Page 2 of 2 FirstFirst 1 2
Results 13 to 20 of 20
Thread: Amine Gas Sweetening HP
  1. #13
    Hi alex.gutu,
    You have to pick the right amine that removes CO2 and amine that removes H2S, their ratio in the mix depends on the stoichiometic calculations you make. I am sorry but my answer in forums is limited to giving key ideas rather than doing full calculations( see this example:
    Best of luck.
    Quote Originally Posted by alex.gutu View Post
    Dear Sir Mobek,
    Could you tell me please what type amine mixture would you recommend to me? I'll appreciate it very much and I'll try to use it in simulation to see what can I get using amine mixture.
    If you don't mind you could recommend more than just one amine mix, in case I can't get what I expect with 1st amine mix.
    Thank you Mobek.
    Kindly,
    A.G.
    A hybrid process involving Membrane system for bulk CO2 removal, followed by an amine system is better suited when ever CO2 concentration exceeds 15%. Refer the book " Gas Purification " by Kohl et.all.
    I understand promax is specialised software for gas treating with amines. Any experience sharing on this? can any one share promax or Protreat ?
  6. #16
    What is typ pressure in the contactor? I heard for mdea or almost all amines it has to be above 4 kg/cm2(abs) ?
    Is it near atm for formulated amines?
  7. #17
    ProTreat gives comparable results to ProMax. You caan also use HYSYS Amine thermo package.
    Quote Originally Posted by aseptman View Post
  9. #18
    Like any diffusion rate controlled process the higher the pressure the better the absoption rate. Also, the lower the temp. the better the absorption of H2S and other species. You have to carry out some simulation runs to optimize your op. conditions as well as equipment size.
  10. #19
    The Bryan blog has the following on Amine degradation:
    Amine Thermal Degradation (by Lili Lyddon)
    Posted by: BRE Blogger Tuesday, April 08, 2008 1:04 PM
    Process engineers often express concern about amine reboiler temperatures being high enough to cause thermal degradation of the amine. However, thermal degradation is generally not a concern in amine reboilers heated with steam or heat transfer fluids.
    In “DEA degradation mechanism,” Hydrocarbon Processing, October 1982, A. Meisen and M. L. Kennard discuss the fact that DEA and MDEA thermal degradation is minimal up to 400°F. Although the degradation of DEA is caused by reaction with CO2 and not temperature alone, temperature does affect the rate of degradation caused by reaction with CO2. This reference states: “Degradation increases strongly with temperature. This is not due to thermal breakdown of DEA, but it requires the presence of carbon dioxide. Design and operation of DEA units must avoid creation of elevated temperature throughout the plants. Heat transfer surfaces of DEA stripper-reboilers (especially when gas fired) are particularly prone to formation of localized hot spots. To prevent such hot spots in operating plants, DEA circulation through the stripper-reboiler should be kept high and steam (or gas) temperature kept low. In many DEA units only the bulk solution temperatures are measured. It must be remembered that the skin temperatures of heat transfer surfaces can be very much higher, particularly during process upsets. Reliance upon bulk temperatures is therefore inadequate.”
    In the paper “Reduce amine plant solvent losses, Part 2” from Hydrocarbon Processing, June 1994, E. J. Stewart and R. A. Lanning mention that the thermal degradation of amines accelerates above 350°F, so the skin temperature of direct fired reboilers should be kept below 350°F. They recommend a reboiler operation with an amine bulk temperature below 260°F. This reference goes on to say: “With hot oil and steam heating systems, risk of thermal degradation is low since the heat media is usually not operated at high temperature. However, in fired-reboiler operation, the temperature of amine on the tube’s surface can easily exceed 350°F. In fired reboilers, forced circulation is often used to maintain low skin temperatures. The rule of thumb is to maintain amine skin temperatures between 300°F and 325°F, and not exceed 350°F. for these temperatures a conservative design heat flux of less than 8000 Btu/ft2 of tube area is recommended.”
    Other references indicate 400°F as the thermal degradation temperature of MEA. Keep in mind that the reboiler temperature is set by the stripper operating pressure. To reduce the reboiler temperature, the stripper pressure can be reduced.
    Authored by Lili Lyddon (BR&E Technical Support and Help Author)
  11. Re: Amine Gas Sweetening HP
    We are having Amine treating unit in Texas for Gas Removal services we are doing works of lots of
  1. Gas Sweetening
    By anything in forum Oil And Gas Process
    Last Post: 03-10-2014, 01:53 AM
  2. Sweetening System With amine Guide needed.
    By djurcich in forum Oil And Gas Process
    Last Post: 02-12-2014, 03:29 PM
  3. Methane Loss in Natural Gas Sweetening using Amine Unit
    By Febrianm9292 in forum Oil And Gas Process
    Last Post: 09-05-2013, 08:22 PM
  4. Article: Amine unit/ Gas sweetening plant material selection
    By Syed Haider Raza in forum Home Articles
    Last Post: 03-19-2012, 10:18 AM
  5. Amine unit/ Gas sweetening plant material selection
    By Syed Haider Raza in forum Materials Science &Corrosion
    Last Post: 10-24-2011, 02:29 PM
