Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 13 to 24 of 68
Thread: OLGA 6.0.2.807 full *****
  1. try
    thanks very much
    Hello People,
    Does anyone have Cr----d OLGA 5
  6. hi
    if you please share OLGA 6.0.2.807 again
    please keep awy of rapidshare
  7. thanks!
  9. Can somebody please help me to make it running on my PC.
    How to get its ******** (L*******) or is there any other way of making it run???
    Ravi
  10. Can anybody help us with ******** for using Olga 6 in Windows 7
  11. #20
    Feb 2010
    Tierra
    Activate OLGA :
    1. Unpack and install OLGA 6. No problem at this point.
    2. Copy ibfs32.dll to C:\Windows\System 32
    3. Modify license file with following header:
    SERVER (my pc) ANY 7570
    VENDOR scplmd
    USE_SERVER
    4. Copy license file to C:\Program Files\SPT Group\Licenses
    5. Start LicMgr and select "Use a license server on this machine", go to License folder (location of license file) with Browse and then go to FlexLM folder with Browse. It indicates that everything is OK and that the server is up and running...
  12. Hi anihita,
    Can u pls help me to run it in Windows 7 Ultimate edition 32 bit... plssss
  13. #22
    I followed all above steps but I got the following message:
    "Failed to start OLGA GUI due to the license error:
    Invalid (inconsistent) license key.
    The license key and data for the feature do not match.
    This usually happens when a license file has been altered.
    Feature: gui
    License path: D\Program Files\SPT Group\Licenses\olga.lic;@knowledge (<= my pc name)
    Flexnet license error:-8,544
    please help
  14. #23
    Feb 2010
    Tierra
    dear orbawy, this may be due to the faulty license that you are using. follow the instructions carefully , especially about from where to copy the license file
  16. #24
    Dear anihita,
    I appreciate your comment but I'm still confused. I use XP SP2 and my pc name is knowledge. So I did the steps as following:
    1- install OLGA.
    2- copy ibfs32.dll to C:\Windows\System 32
    3-modify the header of the file olga.lic:
    SERVER knowledge ANY 7570
    VENDOR scplmd
    USE_SERVER
    4-Copy license file (olga.lic) to C:\Program Files\SPT Group\Licenses
    5-Start LicMgr and select "Use a license server on this machine", go to License folder (location of license file) with Browse and then go to FlexLM folder with Browse. It indicates that everything is OK and that the server is up and running...
    but after all, it does not work!!!
    You can check olga.lic file in below attachment
    Please tell me where is my mistake
