)(5)
• Section VIII, Division 1; Editorial Errors
• Section VIII, Divisions 1 and 2; UHX-19.3.2 and 4.18.14.3 Manufacturer's Data Reports
➡BPVC-VIII-2 2015 Edition Items
• Section VIII, Division 2; Incorporation of Code Case 2562
• Section VIII, Division 2; Para. 4.3.11.3
• Section VIII, Division 2; Table 7.2
• Section VIII, Division 2; Clad Tubesheets
• Section VIII, Division 2; Part 5 Local Failure Check
• Section VIII, Division 2; Review Environmental Factor for Structural Stress Method in Division 2
• Section VIII, Division 2: Incorporate Code Case 2728 for Use of SB-564 Nickel-Iron-Chromium- Molybdenum-Copper Alloy UNS N08825 Forgings
• Section VIII, Division 2; Table 7.4
• Section VIII, Division 2; 7.5.5.1 - Use of Automated UT
• Section VIII, Division 2; Referenced Standards in Table 1.1
• Section VIII, Division 2; Table 4.2.3 - Materials for Major Attachment Parts
• Section VIII, Division 2; Incorporate Code Case 2295-3, UNS S32906 (29Cr-6.5Ni-2Mo-N)
• Section VIII, Division 2; Para. 5.3.3.2 - Equation 5.10
• Section VIII, Division 2; Correct nominal compositions in Division 2 Table 3-A.1 for SA-542 classes C and D
• Section VIII, Division 2; Revise Part 4 to define SPS consistent with Division 1, UG-23(e)
• Section VIII, Division 2; Annex 4-E: Add rules for Tube Expanding Procedures and Qualification
• Section VIII, Division 2; Part 4.13.12.3 Code Case for Rules for Calculating Maximum Permissible Gaps for Layered Vessels; and Equation 4.13.7
• Section VIII, Division 2; Paragraph 7.5.5.2 --Acceptance Criteria for UT in Lieu of RT
• Section VIII, Division 2; Table 6.1; Equations For Calculating Forming Strains
• Section VIII, Division 2; Para. 7.5.5.1
• Section VIII Division 2; Issue of Code Case for use of SA-336 /SA-336M F91 for Section VIII Division 2 application and Addition of SA-336 F91 in Table 3-A.1
➡➡BPVC-VIII-3 2015 Edition Items
• Section VIII, Division 3; Rupture Disk Devices
• Section VIII, Division 3; Incorporation of Code Case 2524, Inclusion of European Carbon Steel Material.
• Section VIII, Division 3; Moving KD-240 Linear Elastic Analysis into a New Mandatory Appendix
• Section VIII, Division 3; Incorporation of final revisions to Code Case 2579, Incorporation to Sec VIII Div 3 (related to 10-811)
• Section VIII, Division 3; Materials Permitted
• Section VIII, Division 3; Correction to Equations in KR523 and KR531
• Section VIII, Division 3; Revisions to KM-211.2 (a), (b),and (d) For The Manufacture Of Large Vessels From Single Piece Forgings
• Section VIII, Division 3; KD-6 - Threaded Components
• Section VIII, Division 3; Update to KD-141 Leak-Before-Burst Mode of Failure to KD-4 Methodology
• Section VIII, Division 3; Clean Up Linear Elastic Verbiage in VIII-3
• Section VIII, Division 3; New Certification Mark
• Section VIII, Division 3; Incorporation of Code Case 2524, Inclusion of European Carbon Steel Material (Error Correction)
• Section VIII, Division 3; Referenced Standards in Table KG-141
• Section VIII, Division 3; KT-312 Upper Limit Pressure of Sphere for Hydrostatic Test
• Section VIII, Division 3; Adding Reference to
• New Elastic Plastic Appendix
• Section VIII, Division 3; KD-221 - Correction of Tensile Strength References
• Section VIII, Division 3; KM-212 Updates to define test locations
• Section VIII, Division 3; Deletion of Nonmandatory Appendix F
• Section VIII, Division 3; KR-1 - Move Cautionary Elements from the current Manufacturing Range Definition
• Section VIII, Division 3; KD-221.1 and KD 221.2 Clarify application of closed and open end cylinders
• Section VIII, Division 3; Corrections to KS-132(c)
• Section VIII, Division 3; Update the Nominal Composition Column in Tables KM-400-1 and KM- 400-1M
• Section VIII, Division 3; Update to Appendix A
• Section VIII, Division 3; Revision to KD-1311
• Section VIII, Division 3; Correction to KD-323
• Section VIII Division 3; Revisions for KD-5.
• Section VIII Division 3; Addition of Reference to ASNT ACCP-CP-1 in KE-301(f).
• Section VIII, Division 3; Removal of Redundant Endnote 13 from VIII-3 Part KE
• Section VIII, Division 3; Revisions to KM-400 Material Tables.
• Section VIII Division 3; Rupture Disk Devices, Correction to item 01-061
• Section VIII, Division 3; Definition Updates for Equation KD-232.3
➡➡BPVC-IX 2015 Edition Items
• Review and Update of SWPSs
• QW-409.26 - Strip Cladding
• Addition of brazing filler metal variables QB-403.3 and QB-403.4 and update QB-252, QB-253, QB-254, QB-255, QB-256, QB-257 and QB-351.1(b)
• Friction Stir Welding Procedure Qualification
• Unassigned Base Metals used in Welder Qualifications
• Nonessential Variables
• Revision of QW-404.45, and Table QW-257.1 Table QW-269 and QW-269.1 QW-409.X
• QF-142
• BPV IX SC IX; QW/QB-422 and Appendix D - Inclusion of ASTM A860 Material
• BPV IX 14-501 SC IX; Hybrid Variables
• BPV IX SC IX; Incorporation of UNS N08367 for specifications A/SA-182, A403 and A/SA-479
• BPV IX 14-604 SC IX; QW-404.35
• BPV IX SC IX; QW/QB-422 - Alloy UNS S32101 for SA-240
• BPV IX SC IX; QG-100(x): Effective date of Section IX Code Cases
• BPV IX 14-501 SC IX; Revision to QW-500
• BPV IX SC IX; Table QW/QB-422 - Revise ISO 15608 Ti Groups
• 14-501
• BPV IX SC IX; Table QW-254.1 and Table QW-258.1 - Strip Cladding
• BPV IX 14-604 SC IX; Effective Date of Section IX
• Addition of A/SA-403 N08904
• Full Supervision & Control During Qualification
• Revision of QG-106.2
• BPV IX 13-590 SC IX; Appendix K
• Forms QW-482 through QW-485
• Table QW/QB-422 and Appendix D - Withdrawal of Specification SA-202
• Part QF - Electrofusing
• QF-464 HSTIT Specimen
• Assignment of a P-No. for UNS N06025
• Request from B31.3: P-number assignment for A928
• F-number assignment for new SFA 5.10 AWS Classifications
• Definition of "bare electrode"
• Appendix K
• Editorial Markups of SC IX
• Addition of A694 Grades F48 and F50
• Nonmandatory Appendix on Qualification of Welders under ISO rules
• Bend testing of Aluminum
• Review of AWS B2.2 E4 WD-1
• Definition of Special Positions
• Addition of S31266 Superaustenitic Stainless Steel
• Incorporation of Code Case 2648 (UNS N10362)
• QW-171 - Impact Testing
• Forms QF-482 & QF-483
• QW-403.3
• QW-409.1
• QW/QB-422 and Appendix D inclusion of A/SA-403 WP S31726
• Variable Definitions Revisions
➡➡BPVC-X 2015 Edition Items
• Revision to Code Case 2745.
• Section X, Adoption of the ASME CA-1 Standard
• Section X, Composite Pressure Vessels for High Pressure Fluids.
• Section X Corrections
BPVC-XI 2015 Edition Items
• Revision to Appendix D
• Incorporate Code Case N-532-5 into the ASME Section XI Code.
• Acceptance by Examination of Tendons in Class CC Containments with Unbonded Post- Tensioning Systems
• Impact of PWSCC examination on RI-ISI /NonMandatory Appendix R
• Revision to Article A-3000 for K Calculation Methods for Surface and Subsurface Flaws
• Revise IWA-4621 and IWA-4651 to clarify that peening for enhancing surface properties of completed temper bead welds is not prohibited. Eliminate peening as a qualification variable in IWA-4652.
• BPV XI 13-1310 Notes 3, 4, & 5 to examination Category B-A
• Clarification of IWB-3514 and IWC-3514 Acceptance Standards for Flaws in SCC Susceptible Materials
• General Requirements Clarify the system/component classification criteria found in IWA- 1400(a).
• Revise Non-mandatory Appendix M; Applying Mathematical Modeling to Ultrasonic Examination of Pressure Retaining Components
• Code Revision to add a Figure clarifying examination requirements for double-groove welded joints
• Code revision for Appendix IV: Supplement 2
• Extent of Surface Examination Requirements for Table IWB 2500 1, Category B-O, Item No. B14.10, Control Rod Drive (CRD) Housing Welds
• BPV XI SG ES IWA-9000 Glossary Definition for "Analytical Evaluation"
• Intent Interpretation and Code Change to IWF-1300(e).
• PQ&SV&ECE Visual Examination requirements of IWA-2210 of the 2013 Edition and of Code Case N-823
• Acceptance of through-wall or through-weld leakage in Class 1 components.
• Pressure Test Requirements for Class 2 & 3 Open End Systems
• Hold Time Requirements for Class 2 or Class 3 Segments of a Pressure Test when performed in conjunction with the Class 1 Test.
• Revision to Underwater Welding Requirements - Code Case N-516-3 and IWA-4660
• Intent Inquiry and Proposed Code Changes to Clarify Support Exemptions in IWF-1230.
• PRA-Related Revisions to Appendix R
• Section XI, Mandatory Appendix III - Ultrasonic Examination of Vessel and Piping Welds
• Incorporate Code Case N-805 into Section XI
• Clarify Class 2 Nozzle to Vessel Volumetric Examination Requirements
• Clarify open-ended IWC-1221(d) and IWC-1222(d) exemption for normally dry lines.
• Change to Supplement 10 (DM welds) to clarify single side qualification rules for DM welds with no austenitic base material Section XI, Division 1
• Cable Length Tolerance added to VIII-2100 for Performance Demonstration.
• Change to Appendix VIII-3000 Full Scale Test Piece Identification Section XI, Division 1
• Supplement 14 Circumferential Flaw Depth Sizing Requirements. Section XI, Division 1
• General Requirements Table IWA-1600-1 Reference Update
• Add figures to Figure IWB-2500-12 to address bolting with integral heads in addition to studs.
• Examination Requirements for Reduced-Shank Bolting
• Add figures to Figure IWC-2500-6 to address integral head bolting in addition to studs
• Adoption of ANSI/ASNT CP-189, 2006 Edition
• IWA-2300 References
• BPV XI New Code Case to Replace N-629 and Revision to Appendix A, A-4200 for Kia Fracture Toughness Determination
➡➡BPVC-XII 2015 Edition Items
• Revision to Section XII, TW-100.1
• BPV XII 1. Section XII - Review of TG-300 2. Substitute "Competent Authority" in place of "Legal Jurisdiction"
• Section XII - Inclusion of Section XII in CC1750
• BPV XII: Use of the "TV" and "TD" Designators in accordance with CSP-53
• Section XII - TG 440 and TP-2
• Section XII, Revision to Code Case 2235-9
• Section XII, TR-100 through TR-140 - General Requirements
• 14-263
• Section XII, TR-200, TR-210.3, TR-300, TR-310, TR-310.3, TR-310.4, TR-310.6, TR-320, TR-310.3, TR-310.4, TR-320.6, TR-510, TR-520, TR-530, TR-540
• Section XII, TR-210.1, TR-210.2, TR-310.1, TR-310.2
• Section XII, TR-210.4, TR-310.5, TR-400, TR-410
• Section XII, Modal Appendix 1 Allowable Stress Criteria
• Section XII - New Mandatory Appendix XIX
• BPV XII; New Certification Mark
• BPV XII, Revision to Table 3 in Code Case 2235
