Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 13 to 24 of 26
Thread: Cdegs 2k
  1. Re: Cdegs 2k
    Yea googling is of no help , cant find it ,Let me know if someone shares the files
    Re: Cdegs 2k
    Quote Originally Posted by rohitsehgal View Post
    Exactly in the same situation.
    I have however received PM from a helpful member saying that these files are readily available in Google.
    I requested the link however the gentlemen has said that "just google by name"
    I have tried but cannot seem to find the files in Google.
    Lets just wait for Himmelstern to share those files.
    I fear you can ever find those files. It is because antivirus is very hostile towards those files. I had also them but my kaspersky deleted them. That must be the situation with many.
    Re: Cdegs 2k
    Please, Please download those links
    1. [link Point to another website Only the registered members can access]
    2. [link Point to another website Only the registered members can access]
    3. [link Point to another website Only the registered members can access]
    4. [link Point to another website Only the registered members can access]
    Quote Originally Posted by himmelstern View Post
    there are some vide tutorials of SES CDEGS on youtube
  6. Re: Cdegs 2k
    Thank you very much himmelstern
    I will download and give these a go.
    Hope these works, thanks again for your continued help.
  7. #17
    Re: Cdegs 2k
    did you meake ses Cdegs 2k run?
    other video tutorialas made from other user
  9. #18
    Oct 2009
    Dehli, Delhi, India, India
    Blog Entries
    1
    Re: Cdegs 2k
    Dear Friends is it work with win 10 64 bit??
  10. Re: Cdegs 2k
    Hi Himmelstern,
    Thank you again for the files, i copied all the ***** files and now it does not come with the error message however when i tried using RESAP to add soil resistivity values, it did not produce a multilayer soil model.
    It is quite possible that i have to learn to run the software, i will be in touch. I am assuming you have been able to use 2K version.
    Question for you - You have also shared CDEGS 15.1.4080, does this version also work the same way? or does this one does not have the required ***** files?
    Rohit
  11. Re: Cdegs 2k
    Please install as per the install guide, the window requirements are listed in the install guide.
    Hope this helps.
  12. #21
    Re: Cdegs 2k
    Quote Originally Posted by raj151857 View Post
    I installed file 1; on win XP; using vmware virtual machine:
    I cant find those files DOWNTVDD.DLL; VSAUTHD.VXD; DS1410d.SYS; sc32w.dll to pa-tc-h it
    even when install it and run with 2000 year date on Virtual Machine.
    Hi Himmelstern,
    I make run ses cdegs 2k* but found some troubles
    when I run MALZ a module for high frecuency grounding (lightning) to make it run or HIFREQ a module for Eelectromagnetic Compatibility studies for grounding meshes foud those errors:
    but when I run the application it appear that works correctly and perfect; but not
    it happened some time before
  13. #22
    Re: Cdegs 2k
    I think some users had SES CDEGS pa:tched but don't share
    Quote Originally Posted by nodongle.biz View Post
    Prepare solution is easy.
    I have 15.1 with solution. All modules is activated in the HASP SRM key emulator.
    Quote Originally Posted by ingo_dingo View Post
    Has any one got the tutorial for this Awesome but expensive program?
  14. Re: Cdegs 2k
    Hi himmelstern
    do you by any chance have you tube videos for the 2k version, i see you have shared CDEGS videos but they are for latest CDEGS version.
    thanks for your help
  16. Re: Cdegs 2k
    I note you got the errors but did it eventually work or not?
    In my case "Data Entry" works but when i try and run RESAP in "Engineering" it does not work.
    Please let me know
  1. Cdegs 15.4
    By ingo_dingo in forum Electrical & Power Engineering
    Last Post: 01-04-2025, 06:14 PM
  2. Ses-cdegs
    By raj151857 in forum Electrical & Power Engineering
    Last Post: 11-28-2017, 01:35 PM
  3. Cdegs 15.6
    By hatashita in forum Electrical & Power Engineering
    Last Post: 04-01-2017, 10:18 AM
  4. cdegs 14v
    By raejang3 in forum Electrical & Power Engineering
    Last Post: 08-14-2014, 07:26 AM
  5. Cdegs?
    By abes in forum Electrical & Power Engineering
    Last Post: 01-18-2014, 03:39 PM
