Page 2 of 2 FirstFirst 1 2
Results 13 to 19 of 19
Thread: What is the minimum distance between two welding joints?
  1. I'm looking for your information about minimum distance between two weld joint should be 11/2" (50mm) or 5 times pipe diameter, but I could not find this information on any standard. Are there any standart are telling that this?
    this as per ASME Sec IX-welding code
    Quote Originally Posted by Ali366 View Post
    Polka,
    What is your design or construction code? Construction code Api 1104
    Where is the welded joint? Is it in a pressure equipment, say piping, pressure vessel, etc. or in a storage tank or steel structure? These welds are for air release valves and for other components like valve,clappe or manholes
    If in a pressure equipment, is the weld joint a longitudinal weld or a circumferential joint? Not a pressure equipment valves or clappes
    What is the degree/type of NDT? 100% x-ray
    Cheers,
    I tried to answer your questions.
  6. I in your place. I will install a elbolet and valve the elbolet is a fittings that permit you install the branch in the elbow. this solution is not in the the highest point but i think it is a solution.
    otherwise you must have minimum 50 mm at weld. this dimension is a thumb rule. The codes indicate the variables that you keep in mind for taht you can determinate this dimension.
    Hope this will help you
  7. #17
    50 mm is minimum, only if you dont have space, for pipes up to 4" i advise you to go 75-100 mm, and for diameters above 4" use 1x Pipe Dia.
  9. #18
    Feb 2012
    Batam Island, Indonesia
    Re: What is the minimum distance between two welding joints?
    As per ASME B31.3 para 341.4.1.6.B " when a circumferential weld with an interesting longitudinal weld is examined, at least the adjacent 38mm(1.5 Inch) , of each interesting weld shall be Examined"
  10. #19
    It depends also to the NDT.
    For example when there is UT, need to have min. 100mm distance...
  1. WeldShop - Free Welding Software for Piping Welding (Carbon & Low Alloy Steel)
    By ashfaqanwer in forum Materials Science &Corrosion
    Last Post: 01-27-2014, 08:50 AM
  2. Minimum Distance Between Feed Nozzle and Tray Downcomer
    By strategist7 in forum Petroleum Refining
    Last Post: 07-21-2013, 02:12 AM
  3. Replies: 0
    Last Post: 07-26-2011, 11:36 AM
  4. Replies: 0
    Last Post: 04-30-2010, 02:36 PM
