Thread: what control and noncontrol valve in subsea wells
  1. what control and noncontrol valve in subsea wells
    I have specification for sud sea wells said"all actuated valves ,except control valve,shall be hydraulic actuated"
    and when I saw the topside P&ID I couldn't realize the different because I found shutdown valves instrument air actuated and others are hydraulic actuated.
    How can I to distinguish between control and non control valve?
    Hi Shiha,
    i try to answer your question. However, it's very difficult. There is a missing information.
    Just for your information, All subsea valves will be actuated using hydraulic as driving force. But, recently a few of subsea equipment vendor invent new design that using electric actuated valve.
    If you have API 17A, perhaps you will know what is subsea valve, the method to control it etc.
    I think, what your subsea spec say about control valve is Directional control valve in subse control module. This DCV usually controlled by pulsed electric signal.
  1. ISO 14723/API 6DSS Subsea Pipeline Valve
    By sxe10 in forum Pipeline And Fluid Flow
    Last Post: 07-18-2019, 03:28 PM
  2. Subsea Control and Data Acquisition: For Oil and Gas Production
    By seel_20 in forum Oil And Gas Production
    Last Post: 11-25-2013, 07:53 AM
  3. Selection Guide for Control System, Control Valve and Custody Transfer
    By nutcha in forum Instrumentation & Control
    Last Post: 03-19-2012, 04:12 PM
  4. Fluid Control Institute - Control Valve Seat Leakage (ASME B16.104)
    By Nabilia in forum Pipeline And Fluid Flow
    Last Post: 05-24-2011, 02:46 AM
  5. Water control diagonostic plots for gas wells
    By Malvika015.upes in forum Reservoir
    Last Post: 02-04-2011, 01:35 PM
