Dear achmed Nur
Many thanks for your Help
Dear achmed Nur
is anyone has the following standards
UL 10B
UL 10C
UBC(Uniform Building Code Standards)7-2" fire tests of door Assemblies"
UL 10B-2008 Standard for Fire Tests of Door Assemblies.pdf 549.8 KB
UL 10C-2009 Positive Pressure Fire Tests of Door Assemblies.pdf 671.55 KB
Hi,
ANSI/ISA 75.08-1999
BSR/ISA 75.10.02-1999 (R200x)
pls send the above pinch valve standards,
hi
is one has UL 50 & UL 1203
Thank u very much Achmud for ur generous effort it really helped.
But the part 3 of the BS 4485 was decrypted or something and it contained only 25 pages and not the full code.
It would be of immense help if u could post the complete PDF file.
Moreover if u have any refence document for NDCT thermal performance calculation or evaluation from vendor or whatever..i would be very thankful to u..
Thanks& Regards
Prasenjit
Dear Sambun please share UL std for Gas detector if possible.
Anyone have the following ASME standards?
ASME PTC 20.1-1977 (Reaf 1982), Speed and Load Governing Systems for Steam Turbine-Generator Units
ASME PTC 20.2-1965 (Reaf 1986), Overspeed Trip Systems for Steam Turbine-Generator Units
ASME PTC 20.3-1970 (Reaf 1980), Pressure-Control Systems Used on Steam Turbine-Generator Units
NEMA SM 23-1985, Steam Turbines for Mechanical Drive Service
NEMA SM 24-1985, Land Based Steam Turbine Generator Sets, 0 to 33 000 kW
ANSI C50.10-1990, American National Standard General Requirements for Synchronous Machines
Thanks in advance.
