Sorry for replying late,my friends. have meeting all these days.After I read the two articles ,I think it can't be called regional velocity reseach. In my study area it have merely 20 wells drilled at present. And in the article it commonly have hundreds of wells.
In my study area we often encounter with the depth conversion question.In a structure, we usually use the velocity of wildcat well to convert time to depth.But on appraisal well ,the actual depth are higher or lower. sometimes the depth in appraisal well were higher than the wildcat.You know we commonly drill wildcat well in the top of the structure.
Your suggestion are very good. I will have a try.Thanks my friend.
And sorry for my poor english expression about "regional velocity".
If you have sufficient wells with sonic logs you could try to tabulate the DT reading at reservoir marked depth. Do this for all wells. You must know x,y coordinates for all wells involved. The inverse of the DT reading is a measure of seismic velocity. Now you have seismic velocity data distributed at all well locations. For the map you can use any contour software like SURFER.
Hi friends
Hope everything goes well with you
I have provided a huge gallery of newest petroleum software like: Petrel 2013.3, Eclipse 2013.1, Geoframe 2012, Paradigm 2011.3, Olga 7.2, OSP4.0.3, Mepo 4.2, Techlog 2013.2, RoXar RMS 2013.1, Ecrin 4.2.07, CMG 2013.1, S/M/T K/ingdom 8.8, Rokdoc 6.0.0.107, Desicion Space Desktop r5000.8.1.1, Drillworks 5000.8.1.1, Openworks r5000.8.1, VIP-Nexus 5000.4.4.0, Skua Gocad 2011.3, IPM 8.0, PetroMod 2013.1, Interactive Petrophysics 4.1, Openflow 2012.2, Pipesim 2013.1, Que$tor 3013Q1, FractPro 2013, Vista 13, Jason 8.4, GeoGraphix Discovery 2013, and so many other things ...
if anybody need Please contact me I will share with you. Also I need some applications hope you can kindly help me.
My E-mail is: slbsoft33@gmail.com
Cheers.
