P
Pale Oil
A base or process oil refined until its color, by
transmitted light, is straw to pale yellow.
PAN
Phenyl-Alpha-Naphthylamine, a commonly
used antioxidant
PAPTG
Product Approval Protocol Task Group
Paraffin Series
A homologous series of open-chain saturated
hydrocarbons of the general formula CnH2n+2 of
which methane (CH4) is the first member;
sometimes referred to as the methane series.
PCMO
Passenger Car Motor Oil
Penetration
Consistency, expressed as the distance in
millimeters that a standard needle or cone
penetrates vertically into a sample of the
material under known conditions of loading, time
and temperature.
Pentane Insolubles
Usually called normal pentane insolubles; the
insoluble matter which can be separated from
a solution of used lubricating oil in normal
pentane and, in addition to the benzene
insolubles, may include resinous bitumens
produced from the oxidation of oil and fuel
(ASTM Method C 893).
Pour Depressor
A lubricating oil additive which lowers the pour
point of an oil by reducing the tendency of the
wax to form a solid mass in the oil. Also called
pour-point depressor, pour depressant.
Pour Point
The lowest temperature at which oil will pour or
flow when it is chilled without disturbance under
definite conditions (ASTM Method D 97)
Pour Stability
The ability of a pour depressed oil to maintain
its original ASTM pour point when subjected to
storage at low temperature approximating winter
conditions
Precipitation Number
The number of milliliters of precipitate formed
when 10 ml of lubricating oil is mixed with 90 ml
of petroleum naphtha and centrifuged under
definitely prescribed conditions. The precipitation
number should indicate the amount of the
asphaltic bodies dissolved in the lubricating oil,
although a certain amount of paraffin bodies
may separate with the asphaltic bodies (ASTM
method D 91).
Process Oil
An oil not used for lubrication but as a component
of another material, or as a carrier of other
products.
