Thread: Micro and Macro Mixing: Analysis, Simulation and Numerical Calculation
    (Heat and Mass Transfer)
    Springer | English | 2010-02-01 | ISBN: 3642045480 | 348 pages | PDF | 12,7 MB
    The homogenization of single phase gases or liquids with chemical reactive components by mixing belongs to one of the oldest basic operations applied in chemical engineering. The design of equipment for mixing processes is still derived from measurements of the mixing time which is related to the applied methods of measurement and the special design of the test equipment itself.
    This book was stimulated by improved modern methods for experimental research and visualization, for simulations and numerical calculations of mixing and chemical reactions in micro and macro scale of time and local coordinates. It is aimed to improve the prediction of efficiencies and selectivities of chemical reactions in macroscopic scale. The results should give an understanding of the influence of the construction of different mixing equipment on to the momentum, heat and mass transfer as well as reaction processes running on microscopic scales of time and local coordinates.
  2. thank you so much
  1. Fundamentals of Numerical Reservoir Simulation
    By sami22 in forum Reservoir
    Last Post: 03-31-2014, 03:02 PM
  2. Mixing Calculation
    By jose_alberto2 in forum Safety And Environment
    Last Post: 06-29-2013, 09:51 AM
  3. Transient Numerical Simulation Of Complex...
    Last Post: 09-18-2010, 04:33 PM
  4. Numerical simulation of gas pipeline networks
    By Azad in forum Pipeline And Fluid Flow
    Last Post: 04-19-2010, 02:56 PM
