Thanks a lot for great help
Thanks a lot!
new API Documents ...
# Document Number Date Title
1. API STD 603 [28 Page(s)] API STD 603
2013.02.01 Corrosion-resistant, Bolted Bonnet Gate Valves—Flanged and Butt-welding Ends - EIGHTH EDITION
2. API MPMS 21.1 [104 Page(s)] API MPMS 21.1
2013.02.01 Manual of Petroleum Measurement Standards Chapter 21.1 - Flow Measurement Using Electronic Metering Systems - Electronic Gas Measurement - Second Edition
3. API SPEC 4F [62 Page(s)] API SPEC 4F
2013.01.01 Specification for Drilling and Well Servicing Structures - Fouth Edition; EFFECTIVE DATE: AUGUST 1, 2013
4. API STD 599 [28 Page(s)] API STD 599
2013.01.01 Metal Plug Valves—Flanged, Threaded and Welding Ends - SEVENTH EDITION
5. API RP 1114 [58 Page(s)] API RP 1114
2013.01.01 Recommended Practice for the Design of Solution-Mined Underground Storage Facilities - Second Edition
6. API MPMS 20.3 [90 Page(s)] API MPMS 20.3
2013.01.01 Manual of Petroleum Measurement Standards Chapter 20.3 Measurement of Multiphase Flow - First Edition
7. API MPMS 20.1 [78 Page(s)] API MPMS 20.1
2013.01.01 Manual of Petroleum Measurement Standards Chapter 20 - Allocation Measurement Section 1 - Allocation Measurement - First Edition
8. API RP 85 ADD [2 Page(s)] API RP 85 ADD
2013.01.01 Use of Subsea Wet-gas Flowmeters in Allocation Measurement Systems - First Edition
9. API RP 17P [80 Page(s)] API RP 17P
2013.01.01 Design and Operation of Subsea Production Systems - Subsea Structures and Manifolds - First Edition; ISO 13628-15:2011 Adoption
10. API MPMS 20.1 ADD [1 Page(s)] API MPMS 20.1 ADD
11. API RP 500 [162 Page(s)] API RP 500
2012.12.01 Recommended Practice for Classification of Locations for Electrical Installations at Petroleum Facilities Classified as Class I, Division 1 and Division 2 - Third Edition
12. API SPEC 5L [192 Page(s)] API SPEC 5L
2012.12.01 Specification for Line Pipe - FORTY-FIFTH EDITION; EFFECTIVE DATE: JULY 1, 2013
13. API MPMS 9.3 [20 Page(s)] API MPMS 9.3
2012.12.01 Manual of Petroleum Measurement Standards Chapter 9.3 Standard Test Method for Density, Relative Density, and API Gravity of Crude Petroleum and Liquid Petroleum Products by Thermohydrometer Method - Third Edition
14. API MPMS 9.1 [18 Page(s)] API MPMS 9.1
2012.12.01 Manual of Petroleum Measurement Standards Chapter 9.1 - Standard Test Method for Density, Relative Density, or API Gravity of Crude Petroleum and Liquid Petroleum Products by Hydrometer Method - Third Edition
15. API MPMS 9.2 [16 Page(s)] API MPMS 9.2
2012.12.01 Manual of Petroleum Measurement Standards Chapter 9.2 Standard Test Method for Density or Relative Density of Light Hydrocarbons by Pressure Hydrometer- Measurement Coordination - Third Edition
16. API STD 53 [124 Page(s)] API STD 53
2012.11.01 Blowout Prevention Equipment Systems for Drilling Wells - Fourth Edition
17. API STD 675 [74 Page(s)] API STD 675
2012.11.01 Positive Displacement Pumps - Controlled Volume for Petroleum, Chemical, and Gas Industry Services - Third Edition
18. API STD 608 [28 Page(s)] API STD 608
2012.11.01 Metal Ball Valves - Flanged, Threaded, and Welding Ends - FIFTH EDITION
19. Not part of your company subscription. Click the icon to order a personal copy. API RP 5L2 RUSSIAN
2012.10.11 Recommended Practice for Internal Coating of Line Pipe for Non-Corrosive Gas Transmission Service - Fourth Edition
20. API RP 1595 [88 Page(s)] API RP 1595
2012.10.01 Design, Construction, Operation, Maintenance, and Inspection of Aviation Pre-Airfield Storage Terminals - SECOND EDITION
21. API RP 553 [122 Page(s)] API RP 553
2012.10.01 Refinery Valves and Accessories for Control and Safety Instrumented Systems - Second Edition
22. API SPEC 11AX ADD 2 CHINESE [1 Page(s)] API SPEC 11AX ADD 2 CHINESE
2012.10.01 Specification for Subsurface Sucker Rod Pumps and Fittings - Twelfth Edition
23. API RP 11S8 [28 Page(s)] API RP 11S8
2012.10.01 Recommended Practice on Electric Submersible System Vibrations - Second Edition
24. API API STD 6DX [63 Page(s)] API API STD 6DX
2012.10.01 Petroleum and natural gas industries—Mechanical integrity and sizing of actuators and mounting kits for pipeline valves - First Edition
25. API MPMS 19.4 [148 Page(s)] API MPMS 19.4
2012.10.01 Manual of Petroleum Measurement Standards Chapter 19.4 Evaporative Loss Reference Information and Speciation Methodology - Third Edition
26. API SPEC 6D ADD 3 CHINESE [16 Page(s)] API SPEC 6D ADD 3 CHINESE
2012.10.01 Specification for Pipeline Valves - Twenty-Third Edition; Effective date: April 1,2013
27. API MPMS 19.1 [38 Page(s)] API MPMS 19.1
2012.10.01 Manual of Petroleum Measurement Standards Chapter 19.1 Evaporative Loss From Fixed-Roof Tanks - Fourth Edition
28. API MPMS 19.2 [98 Page(s)] API MPMS 19.2
2012.10.01 Manual of Petroleum Measurement Standards Chapter 19.2 Evaporative Loss From Floating-Roof Tanks - Third Edition
29. API SPEC 5CT ERTA [15 Page(s)] API SPEC 5CT ERTA
2012.09.01 Specification for Casing and Tubing - NINTH EDITION
30. API MPMS 14.3.1 [68 Page(s)] API MPMS 14.3.1
2012.09.01 Orifice Metering of Natural Gas and Other Related Hydrocarbon Fluids - Concentric, Square-edged Orifice Meters Part 1: General Equations and Uncertainty Guidelines - FOURTH EDITION
31. API SPEC 20E [30 Page(s)] API SPEC 20E
2012.08.01 Alloy and Carbon Steel Bolting for Use in the Petroleum and Natural Gas Industries - FIRST EDITION
32. API COMPOSITE LIST [1028 Page(s)] API COMPOSITE LIST
2012.07.01 The API Composite List
33. API STD 2350 [58 Page(s)] API STD 2350
2012.05.01 Overfill Protection for Storage Tanks in Petroleum Facilities - Fourth Edition
34. API RP 6DR [22 Page(s)] API RP 6DR
2012.05.01 Recommended Practice for the Repair and Remanufacture of Pipeline Valves - Second Edition
35. API MPMS 17.9 [34 Page(s)] API MPMS 17.9
2012.05.01 Manual of Petroleum Measurement Standards Chapter 17 El Hydrocarbon Management HM 49 Marine Measurement Section 9—Vessel Experience Factor (VEF) - Second Edition
36. API SPEC 8C [66 Page(s)] API SPEC 8C
2012.04.01 Drilling and Production Hoisting Equipment (PSL 1 and PSL 2) - Fifth Edition
37. API RP 4G [68 Page(s)] API RP 4G
2012.04.01 Operation, Inspection, Maintenance, and Repair of Drilling and Well Servicing Structures - Fourth Edition
38. API RP 2001 [86 Page(s)] API RP 2001
2012.04.01 Fire Protection in Refineries - Ninth Edition
39. API MPMS 12.1.1 [52 Page(s)] API MPMS 12.1.1
2012.04.01 Manual of Petroleum Measurement Standards Chapter 12.1.1—Calculation of Static Petroleum Quantities—Upright Cylindrical Tanks and Marine Vessels - Third Edition
40. API RP 688 [550 Page(s)] API RP 688
2012.04.01 Pulsation and Vibration Control in Positive Displacement Machinery Systems for Petroleum, Petrochemical, and Natural Gas Industry Services - First Edition
41. API SPEC 8C CHINESE [69 Page(s)] API SPEC 8C CHINESE
42. API RP 1161 [106 Page(s)] API RP 1161
2012.04.01 Recommended Practice for Pipeline Operator Qualification (OQ) - Second Edition; Addendum 1: January 2013
43. API MPMS 14.7 [18 Page(s)] API MPMS 14.7
2012.04.01 Manual of Petroleum Measurement Standards Chapter 14.7 - Mass Measurement of Natural Gas Liquids - Fourth Edition
44. API MPMS 17.5 [51 Page(s)] API MPMS 17.5
2012.04.01 Manual of Petroleum Measurement Standards Chapter 17.5 - El Hydrocarbon Management - HM 64 - Guidelines for Voyage Analysis and Reconciliation of Cargo Quantities - Third Edition; Includes Access to Additional Content
45. API SPEC 2C [136 Page(s)] API SPEC 2C
2012.03.01 Offshore Pedestal-mounted Cranes - Seventh Edition
46. API OCCUPATIONAL INJURIES [27 Page(s)] API OCCUPATIONAL INJURIES
2012.03.01 2011 Survey of Occupational Injuries, Illnesses, and Fatalities in the Petroleum Industry Summary Report Aggregate Data Only
47. API SPEC 20A [42 Page(s)] API SPEC 20A
2012.03.01 Carbon Steel, Alloy Steel, Stainless Steel, and Nickel Base Alloy Castings for Use in the Petroleum and Natural Gas Industry - First Edition
48. API RP 932-B [54 Page(s)] API RP 932-B
2012.03.01 Design, Materials, Fabrication, Operation, and Inspection Guidelines for Corrosion Control in Hydroprocessing Reactor Effluent Air Cooler (REAC) Systems - Second Edition
49. API SPEC 2C CHINESE [142 Page(s)] API SPEC 2C CHINESE
50. API TR 17TR6 [54 Page(s)] API TR 17TR6
2012.03.01 Attributes of Production Chemicals in Subsea Production Systems - First Edition
51. API TR 17TR5 [54 Page(s)] API TR 17TR5
2012.03.01 Avoidance of Blockages in Subsea Production Control and Chemical Injection Systems - First Edition
52. API RP 5LT [16 Page(s)] API RP 5LT
2012.03.01 Recommended Practice for Truck Transportation of Line Pipe - First Edition
53. API STD 653 ADD 2 CHINESE [106 Page(s)] API STD 653 ADD 2 CHINESE
2012.01.01 Tank Inspection, Repair, Alteration, and Reconstruction - Fourth Edition; Includes Addendum 1: 8/2010
54. API SPEC 17D ERTA 2 [3 Page(s)] API SPEC 17D ERTA 2
2012.01.01 Design and Operation of Subsea Production Systems-Subsea Wellhead and Tree Equipment - Second Edition
55. API TR 17TR4 [16 Page(s)] API TR 17TR4
2012.01.01 Subsea Equipment Pressure Ratings - First Edition
56. API SPEC Q2 [36 Page(s)] API SPEC Q2
2011.12.01 Specification for Quality Management System Requirements for Service Supply Organizations for the Petroleum and Natural Gas Industries - First Edition
57. API SPEC Q2 CHINESE [36 Page(s)] API SPEC Q2 CHINESE
58. API MPMS 5.8 [38 Page(s)] API MPMS 5.8
2011.11.01 Manual of Petroluem Measurement Standards Chapter 5.8 Measurement of Liquid Hydrocarbons by Ultrasonic Flow Meters - Second Edition
59. API MPMS 4.5 [26 Page(s)] API MPMS 4.5
2011.11.01 Manual of Petroleum Measurement Standards Chapter 4.5 Master Meter Provers - Third Edition
60. API SPEC 6A ADD 1 CHINESE [11 Page(s)] API SPEC 6A ADD 1 CHINESE
2011.11.01 Specification for Wellhead and Christmas Tree Equipment - Twentieth Edition; Incorporates Errata: 11/2011
61. API RP 2FPS [208 Page(s)] API RP 2FPS
2011.10.01 Planning, Designing, and Constructing Floating Production Systems - SECOND EDITION
62. API RP 9B [44 Page(s)] API RP 9B
2011.10.01 Application, Care, and Use of Wire Rope for Oil Field Service - THIRTEENTH EDITION; INCORPORATED ERRATA:APRIL 2012; ERRATA: January 2013
63. API STD 2220 [38 Page(s)] API STD 2220
2011.10.01 Contractor Safety Performance Process - Third Edition
64. API RP 2221 [100 Page(s)] API RP 2221
2011.10.01 Contractor and Owner Safety Program Implementation - Third Edition
65. API MPMS 7.3 [42 Page(s)] API MPMS 7.3
2011.10.01 Manual of Petroleum Measurement Standards Chapter 7.3 Temperature Determination—Fixed Automatic Tank Temperature Systems - SECOND EDITION
66. API MPMS 7 ADD 1 [2 Page(s)] API MPMS 7 ADD 1
2011.10.01 Manual of Petroleum Measurement Standards Chapter 7 - Temperature Determination - First Edition
67. API STD 622 [42 Page(s)] API STD 622
2011.10.01 Type Testing of Process Valve Packing for Fugitive Emissions - Second Edition
68. API MPMS 11.2.4 ERTA [1 Page(s)] API MPMS 11.2.4 ERTA
2011.09.01 Manual of Petroleum Measurement Standards Chapter 11—Physical Properties Data Section 2, Part 4—Temperature Correction for the Volume of NGL and LPG Tables 23E, 24E, 53E, 54E, 59E, and 60E - First Edition
69. API MPMS 11.4.1 ERTA [1 Page(s)] API MPMS 11.4.1 ERTA
2011.09.01 Manual of Petroleum Measurement Standards Chapter 11—Physical Properties Data Section 4—Properties of Reference Materials Part 1—Density of Water and Water Volumetric Correction Factors for Water Calibration of Volumetric Provers - First Edition
70. API PUBL 4776 [72 Page(s)] API PUBL 4776
2011.09.01 A Guide to Understanding, Assessment, and Regulation of PAHs in the Aquatic Environment
71. API SPEC 6D ADD 2 CHINESE [15 Page(s)] API SPEC 6D ADD 2 CHINESE
2011.08.01 Specification for Pipeline Valves - Twenty-Third Edition; Incorporates Errata 6: 8/2011
72. API SPEC 5CT [284 Page(s)] API SPEC 5CT
2011.07.01 Specification for Casing and Tubing - NINTH EDITION
73. API SPEC 5CT CHINESE [321 Page(s)] API SPEC 5CT CHINESE
2011.07.01 Specification for Casing and Tubing - Ninth Edition; Incorporates Errata: September 2012
74. API MPMS 11.3.3 [28 Page(s)] API MPMS 11.3.3
2011.07.01 Manual of Petroleum Measurement Standards Chapter 11.3.3 Miscellaneous Hydrocarbon Product Properties - Ethanol Density and Volume Correction Factors - First Edition
75. API RP 2611 [54 Page(s)] API RP 2611
2011.06.01 Terminal Piping Inspection— Inspection of In-Service Terminal Piping Systems - First Edition
76. API RP 19G4 [62 Page(s)] API RP 19G4
2011.06.01 Practices for Side-pocket Mandrels and Related Equipment - FIRST EDITION; ISO 17078-4:2010 Adoption
77. API SPEC 19G3 [58 Page(s)] API SPEC 19G3
2011.06.01 Running Tools, Pulling Tools, and Kick-over Tools and Latches for Side-pocket Mandrels - FIRST EDITION; ISO 17078-3:2009 Adoption
78. API SPEC 17D [272 Page(s)] API SPEC 17D
2011.05.01 Design and Operation of Subsea Production Systems-Subsea Wellhead and Tree Equipment - Second Edition; Incorporating Errata: September 2011; ISO 13628-4 Adoption; Effective February 1, 2013 [for Valve and Actuator Design Validation (Test Requirements) Only]
79. API SPEC 9A [72 Page(s)] API SPEC 9A
2011.05.01 Specification for Wire Rope - Twenty-Sixth Edition; Incorporating Errata: October, 2012
80. API RP 13K [66 Page(s)] API RP 13K
2011.05.01 Recommended Practice for Chemical Analysis of Barite - Third Edition
81. API RP 13K RUSSIAN [66 Page(s)] API RP 13K RUSSIAN
2011.05.01 RECOMMENDED PRACTICE FOR CHEMICAL ANALYSIS OF BARITE - Third Edition
82. API SPEC 9A CHINESE [83 Page(s)] API SPEC 9A CHINESE
2011.05.01 Specification for Wire Rope - Twenty-sixth Edition
83. API SPEC 17D CHINESE [272 Page(s)] API SPEC 17D CHINESE
84. API SPEC 17D ERTA 2 CHINESE [3 Page(s)] API SPEC 17D ERTA 2 CHINESE
85. API TR 938-C [58 Page(s)] API TR 938-C
2011.04.01 Use of Duplex Stainless Steels in the Oil Refining Industry - Second Edition
86. API BULL D16 [75 Page(s)] API BULL D16
2011.04.01 Suggested Procedure for Development of a Spill Prevention Control and Countermeasure Plan - Fifth Edition
87. API RP 571 [372 Page(s)] API RP 571
2011.04.01 Damage Mechanisms Affecting Fixed Equipment in the Refining Industry - Second Edition
88. API RP 1615 [106 Page(s)] API RP 1615
2011.04.01 Installation of Underground Petroleum Storage Systems - Sixth Edition
89. API TR 934-B [42 Page(s)] API TR 934-B
2011.04.01 Fabrication Considerations for Vanadium-Modified Cr-Mo Steel Heavy Wall Pressure Vessels - First Edition
90. API RP 556 [78 Page(s)] API RP 556
2011.04.01 Instrumentation, Control, and Protective Systems for Gas Fired Heaters - Second Edition
91. API RP 2GEO [120 Page(s)] API RP 2GEO
2011.04.01 Geotechnical and Foundation Design Considerations - First Edition; ISO 19901-4:2003 Adoption
92. API BULL D16 TEMPLATE [88 Page(s)] API BULL D16 TEMPLATE
2011.04.01 Suggested Procedure for Development of Spill Prevention Control and Countermeasure Plans - Plan Template - Fifth Edition
93. API RP 556 RUSSIAN [140 Page(s)] API RP 556 RUSSIAN
94. API TR 2571 [82 Page(s)] API TR 2571
2011.03.01 Fuel Gas Measurement - First Edition
95. API STD 685 [186 Page(s)] API STD 685
2011.02.01 Sealless Centrifugal Pumps for Petroleum, Petrochemical, and Gas Industry Process Service - SECOND EDITION
96. API STD 616 [180 Page(s)] API STD 616
2011.01.01 Gas Turbines for Petroleum, Chemical, and Gas Industry Services - Fifth Edition
97. API HF3 [34 Page(s)] API HF3
2011.01.01 Practices for Mitigating Surface Impacts Associated with Hydraulic Fracturing - First Edition
98. API SPEC 10A [52 Page(s)] API SPEC 10A
2010.12.01 Specification for Cements and Materials for Well Cementing - Twenty-Fourth Edition
99. API SPEC 7-2 ADD 1 [46 Page(s)] API SPEC 7-2 ADD 1
2010.12.01 Specification for Threading and Gauging of Rotary Shouldered Thread Connections - First Edition; ISO 10424-2:2007 Adoption; Effective Date: June 2011
100. API RP 17A ADD 1 [18 Page(s)] API RP 17A ADD 1
2010.12.01 Design and Operation of Subsea Production Systems—General Requirements and Recommendations - Fourth Edition; ISO 13628-1:2005 Adoption
please every body can any one resend the link again i can not download API 625
Please share it again
Mr. netspyking,
Link is dead. Could you please, upload file again?Re: API Standard 625
Hi
Here I attached API 625-2010
API 625-2010.rar
Thanks in advance
Please upload again API 625
I also need API 625. Please upload it again guys.![]()
New link[link Point to another website Only the registered members can access]
Hi friends
Hope everything goes well with you
I have provided a huge gallery of newest petroleum software like: Petrel 2013.3, Eclipse 2013.1, Geoframe 2012, Paradigm 2011.3, Olga 7.2, OSP4.0.3, Mepo 4.2, Techlog 2013.2, RoXar RMS 2013.1, Ecrin 4.2.07, CMG 2013.1, S/M/T K/ingdom 8.8, Rokdoc 6.0.0.107, Desicion Space Desktop r5000.8.1.1, Drillworks 5000.8.1.1, Openworks r5000.8.1, VIP-Nexus 5000.4.4.0, Skua Gocad 2011.3, IPM 8.0, PetroMod 2013.1, Interactive Petrophysics 4.1, Openflow 2012.2, Pipesim 2013.1, Que$tor 3013Q1, FractPro 2013, Vista 13, GeoGraphix Discovery 2013, and so many other things ...
if anybody need Please contact me I will share with you. Also I need some applications Like IPM 8.1 hope you can kindly help me.
My E-mail is: slbsoft33@gmail.com
Cheers.
