Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 13 to 24 of 48
Thread: etap 24.0.0 Download + C.r.a.c.k
  1. #13
    Re: etap 24.0.0 Download + C.r.a.c.k
    Quote Originally Posted by hopeful View Post
    uaytac , Can you send me a sample lic.dat by private message?
    The HWID program generates an identification number for the computer it is installed on. We need to send this HWID number to someone (whoever craxxxxked the program) and then copy the lic.dat file created by that person to the installation folder.
    Quote Originally Posted by uaytac View Post
    And who is this "someone"??
    Quote Originally Posted by orlyboy View Post
    Cra***k/******** owner. I dont know who he is.
    -Run "1-GetHWID.exe" and then select "Get Hardware ID" and then copy and send Hardware ID to your software provider for receiving license file .
  6. Re: etap 24.0.0 Download + C.r.a.c.k
    the program is packed by Themida/WinLicense, which allows create hardware locked licenses.
    the missing file is therefore the one generated by the packer which integrates the HWID option.
  7. #17
    I dont have license file. I have just HWID number.
  9. #18
    What we need is the License Key g.e.n.e.r.a.t.o.r
    maybe a self coded program that generates....
  10. Re: etap 24.0.0 Download + C.r.a.c.k
    Job is not as easy as it sounds, as a starting point you need to at least have an original license even if it won't work due to the HWID.
  11. Re: etap 24.0.0 Download + C.r.a.c.k
    Do you have the installation file for ETAP 24.03? I only need the installation file.
  12. Re: etap 24.0.0 Download + C.r.a.c.k
    f79nSQ, If you only need installation files, you must have a working solution ***, share it and others will do the same.
  13. Re: etap 24.0.0 Download + C.r.a.c.k
    Thank you luis4170
    Apparently, some kind of K.e.y.g.e.n is required to generate the license file from the hardware ID.
    Could anyone share this K.e.y.g.e.n?
  14. Re: etap 24.0.0 Download + C.r.a.c.k
    Thanks luis4170
    Apparently, some kind of key.g.en is required to generate the license file from the Hardware ID.
    Could anyone share it?
  16. Re: etap 24.0.0 Download + C.r.a.c.k
    The solution cannot be generated if we do not have the missing file "lic.dat" to allow the protection envelope to be removed and thus the HWID limitation to be removed.
  1. Etap-18
    By raj151857 in forum Electrical & Power Engineering
    Last Post: 02-14-2025, 08:01 AM
  2. etap and smart plant electrical download
    By Nald in forum Electrical & Power Engineering
    Last Post: 12-07-2012, 05:40 PM
