Page 15 of 31 FirstFirst ... 5 13 14 15 16 17 25 ... LastLast
Results 169 to 180 of 368
Thread: API Code Collections
  1. #169
    E&P Historical Addenda/Errata are at this link...
    Spec Q1, Specification for Quality Programs for the Petroleum, Petrochemical and Natural Gas Industry, 7th Edition, June 2003
    Errata, August 2003
    Spec 5B, Threading Gauging, and Thread Inspection of Casing, Tubing and Line Pipe Threads, 14th Edition, August 1996
    Addendum, March 2004 (Includes Errata, April 1998)
    Bull 5C3, Bulletin on Formulas and Calculations for Casing, Tubing, Drill Pipe, and Line Pipe Properties, 6th Edition, October 1994
    Supplement 1, April 1999
    Spec 6A718, Specification of Nickel Base Alloy 718 (UNS NO7718) for Oil and Gas Drilling and Production Equipment, First Edition, March 2004
    Addendum, March 2006 (Includes Errata, March 2005)
    Spec 12F, Specification for Shop Welded Tanks for Storage of Production Liquids, 11th Edition, November 1, 1994
    Errata, February 2007
    RP 19B, Evaluation of Well Perforators, 1st Edition, November 2000
    Errata, September 2001
  3. Please,
    I need API STD 537 - ED. 2
    Does anyone has to share???
    Thanks!
    Pipeline Transportation Addenda/Errata Publications are at this link...
    RP 1102, Steel Pipelines Crossing Railroads and Highways, Seventh Edition, December 2007
    Errata 2, May 2010
    Std 1104, Welding of Pipelines and Related Facilities, 20th Edition, October 2005
    Errata/Addendum, July 2007
    Errata 2, December 2008
    RP 1114, Recommended Practice for the Design of Solution-Mined Underground Storage Facilities, First Edition, June 1994
    Errata, July 2007
    RP 1117, Recommended Practice for Movement of In-service Pipelines, 3rd Edition, July 2008
    Errata 1, December 2008
    Errata 2, August 2009
    RP 1166, Excavation Monitoring and Observation, First Edition, November 2005
    Errata, December 2006
  6. #172
    Refining Addenda/Errata Publications are here...
    Std 521, Pressure-relieving and Depressuring Systems, 5th Edition, January 2007
    Errata, June 2007
    Addendum, May 2008
    Std 526, Flanged Steel Pressure-relief Valves, 6th Edition, April 2009
    Errata, May 2009
    Std 530, Calculation of Heater Tube Thickness in Petroleum Refineries, 6th Edition, September 2008
    Errata, January 2009
    Std 600, Steel Gate Valves—Flanged and Butt-welding Ends, Bolted Bonnets, 12th Edition, September 2009
    Errata, November 2009
    Std 607, Testing of Valves—Fire Type-testing Requirements, 5th Edition, June 2005
    Errata, November 2008
    Std 611, General-purpose Steam Turbines for Petroleum, Chemical, and Gas Industry Services, 5th Edition, March 2008
    Errata, May 2008
    Std 613, Special Purpose Gear Units for Petroleum, Chemical and Gas Industry Services, 5th Edition, February, 2003
    Errata, November 2006
    Std 614, Lubrication, Shaft-sealing and Oil-control Systems and Auxiliaries, 5th Edition, April, 2008
    Errata, May 2008
    Std 617, Axial and Centrifugal Compressors and Expander-compressors for Petroleum, Chemical and Gas Industry Services, 7th Edition, July 2002
    Errata, June 2003
    Std 618, Reciprocating Compressors for Petroleum, Chemical, and Gas Industry Services, Fifth Edition, December 2007
    Errata 2, July 2010
    Std 650, Welded Steel Tanks for Oil Storage, 10th Edition, November 1998
    Errata, April 2007
    Std 672, Packaged, Integrally Geared Centrifugal Air Compressors for Petroleum, Chemical and Gas Industry Services, 4th Edition, March 2004
    Errata, October 2007
    Errata 2, July 2010
    Std 673, Centrifugal Fans for Petroleum, Chemical and Gas Industry Services, 2nd Edition, January 2002
    Errata, October 2002
    Std 682, Pumps—Shaft Sealing Systems for Centrifugal and Rotary Pumps, 3rd Edition, September 2004
    Std 685, Sealless Centrifugal Pumps for Petroleum, Heavy Duty Chemical, and Gas Industry Services, 1st Edition, October 2000
    RP 934-A, Materials and Fabrication of 2 1/4Cr-1Mo, 2 1/4Cr-1Mo-1/4V, 3Cr-1Mo, and 3Cr-1Mo-1/4V Steel Heavy Wall Pressure Vessels for High-temperature, High-pressure Hydrogen Service, Second Edition, May 2008
    Addendum 1, February 2010
    Std 2000, Venting Atmospheric and Low-pressure Storage Tanks: Nonrefrigerated and Refrigerated, 5th Edition, April 1998
    Errata, November 1999
    Refining Historical Addenda & Errata are here...
    Std 560, Fired Heaters for General Refinery Services, 3rd Edition, May 2001
    Errata, January 2002
    API 653, Tank Inspection, Repair, Alteration, and Reconstruction, 3rd Edition, December 2001
    Errata 1, April 2008
  7. Hi All!
    Does anyone have a copy of API Publication 4615
    Emission Factors for Oil and Gas Production Operations
  9. Api 941
    Does Anyone have this Please:
    API 941 "Steels for Hydrogen Service at Elevated Temperatures and Pressures in Petroleum Refineries and Petrochemical Plants"
    Greatings
  10. #175
    [link Point to another website Only the registered members can access] API - Technical Report 941 Sept. 2008 - The Technical Basis Document for API RP 941.pdf
    API RP 941 7th Ed. Aug. 2008 - Steels for Hydrogen Service at Elevated Temperatures and Pressures in Petroleum Refineries and Petrochemical Plants.pdf
  11. Quote Originally Posted by Nabilia View Post
    Thanks Nabilia, you are the best.
  12. I need API RP2A-2005,help me please.
  13. #178
    API RP 2A-WSD 21st Ed. Dec. 2002 w: Dec. 2002 & Oct. 2005 Erratas and Supplements 1 & 2 - Recommended Practice for Planning, Designing and Constructing Fixed Offshore Platforms—Working Stress Design.pdf
    API RP 2A-WSD Errata and Supplement 3 Oct. 2008.pdf
  14. thanks for these file,but if you have newest edition,please send me those because these are for 1997 &1998.
  16. #180
    Quote Originally Posted by rezajun View Post
    Exactly what files are you referring to? The last ones posted are from 2005 with 2008 eratta
  1. MY Audel Books Collections
    By Han Ah kwang in forum General Engineering
    Last Post: 01-16-2014, 12:18 PM
  2. Collections of oil and gas Books
    By ameer in forum Mechanical Engineering
    Last Post: 12-05-2013, 03:52 AM
  3. AWS great collections [ask]
    By menarizki in forum Mechanical Engineering
    Last Post: 05-22-2013, 10:09 PM
  4. Replies: 4
    Last Post: 06-12-2012, 06:35 AM
  5. standards collections
    Last Post: 04-03-2010, 07:08 PM
