I need help for the qualification of procedure for the repair of pump casing. The pump casing has thickness of 32mm and has damaged by erosion of 15mm depth groove.We plan to build up. The material is WCB. I want to know which thickness shall I will consider for the PQR specimen.
Thanks a lot
