it's a problem related with the ***** of 12.6 version, for every presentation that you create it shows taht error of the parameter is incorrect.
if you work with the star module and zoom in and out the one line diagram the software shows another error with the save command. but this is the etap 14.1 thread.
why you create polemics insulting another users?. there is no place for it, the software shows that error when you you work with it. for more ovl you create the shoftware shows the parameter is incorrect. or more star views that you work the software becomes inestable. thats a fact. you don't have to insult me for that.
all people work with this c.r.a.c.k and only you say this c.r.a.c.k is fault.
why?
i don't insult to real person.
you are real or seller?
if you real person then you have problem(windows and other...)
if you are seller so be silent because this c.r.a.c.k is amazing
that's true
that's the only cr.ack version that works ok after etap 7. thanks for it, because every one can use etap 12.5. but it's inestable, or when you create a big one line diagram and put it in a composite network, and you put a composite network inside another composite network, and another system inside at a composite network, 12.6 versión becomes unestable, that happnens of very big systems.
ETAP 11 version is not unestable, but it's hard to cr.ack}
why I complain, if it's free.............![]()
Are we referring to etap 12.6? It doesnt mean that if all work on this its perfect, you should know that. The number of people doesnt justify it. An analysis was given before, maybe you are new to this forum and havent read those.
It also doesnt mean if i have seen the errors, im a reseller then. What are basis? Can you prove it? If you havent experienced errors, then good. Maybe you are only using load flow and SC.
Still, for now, it is the best we have and i thank the uploader for that.
since no one is talking about ETAP 14.1 anymore....
Anyone want some porn?
