Page 17 of 89 FirstFirst ... 7 15 16 17 18 19 27 67 ... LastLast
Results 193 to 204 of 1065
Thread: ASTM Book Volume 2015
Hybrid View
Previous Post Previous Post   Next Post Next Post
    Re: ASTM Book Volume 2015
    ASTM - STP 945 - Fracture Mechanics; 18th Symposium 1985
    .b1 pass: egpet.net
  2. #2
    Hi, Marty:
    Can you upload A955 SS rebar specification sin Book 1.04?
  3.    Sponsored Links
  4. #3
    11.01 Water (I)
    .b1 pass: egpet.net
  5. Re: ASTM Book Volume 2015
    Dear Marty Thompson
    please share astm stp 470 and 470a and 470b
  6. #5
    ASTM - STP 470A - Manual on the Use of Thermocouples in Temperature Measurement 1974
    .b1 pass: egpet.net
  7.    Spons.
  8. #6
    ASTM - STP 470B - Manual on the Use of Thermocouples in Temperature Measurement 1981
    .b1 pass: egpet.net
  9. #7
    ASTM - STP 470 - Manual on the Use of Thermocouples in Temperature Measurement 1970
    .b1 pass: egpet.net
  10. #8
    New 1.01 files 12-01-15
    A106A106M-15 Standard Specification for Seamless Carbon Steel Pipe for High-Temperature Service
    A213A213M-15c Standard Specification for Seamless Ferritic and Austenitic Alloy-Steel Boiler, Superheater, and Heat-Exchanger Tubes
    A453A453M-15 Standard Specification for High-Temperature Bolting, with Expansion Coefficients Comparable to Austenitic Stainless Steels
    A960A960M-15 Standard Specification for Common Requirements for Wrought Steel Piping Fittings
    A1014A1014M-15 Standard Specification for Precipitation-Hardening Bolting (UNS N07718) for High Temperature Service
    A1085A1085M-15 Standard Specification for Cold-Formed Welded Carbon Steel Hollow Structural Sections (HSS)
    Attached Files Attached Files
  11. #9
    New 1.02 files 12-01-15
    A159-83(2015) Standard Specification for Automotive Gray Iron Castings
    A197A197M-00(2015) Standard Specification for Cupola Malleable Iron
    A278A278M-01(2015) Standard Specification for Gray Iron Castings for Pressure-Containing Parts for Temperatures Up to 650°F (350°C)
    A319-71(2015) Standard Specification for Gray Iron Castings for Elevated Temperatures for Non-Pressure Containing Parts
    A323-05(2015) Standard Specification for Ferroboron
    A436-84(2015) Standard Specification for Austenitic Gray Iron Castings
    A481-05(2015) Standard Specification for Chromium Metal
    A483A483M-10(2015) Standard Specification for Silicomanganese
    A495-06(2015) Standard Specification for Calcium-Silicon Alloys
  12. #10
    More New 1.02 files 12-01-15
    A550-06(2015) Standard Specification for Ferrocolumbium
    A571A571M-01(2015) Standard Specification for Austenitic Ductile Iron Castings for Pressure-Containing Parts Suitable for Low-Temperature Service
    A601A601M-10(2015) Standard Specification for Electrolytic Manganese Metal
    A701A701M-10(2015) Standard Specification for Ferromanganese-Silicon
    A799A799M-10(2015) Standard Practice for Steel Castings, Stainless, Instrument Calibration, for Estimating Ferrite Content
    A802-95(2015) Standard Practice for Steel Castings, Surface Acceptance Standards, Visual Examination
    A834-95(2015) Standard Specification for Common Requirements for Iron Castings for General Industrial Use
    A835A835M-10(2015) Standard Specification for Sizes of Ferroalloys and Alloy Additives
    A922-05(2015) Standard Specification for Silicon Metal
    A957A957M-15a Standard Specification for Investment Castings, Steel and Alloy, Common Requirements, for General Industrial Use
    A1025A1025M-10(2015) Standard Specification for Ferroalloys and Other Alloying Materials, General Requirements
    A1062-10(2015) Standard Specification for Steel Castings Sampling
  13. #11
    New 1.03 files 12-01-15
    A109A109M-15 Standard Specification for Steel, Strip, Carbon (0.25 Maximum Percent), Cold-Rolled
    A231A231M-15 Standard Specification for Chromium-Vanadium Alloy Steel Spring Wire
    A401A401M-15 Standard Specification for Steel Wire, Chromium-Silicon Alloy
    A568A568M-15 Standard Specification for Steel, Sheet, Carbon, Structural, and High-Strength, Low-Alloy, Hot-Rolled and Cold-Rolled, General Requirements for
    A606A606M-15 Standard Specification for Steel, Sheet and Strip, High-Strength, Low-Alloy, Hot-Rolled and Cold-Rolled, with Improved Atmospheric Corrosion Resistance
    A635A635M-15 Standard Specification for Steel, Sheet and Strip, Heavy-Thickness Coils, Hot-Rolled, Alloy, Carbon, Structural, High-Strength Low-Alloy, and High-Strength Low-Alloy with Improved Formability, General Requirements for
    A684A684M-15 Standard Specification for Steel, Strip, High-Carbon, Cold-Rolled
    A370-15 Standard Test Methods and Definitions for Mechanical Testing of Steel Products
  14.    Spons.
  15. #12
    New 1.04 files 12-01-15
    A20A20M-15 Standard Specification for General Requirements for Steel Plates for Pressure Vessels
    A767A767M-09(2015) Standard Specification for Zinc-Coated (Galvanized) Steel Bars for Concrete Reinforcement
  1. ASTM D1250 - Volume 07 Tables 53A & 54A
    By el hassan in forum Laboratory Measurements
    Last Post: 02-12-2019, 02:05 PM
  2. ASTM Handbook Volume 3.02 and 3.03
    By id24_band@yahoo.com in forum Materials Science &Corrosion
    Last Post: 07-21-2017, 10:23 PM
  3. Astm a780 / a780m - 09(2015)
    By kavita_00 in forum Mechanical Engineering
    Last Post: 03-16-2016, 05:23 AM
  4. ASTM Volume 08.03 (D4097 , D3299)
    By Virgule in forum Mechanical Engineering
    Last Post: 02-16-2013, 06:00 PM
