Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 13 to 24 of 39
Thread: AD2000 German pressure vessel code
  1. Re: AD2000 German pressure vessel code
    Dear all i want AD200 design calculations urgentttt
  3. Re: AD2000 German pressure vessel code
    kindly mail me at najamshahzad2050@yahoo.com
    Najam, Here is the link for AD2000:
  6. #16
  7. Re: AD2000 German pressure vessel code
    Indeed thank you, I have used these as well.
  9. #18
    thank you..
  10. #19
    Jul 2008
    malaysia
    Blog Entries
    2
  11. Re: AD2000 German pressure vessel code
    Good morning to all,
    I would like to share my views regarding AD 2000 Merkblatt with respect to ASME codes as I have used and compared it for designing of high pressure Vessels.
    First and foremost, the AD code does not compromise with safety factors and nor it is limited in terms of design temperature. Let me be a bit more specific.
    Safety Factors :
    AD code uses allowable design stress based on yield stress of the material only and the safety factor depends on the ductile/brittle nature of the material. In fact the safety factor for ductile materials is 1.5 on yield stress i.e. same as ASME code. However the ASME code allowable values come out lower because in ASME code a minimum value of yield stress/safety factor and tensile stress/safety factor is used. So any material which has yield strength and tensile strength close to each other will always result in lower allowable stress for ASME code. But the allowable stress will be higher in AD code as it depends only on yield strength.
    So the thickness of pressure parts in AD code comes out to be lesser than ASME code.
    Infact ASME Sec VIII Div 2 was released in order to compete with the German code to provide for lower cost of equipments as ASME VIII Div 1 always gave higher thickness due to high safety factor and lesser inspection requirements.
    Also having a low safety factor in no way undermines the strength of equipment if the NDT performed is more stringent.
    That is why both ASME Sec VIII Div 2 and AD 2000 code provides for a more stringent NDT inspection in order to make up for low safety factor.
    Also regarding materials properties, AD2000 refers to the more established EN codes which can be used for higher design temperatures also.
    Hope this helps.
  12. Re: AD2000 German pressure vessel code
    Just to add to my above post,
    Kindly note that the AD merkblatt also requires additional testing at the product manufacturing stage.
    I.e it mandates hot tensile test to be performed for all materials at the maximum design temperature or 300 deg C (if design temperature is not mentioned) so that the actual yield strength at design temperature is verified.
    Thus the allowable stress based on yield strength which is considered during design can be safely used.
  13. Re: AD2000 German pressure vessel code
    Interesting stuff techwarrior08. Can you exactly pinpoint me where in AD2000 this is outlined? These details help a lot in selecting the proper design code for me. Thanks again.
  14. Re: AD2000 German pressure vessel code
    Quote Originally Posted by ThaMaestro View Post
    Hello ThaMaestro,
    Regarding the above mentioned details, the same are indicated in the following clauses of AD2000 Merkblatt.
    1. For Classification of Vessel, its safety category & CE stamping refer Pressure Equipment Directive at start of code.
    2. For design & allowable stress refer Section B0 & B1
    3. For detailed inspection table of welded joints refer Section HP5/3
    4. For Material testing & information refer Section W0 & W1
    As per my experience, AD2000 Merkblatt will always score over ASME Sec VIII Div 1 in terms of thickness and in case of Div 2, it depends on the material that is selected but the difference in thickness is comparatively smaller. It also depends on the equipment manufacturer with which code they are comfortable with.
  16. Re: AD2000 German pressure vessel code
    I think I may have found the exact reference which underlines your statement on hot tensile testing, it is found in W1 section 3.3 and 3.4, W3/1 section 3.1 and 7.1.2. These sections apply to specific product forms, i.e. flat products (plate) and cast iron, respectively.
    THerefore the remark you made has to be within a certain context. As I understand it, it does not apply in general to all types of materials applied within AD2000 ...
  1. Australian Pressure Vessel Code
    By praphulla.phirke in forum Mechanical Engineering
    Last Post: 08-21-2017, 02:35 AM
  2. China gb pressure vessel code
    By kafmaidi in forum Mechanical Engineering
    Last Post: 07-27-2017, 10:04 AM
  3. ASME pressure vessel code
    By kunu2011 in forum Mechanical Engineering
    Last Post: 09-05-2013, 12:30 PM
  4. CSA B51-09 Boiler, Pressure Vessel and Pressure Piping Code Need
    By cpchonburi in forum Mechanical Engineering
    Last Post: 08-05-2011, 01:14 AM
  5. CSA B51-09 Boiler, Pressure Vessel and Pressure Piping Code
    Last Post: 07-29-2011, 06:48 AM
