Page 11 of 25 FirstFirst ... 9 10 11 12 13 21 ... LastLast
Results 121 to 132 of 292
Thread: Etap 14
  1. Re: Etap 14
    @sophaholic : It seems to be a potable or ready to run show. Not need installation. Just run ETAP executable file. but not *****ed.
  3. Re: Etap 14
    Quote Originally Posted by sanyad View Post
    @sanyad
    I knew it potable, when I executable etaps64.exe --> required license manager
    When I apply "etap 14 faulty solution" ( I got from this forum, but forgot where), the license manager box is disappeared. So, I test to open example file but a message box appear and said : there is no DB ODBC setup for Etap and there is no DB DSN setup for Etap ...
    I stuck in this step ... Any ideas how to setup DB ODBC and DB DSN ?
  5. Re: Etap 14
    @sophaholic
    Could you please reupload "etap 14 faulty solution"?
    It seems that original link has been removed.
  6. Re: Etap 14
    @sophaholic : Sorry Brother. I dont know how to do that. Rather I didn't have that faulty Etap solution you mentioned here. Will wait for a perfect med. Till then Etap12.6 can be used. We are even not harnessing the capabilities of 12.6. People have done good job in v5......v11.
    Don't worry , meds will be available in this or other chinese forums. Time is the key..
  7. #125
    Could someone reupload etap fault solution? I want to try this version of etap..
    Sent from Mars using Tapatalk
  9. #126
    Re: Etap 14
    I was able to make this version of etap run by manually configuring the OBDC setup.
    Go to Others Folder
    Install SQL
    Run *.bat
    Here is my review of using the software: (i am assuming that the c.r.a.c.k. -"etap_faulty_solution" works ok")
    1. This is for 64 bit.
    2. This is portable. Errors are expected.
    3. The c.r.a.c.k. removes the Etap's dependency to its license manager.
    4. Reporting doesn't work.
    5. Analysis modules are okay so far.
    6. Study Case editor runs okay during the first few moments. If report manager is click. The Study Case Editor says "resource is required". Maybe this is due to that fact that this version is not installed. It needs some program dependencies.
    7. Panel Systems sometimes works. If report manager is click. The Study Case Editor says "resource is required". Maybe this is due to that fact that this version is not installed. It needs some program dependencies.
    I haven't tried all features. I also havent tried auto star feature. But etap star works.
    *****UPDATE******
    The features changes in due time. Some components (for ex. motors), don't work after some time. Same with the other components. I guess I 'll have to ETAP v11 again. hehe..
  10. #127
    Re: Etap 14
    if 100USD deal is on above that..have to think.i thought this forum for sharing oso
  11. Re: Etap 14
    ETAPS64.exe must be runned first time on administrator mode
    before run ETAP you must install:
    ETAP requires the following prerequiste software.
    These software will be automatically installed if not detected.
    • Microsoft .NET Framework v4.0
    • Microsoft .NET Framework v4.5
    • Microsoft SQL Server 2012 Express (x64)
    • Microsoft SQL Server 2012 Express LocalDB (x64)
    • Microsoft Windows Update (KB2670838)
    this version is very faulty, some times you are going to edit components and the program shows errors, like the the component is not installed, you must close and open again ETAP 14. "resource is required"
    a friend told me that he bought an original version of ETAP 14 and this is very faulty. beacuse software is not so friendly with MySQL, software is on adaptation process (and left using MS access database that used on previus versions), software has too many bugs, is not related with meds, he must update continusly ETAP to solve this, ETAP 14 version is like a Windows vista example, is more beautyful but very faulty. he downloaded the last version of 14,1 and works ok, but some times he need to call to ETAP technical service, and they stay all the day configuring this software to run ok by a remote connection.
    prefer using etap 12.6.5 version. but this also fails with complex and big systems and to many composite network. Etap 11 works ok and functions are almost the same
    Other Software Requirements
    • Internet Explorer® 10 or higher (or minimum version level specified by the Operating System)
    • Microsoft .NET Framework v3.5 (SP1)
    • Microsoft SQL Server Compact 3.5 (SP2)
    • Microsoft SQL Server 2012 Native Client (x64)
    • Microsoft SQL Management Studio 2012 (x64)
  12. #129
    Re: Etap 14
  13. #130
    Re: Etap 14
  14. #131
    Re: Etap 14
    discount pls
  16. Re: Etap 14
    Quote Originally Posted by surgeArrester View Post
    Here's Faulty Solution:
    regards
    SANYAD
  1. Etap 12.6
    By shengna in forum Electrical & Power Engineering
    Last Post: 03-08-2017, 05:09 AM
  2. Etap 11.0
    By maximiliano_capote in forum Electrical & Power Engineering
    Last Post: 02-09-2015, 10:39 AM
  3. ETAP 11 and !2
    By fx007 in forum Electrical & Power Engineering
    Last Post: 04-05-2014, 05:35 PM
  4. Need etap --------
