Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 13 to 24 of 62
Thread: WRC Bulletin 449
  1. #13
    does anyone have WRC Bulletin 417 - flow-induced vibration problems
    best regards
  3. Here is WRC 417
    thanks.very good
  6. #16
    Wrc 329 & wrc 330
    Please, have somebody WRC 329 & WRC 330 in link with SIF (stress intensification factors) in pipes ? Thank you !
  7. Thanks a lot Tony.... where could I find somo more WRC documents?
    Cheers !!!
  9. Which ones are you looking for?
  10. I'd say:
    076-Gas And Oil Pipeline Welding Practices
    089-Experimental Investigation Of Stresses In Nozzles In Cylindrical Pressure Vessels
    179-Stress Indices and Flexibility Factiors for Moment Loadings on Elbows and Curved Pipe
    198-Secondary Stress Indices for Integral Structural Attachments to Striaght Pipe; Stress Indices at Lug Supports on Piping Systems
    285-Stress Indices and Flexibility Factors for Concentric Reducers ; Finite Element Analysis of Eccentric Reducers and Comparisons with Concentric Reducers
    296-Fitness-For-Service Criteria For Pipeline
    308-Verification and Application of an Inelastic Analysis Method for LMFBR Piping System
    314-Bolted Flanged Connections with Full Face Gaskets
    321-The Dynamic Deformation of Piping
    329-Accuracy of Stress Intensification Factors for Branch Connections
    335-A Review of Area Replacement Rules for Pipe Connections in Pressure Vessels and Piping
    356-Finite Element Modelling Of A Single Pass Weld ; Finite Element Analysis Of Multi-Pass Welds ; Thermal And Mechanical Simulations Of Resistance Spot Welding
    360-Stress Indices, Pressure Design And Stress Intensification Factors For Laterals In Piping
    367-Basis Of Current Dynamic Stress Criteria For Piping
    379-Alternative Methods For Seismic Analysis Of Piping Systems
    380-Recommendations To ASME For Code Guidelines And Criteria For Continued Operation Of Equipment
    391-Elevated Temperature Testing Of Gaskets For Bolted Flanged Connections
    392-Developing Stress Intensification Factors: I - Standardized Method For Developing Stress Intensification Factors For Piping Components ; II - Effects Of Weld Metal Profile On The Fatigue Life Of Integ
    412-Challenges and Solutions in Repair Welding for Power and Processing Plants – Proceedings of a Workshop
    417-Design Guide To Reduce Potential For Vibration Caused By Fluid Flow Inside Pipes-Review And Survey
    423-Evaluation Of Seismic Response Data For Piping
    425-A Review Of Methods For The Analysis Of Buried Pressure Piping
    429-3D Stress Criteria Guidelines For Application
    432-Fatigue Strength Reduction And Stress Concentration Factors For Welds In Pressure Vessels And Piping: )Interpretive Review Of Weld Fatigue-Strength-Reduction And Stress-Concentration Factors ; II)Fati
    433-Fatigue Of Butt-Welded Pipe And Effect Of Testing Methods: Fatigue Of Butt-Welded Pipe ; Effect Of Testing Methods On Stress Intensification Factors
    436-Evaluation Of Small (R/R<0.5) Branch Connections With Through-Run Moments
    441-Development Of A Comprehensive Static Seismic Analysis Method For Piping Systems
    446-Design And Repair Of Buried Pipe
    448-Evaluation of Welded Attachments on Pipe and Elbows
    468-Leak Testing Of A Raised Face Weld Neck Flange
    472-Using Finite Element Analysis To Determine Piping Elbow Bending Moment (B2) Stress Indices
    476-Recommendations for Determining Residual Stresses in Fitness-For-Service Assessment
    482-Special Finite Elements for Piping Elbows and Bends at High Temperatures with Creep
    492-Piping System SIFs and Flexibility Analysis Criteria
    500-Stress or Strain Criteria for Combined Static and Dynamic Loading
    505-An Overview and Validation of the Fitness-For-Service Assessment Procedures for Local Thin Areas in API 579
    510-Analysis of the Effects of Temperature on Bolted Joints
    Anything out of this list, would be a lot appreciated.
    Thanks in advance Tony
  11. Do you have WRC 488? It would be great if you could share that...
  12. Tony
    can you help me with this paper
    I appreciate you help
    regards
  13. #22
    Tony,
    Could you send me this documents ?
    Thanks in advance
  14. Sorry guys, I do not have any of WRC 296, 379, nor 446.
    (I do have 488 - I just have not gotten around to it yet)
  16. Hey tony_black
    I would be really grateful if you could share WRC 488 here....
    Thanks in advance...
  1. WRC Bulletin 360
    By pico5892 in forum Mechanical Engineering
    Last Post: 06-17-2016, 03:51 AM
  2. WRC Bulletin 452
    By Mike9977 in forum Mechanical Engineering
    Last Post: 12-21-2015, 05:39 AM
  3. WRC Bulletin 537
    By aap in forum Pipeline And Fluid Flow
    Last Post: 05-11-2014, 02:05 AM
  4. (need) API Bulletin D20
    By baronwisanggeni in forum Pipeline And Fluid Flow
    Last Post: 12-07-2011, 02:53 AM
  5. API Bulletin
    By Welding Inspector.SCWI in forum Oil And Gas Production
    Last Post: 09-25-2011, 05:50 AM
