Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 13 to 24 of 50
Thread: ASTM D1250 - 08 Standard Guide for Use of the Petroleum Measurement Tables
  1. I am working on a few data points where I need to calculate the corrected API (@ 60F) from an observed API which was taken at a different temperature for crude oil. I also need to calcualte corrected volume as well for which I believe I understand I need the VCF (Volume Correction Factors).
    I understand that "Adjunct to D1250 Petroleum Measurement Tables – Volume I" contains Table 5A: Generalized Crude Oils, Correction of Observed API Gravity to API Gravity at 60°F and Table 6A: Generalized Crude Oils, Correction of Volume to 60°F Against API Gravity.
    I also understand that "Adjunct to D1250 Petroleum Measurement Tables – Volume X" contains Background, Development, and Computer Documentation and that Volume X actually has the algorithms and equations published for calculating and approximating all of the tables published in the 12 volume Adjunct set.
    I don't know how many pages there are to Tables 5A and 6A in Volume 1 but that is what I believe I need. Even better would be the algorithms/equations that generate these particular tables for which I understand is published in Volume 10.
    Can someone help me with this??
    I only need this data for a one time set of calculations..
    Thanks to whoever can help me with this!!
    Greg
    Quote Originally Posted by curiousguy View Post
    [link Point to another website Only the registered members can access] Older version.. see if it helps
    please re-upload the file.
    file was expired.
    D 1250 - 04 Standard Guide for Use of the Petroleum Measurement Tables
  6. #16
    144.8mb
    Chapter 11 - Volume Correction Factors
    These are all I have, please update and add to these on this thread
    API MPMS 11.1 Addendum 1 9/2007
    API MPMS 11.1.1, Volume Correction Factors 8/1980 (R 8/1987) - TABLES 5A & 6A-Generalized Crude Oil and JP-4
    API MPMS 11.1.2, Volume Correction Factors 8/1980 (R 8/1987) - TABLE 5B-Generalized Products Correction of Observed API Gravity to API Gravity at 60°F TABLE 6B-Generalized Products Correction of Volume to 60°F Against API Gravity at 60°F 2540
    API MPMS 11.1.3, 1/1995 TABLE 6C, TABLE 54C
    API MPMS 11.1.10, 8/1980 Background, Development, and Program Documentation
    API MPMS 11.1.11-12, 7/1982 Petroleum Measurement Tables - Intraconversion Between Volume Measures and Density Measures
    API MPMS 11.1.14, 1/1982 Table 53D & 54D Lubricating Oils Correction
    API MPMS 11.2.1, 8/1984 Compressibility Factors for Hydrocarbons; 0-90&#186;API Gravity Range
    API MPMS 11.2.1, 10/1984 Errata
    API MPMS 11.2.1, 11.2.1M, 11.2.3 and 11.2.3M 8/1984 Computer Tape Information and Documentation
    API MPMS 11.2.5, Physical Properties Data 9/2007 - A Simplified Vapor Pressure Correlation for Commercial NGLs foreword only
    API MPMS 11.5.1, Physical Properties Data 3/2009 Section 5—Density/Weight/Volume Intraconversion Part 1—Conversions of API Gravity at 60 °F Adjunct to; ASTM D1250-08 and IP 200/08
    API MPMS 11.5.2, Physical Properties Data 3/2009 Section 5—Density/Weight/Volume Intraconversion Part 2—Conversions for Relative Density (60/60 °F) Adjunct to; ASTM D1250-08 and IP 200/08
    API MPMS 11.5.3, Physical Properties Data 3/2009 Section 5—Density/Weight/Volume Intraconversion Part 3—Conversions for Absolute Density at 15 °C Adjunct to; ASTM D1250-08 and IP 200/08
    See...
    for individual files
  7. Please re-upload ASTM D1250-08
    We need it urgently
  9. Here you go
  10. #19
    masboy, thanks but he's looking for 2008 not 1980
  11. Nabillia you are right my mistake. Dont seem to have it though. Is this 2008 basically a software add-in?
  12. #21
    Quote Originally Posted by masboy View Post
    My guess is that is new, I already posted a 2004 one above.
  13. #22
    From the ASTM site...
    ASTM D1250
    Significance and Use
    The expanded limits of API MPMS Chapter 11.1–2004/Adjunct to IP 200/04/Adjunct to ASTM D 1250–04 (ADJD1250CD) are defined in a mixture of terms of customary and metric units. Table 1 shows the defining limits and their associated units in bold italics. Also shown in Table 1 are the limits converted to their equivalent units (and, in the case of the densities, other base temperatures).
    Note that only the precision levels of the defining values shown in Table 1 are correct. The other values showing converted units have been rounded to the significant digits shown; as rounded values, they may numerically fall just outside of the actual limits established by the defining values.
    Table 2 provides a cross-reference between the historical table designations and the corresponding section in API MPMS Chapter 11.1–2004/Adjunct to IP 200/04/Adjunct to ASTM D 1250–04 (ADJD1250CD). Note that procedure paragraphs 11.1.6.3 (U.S. customary units) and 11.1.7.3 (metric units) provide methods for correcting on-line density measurements from live conditions to base conditions and then to compute CTPL factors for continuous volume corrections to base conditions.
    4.4 When a glass hydrometer is used to measure the density of a liquid, special corrections must be made to account for the thermal expansion of the glass when the temperature is different from that at which the hydrometer was calibrated. The 1980 CTL Tables had generalized equations to correct glass hydrometer readings, and these corrections were part of the printed odd-numbered tables. However, detailed procedures to correct a glass hydrometer reading are beyond the scope of API MPMS Chapter 11.1–2004/Adjunct to IP 200/04/Adjunct to ASTM D 1250–04 (ADJD1250CD). The user should refer to the appropriate sections of API MPMS Chapter 9 or other appropriate density/hydrometer standards for guidance.
    4.5 The set of correlations given in API MPMS Chapter 11.1–2004/Adjunct to IP 200/04/Adjunct to ASTM D 1250–04 (ADJD1250CD) is intended for use with petroleum fluids comprising either crude oils, refined products, or lubricating oils that are single-phase liquids under normal operating conditions. The liquid classifications listed here are typical terms used in the industry, but local nomenclature may vary. The list is illustrative and is not meant to be all-inclusive.
    4.6 Crude Oils—A crude oil is considered to conform to the commodity group Generalized Crude Oils if its density falls in the range between approximately –10°API to 100°API. Crude oils that have been stabilized for transportation or storage purposes and whose API gravities lie within that range are considered to be part of the Crude Oil group. Also, aviation jet B (JP-4) is best represented by the Crude Oil correlation.
    4.7 Refined Products—A refined product is considered to conform to the commodity group of Generalized Refined Products if the fluid falls within one of the refined product groups. Note the product descriptors are generalizations. The commercial specification ranges of some products may place their densities partly within an adjacent class (for example, a low density diesel may lie in the jet fuel class). In such cases, the product should be allocated to the class appropriate to its density, not its descriptor. The groups are defined as follows:
    4.7.1 Gasoline—Motor gasoline and unfinished gasoline blending stock with a base density range between approximately 50°API and 85°API. This group includes substances with the commercial identification of: premium gasoline, unleaded gasoline, motor spirit, clear gasoline, low lead gas, motor gasoline, catalyst gas, alkylate, catalytic -----ed gasoline, naphtha, reformulated gasoline, and aviation gasoline.
    4.7.2 Jet Fuels—Jet fuels, kerosene, and Stoddard solvents with a base density range between approximately 37°API and 50°API. This group includes substances with the commercial identification of: aviation kerosene K1 and K2, aviation jet A and A-1, kerosene, Stoddard solvent, JP-5 and JP-8.
    4.7.3 Fuel Oils—Diesel oils, heating oils, and fuel oils with a base density range between approximately –10°API and 37°API. This group includes substances with the commercial identification of: No. 6 fuel oil, fuel oil PA, low sulfur fuel oil, LT (low temperature) fuel oil, fuel oil, fuel oils LLS (light low sulfur), No. 2 furnace oil, furnace oil, auto diesel, gas oil, No. 2 burner fuel, diesel fuel, heating oil, and premium diesel.
    4.8 Lubricating Oils—A lubricating oil is considered to conform to the commodity group Generalized Lubricating Oils if it is a base stock derived from crude oil fractions by distillation or asphalt precipitation. For the purpose of API MPMS Chapter 11.1–2004/Adjunct to IP 200/04/Adjunct to ASTM D 1250–04 (ADJD1250CD), lubricating oils have initial boiling points greater than 700°F (370°C) and densities in the range between approximately –10°API to 45°API.
    4.9 Special Applications—Liquids that are assigned the special applications category are generally relatively pure products or homogeneous mixtures with stable (unchanging) chemical composition that are derived from petroleum (or are petroleum-based with minor proportions of other constituents) and have been tested to establish a specific thermal expansion factor for the particular fluid. These tables should be considered for use when:
    4.9.1 The generalized commodity groups' parameters are suspected of not adequately representing the thermal expansion properties of the liquid.
    4.9.2 A precise thermal expansion coefficient can be determined by experiment. A minimum of 10 temperature/density data points is recommended to use this method. See 11.1.5.2 of API MPMS Chapter 11.1–2004/Adjunct to IP 200/04/Adjunct to ASTM D 1250–04 (ADJD1250CD) for the procedure to calculate the thermal expansion coefficient from measured density data.
    4.9.3 Buyer and seller agree that, for their purpose, a greater degree of equity can be obtained using factors specifically measured for the liquid involved in the transaction.
    4.9.4 Specific Examples:
    4.10 Refer to paragraphs 11.1.2.4 and 11.1.2.5 in API MPMS Chapter 11.1–2004/Adjunct to IP 200/04/Adjunct to ASTM D 1250–04 (ADJD1250CD) for a complete description of the suitability of the implementation procedures for specific hydrocarbon liquids.
    TABLE 1 Range LimitsA
    Physical Units Crude Oil Refined Products Lubricating Oils
    Density, kg/m3 @ 60°F 610.6 to 1163.5 610.6 to 1163.5 800.9 to 1163.5
    Relative Density @ 60°F 0.61120 to 1.16464 0.61120 to 1.16464 0.80168 to 1.1646
    API Gravity @ 60°F 100.0 to -10.0 100.0 to -10.0 45.0 to -10.0
    Density, kg/m3 @ 15°C 611.16 to 1163.79 611.16 to 1163.86 801.25 to 1163.85
    Density, kg/m3 @ 20°C 606.12 to 1161.15 606.12 to 1160.62 798.11 to 1160.71
    Temperature, °C –50.00 to 150.00 –50.00 to 150.00 –50.00 to 150.00
    Temperature, °F –58.0 to 302.0 –58.0 to 302.0 –58.0 to 302.0
    Pressure, psig 0 to 1500 0 to 1500 0 to 1500
    kPa (gage) 0 to 1.034 × 104 0 to 1.034 × 104 0 to 1.034 × 104
    bar (gage) 0 to 103.4 0 to 103.4 0 to 103.4
    α60, per °F 230.0 × 10-6 to 930.0 × 10-6 230.0 × 10-6 to 930.0 × 10-6 230.0 × 10-6 to 930.0 × 10-6
    α60, per °C 414.0 × 10-6 to 1674.0 × 10-6 414.0 × 10-6 to 1674.0 × 10-6 414.0 × 10-6 to 1674.0 × 10-6
    A Defining limits and their associated units appear in bold italics.
    TABLE 2 Historical Table Cross-Reference
    Historical Table Designation Procedure Paragraph in Current Standard Historical Table Designation Procedure Paragraph in Current Standard
    5 A, B & D 11.1.6.2 53 A, B & D 11.1.7.2
    23 A, B, & D 11.1.6.2 59 A, B, & D 11.1.7.2
    6 A, B, C & D 11.1.6.1 54 A, B, C & D 11.1.7.1
    24 A, B, C & D 11.1.6.1 60 A, B, C & D 11.1.7.1
    1. Scope
    1.1 The API MPMS Chapter 11.1–2004/Adjunct to IP 200/04/Adjunct to ASTM D 1250–04 (ADJD1250CD) for temperature and pressure volume correction factors for generalized crude oils, refined products, and lubricating oils, provides the algorithm and implementation procedure for the correction of temperature and pressure effects on density and volume of liquid hydrocarbons. Natural gas liquids (NGLs) and liquefied petroleum gases (LPGs) are excluded from consideration. The combination of density and volume correction factors for both temperature and pressure is collectively referred to in the standard/adjunct(s) as a Correction for Temperature and Pressure of a Liquid (CTPL). The temperature portion of this correction is termed the Correction for the effect of Temperature on Liquid (CTL), also historically known as VCF (Volume Correction Factor). The pressure portion is termed the Correction for the effect of Pressure on Liquid (CPL). As this standard will be applied to a variety of applications, the output parameters specified in this standard/adjunct(s) (CTL, Fp, CPL, and CTPL) may be used as specified in other standards.
    1.2 Including the pressure correction in API MPMS Chapter 11.1–2004/Adjunct to IP 200/04/Adjunct to ASTM D 1250–04 (ADJD1250CD) represents an important change from the “temperature only” correction factors given in the 1980 Petroleum Measurement Tables. However, if the pressure is one atmosphere (the standard pressure) then there is no pressure correction and the standard/adjunct(s) will give CTL values consistent with the 1980 Petroleum Measurement Tables.
    1.3 API MPMS Chapter 11.1–2004/Adjunct to IP 200/04/Adjunct to ASTM D 1250–04 (ADJD1250CD) covers general procedures for the conversion of input data to generate CTL, Fp, CPL, and CTPL values at the user specified base temperature and pressure (Tb, Pb). Two sets of procedures are included for computing volume correction factor: one set for data expressed in customary units (temperature in °F, pressure in psig); the other for the metric system of units (temperature in °C, pressure in kPa or bar). In contrast to the 1980 Petroleum Measurement Tables, the metric procedures require the procedure for customary units be used first to compute density at 60°F. This value is then further corrected to give the metric output. The metric procedures now incorporate the base temperature of 20°C in addition to 15°C.
    1.4 The procedures recognize three distinct commodity groups: crude oil, refined products, and lubricating oils. A procedure is also provided for determining volume correction for special applications where the generalized commodity groups' parameters may not adequately represent the thermal expansion properties of the liquid and a precise thermal expansion coefficient has been determined by experiment.
    2. Referenced Documents
    API Standards
    ISO Standards
    Index Terms
    crude oil; density correction; lubricants; lubricating oils; Petroleum Measurement Tables; petroleum products; volume correction; volume correction factor; API (American Petroleum Institute); Electrical insulating petroleum products; Volumetric measurement--petroleum products; Weight per unit area; ICS Number Code 75.080 (Petroleum products in general); 75.100 (Lubricants, industrial oils and related products)
  14. #23
    thanks,masboy!
  16. HELLO NABILIA:
    NOT DOWNLOAD, NO ABRE LOS FILES
    [link Point to another website Only the registered members can access] PLEASE ENVIALOS A MI MAIL angeljos@gmail.com
  1. SOFTWARE FOR PETROLEUM MEASUREMENT TABLES, ASTM D 1250-80 and D1250-04
    By tonycaden in forum Laboratory Measurements
    Last Post: 04-23-2025, 01:43 AM
  2. ASTM D1250 - Volume 07 Tables 53A & 54A
    By el hassan in forum Laboratory Measurements
    Last Post: 02-12-2019, 02:05 PM
  3. Petroleum Measurement Tables
    By andy70 in forum Oil And Gas Production
    Last Post: 11-03-2016, 11:47 AM
  4. ASTM D1250-IP200 Petroleum Measurement Tables - Table 54
    By Deer in forum Laboratory Measurements
    Last Post: 07-19-2014, 12:31 PM
  5. Astm d1250
    Last Post: 07-19-2014, 09:11 AM
