Page 12 of 26 FirstFirst ... 2 10 11 12 13 14 22 ... LastLast
Results 133 to 144 of 310
Thread: API Standards
  1. #133
    PLS.,any one provide me ANSI/API 661.API 650 & ASME SEC.III DIV 1 (LATEST EDITION OR OLDER EDITION)
    Thanks in advance
    API Standard 661 6th Ed. Feb. 2006 - Air-Cooled Heat Exchangers for General Refinery Service - ISO 13706; 2005.pdf
    API Standard 650 11th Ed. June 2007 w:Ad2 Nov. 2009 - Welded Tanks for Oil Storage - Full.pdf
    Quote Originally Posted by davidwai View Post
    Hi All,
    I'm looking for;
    API RP 2SK
    API RP 2FPS
    API RP 2RD
    API RP 2SM
    API RP 17A,B
    API RP 2A
    API RP 1111
    API RP 17J
    API RP 17K
    Your good deed for sharing is highly appreciated. Thanks in advance
    API SERIES 2 – OFFSHORE STRUCTURE
    SERIES 2 - OFFSHORE STRUCTURE.rar 65.45 MB
    Consist of:
    API RP 2A LRFD 1st Ed 2003 - Recommended Practice for Planning, Designing and Constructing Fixed Offshore Platforms - Load and Resistance Factor Design
    API RP 2A-WSD 21st Ed, 2005 - Recommended Practice for Planning, Designing and Constructing Fixed Offshore Platforms - Working Stress Design
    API SPEC 2B 6th Ed 2002 - Specification for the Fabrication of Structural Steel Pipe
    API SPEC 2C 6th Ed 2004 - Specification for Offshore Cranes
    API RP 2D 5th Ed 2003 - Recommended Practice for Operation and Maintenance of Offshore Cranes
    API SPEC 2F 6th Ed 1997 - Specification for Mooring Chain (ANSI STANDARD)
    API RP 2FPS 1st Ed 2001 - Recommended Practice for Planning, Designing and Constructing Floating Production System
    API SPEC 2H 9th 2007 - Specification for Carbon Manganese Steel Plate for Offshore Platform Tubular Joints
    API RP 2I 2nd Ed 1996 - In-Service Inspection of Mooring Hardware for Floating Drilling Units Second Edition
    API RP 2L 4th Ed 1996 - Recommended Practice for Planning, Designing, and Constructing Heliports for Fixed Offshore Platforms
    API SPEC 2MT1 2nd Ed 2001 - Specification for As-Rolled Carbon Manganese Steel Plate with Improved Toughness for Offshore Structures
    API SPEC 2MT2 1st Ed 2002 - Rolled shaped with improve Notch Toughness
    API RP 2N 2nd Ed 1995 - Recommended Practice for Planning, Designing, and Constructing Structures and Pipelines for Arctic Conditions
    API RP 2RD 1st Ed 1998 - Design of Risers for Floating Production Systems (FPSs) and Tension-Leg Platforms (TLPs) (ANSI STANDARD)
    API RP 2SK 2nd Ed 1996 - Recommended Practice for Design and Analysis of Stationkeeping Systems for Floating Structures
    API RP 2T 2nd Ed 1997 - Recommended Practice for Planning, Designing, and Constructing Tension Leg Platforms (ANSI STANDARD)
    API BULL 2U 2nd Ed 2000 - Bulletin on Stability Design of Cylindrical Shells
    API BULL 2V 2nd Ed 2000 - Bulletin on Design of Flat Plate Structures
    API SPEC 2W 4th Ed 1999 - Specification for Steel Plates for Offshore Structures, Produced by Thermo-Mechanical Control Processing (TMCP)
    API RP 2X 4th Ed 2004 - Recommended Practice for Ultrasonic and Magnetic Examination of Offshore Structural Fabrication and Guidelines for Qualification of Technicians
    API SPEC 2Y 5th Ed 2006 - Specification for Steel Plates, Quenched-and-Tempered, for Offshore Structures Third Edition
    API RP 2Z 3rd Ed 1998 - Recommended Practice for Preproduction Qualification for Steel Plates for Offshore Structures (ANSI STANDARD)
    MISSING LINKS :
    API RP 2FB - Recommended Practice for the Design of Offshore Facilities Against Fire and Blast Loading
    API Bull 2HINS - Guidance for Post-hurricane Structural Inspection of Offshore Structures
    API BULL 2 INT-DG - Interim Guidance for Design of Offshore Structure for Hurricane Condition
    API BULL 2 INT-EX - Interim Guidance for Assessment Existing Offshore Structures for Hurricane Conditions
    API BULL 2 INT-MET - Interim Guidance for for Hurricane C onditions in the Gulf of Mexico
    API BULL 2S - Design of Windlass Wildcats for Floating Offshore Structures
    API RP 2SM - Recommended Practice for Design, Manufacture, Installation and Maintenance of Synthetic Fibre Ropes of Offshore Mooring
    B API ULL 2TD - Guidance for Tie Down for Offshore Production Facilities for Hurricane Seasons
    API RP 95J - Gulf of Mexico - Jack up Operation for Hurricane Seasons - Interim Recommendations
    SOMEBODY WHO HAS ABOVE MISSING LINKS, VERY APPRECIATE IF YOU COULD UPLOAD IT !!!!!!
  6. Dear Naeem,
    I would appreciate if you have preparatory course material for API 510. With latest edition
    M.Ali
  7. #137
    Thanks for API 661 6th Edition
  9. #138
    kee*p upd@t!ing ple@se
  10. dear friend
    please share these documents:
    -API 509
    -API 601
    -ANSI B1.1
    -ANSI B2.1
    -ANSI16.10
    -ANSI B16.11
    -ANSI B16.20
    -ANSI B16.21
    tq dear friend
  11. Can anybody help me for API MPMS Chapter 11.1.-2004. I would also be grateful for the calculation for PC (Excel spreadsheet).
  12. #141
    hi naeem,
    could you send me those API to: samavati_raheleh@yahoo.com,I need The API 13A,13B on drilling fluids to specific
    Appreciate for your kind help..
    Thanks a lot
  13. Hi, someone, please, have some software of blasting for share or exchange??? cheers
  14. #143
    Quote Originally Posted by raheleh samavati View Post
    hi naeem,
    Thanks a lot
    API Specification 13A 18th Ed. Feb. 2010 - Specification for Drilling Fluid Materials ISO 13500;2009.pdf 0.973 MB
    API RP 13B-1 4th Ed. Mar. 2009 - Recommended Practice for Field Testing Water-based Drilling Fluids - ISO 10414-1;2008.pdf 1.188 MB
    API RP 13B-2 3rd Ed. Feb. 2003 - Recommended Practice Standard Procedure for Field Testing Oil-Based Drilling Fluids with addendum 1.pdf 3.785 MB
  16. #144
    wow,thanks a million for these API stuffs!
  1. API standards
    By ayoubhk in forum Safety And Environment
    Last Post: 12-15-2014, 02:29 AM
  2. ISA standards
    By kaicyem in forum Instrumentation & Control
    Last Post: 06-21-2014, 12:26 AM
  3. BS/DIN/EN - STANDARDS FOR P&ID's
    By ceeee83 in forum Engineering Certificates
    Last Post: 04-27-2013, 08:10 AM
  4. Need the following IEC standards
    By SA_FETY in forum Safety And Environment
    Last Post: 12-09-2011, 05:11 AM
  5. IEC Standards
    By sunset_eagle in forum Electrical & Power Engineering
    Last Post: 10-25-2010, 08:52 PM
