Thread: Help me in designing Anti-Splash Mechanism for Pressure Vessels!
  1. Exclamation Help me in designing Anti-Splash Mechanism for Pressure Vessels!
    Hi there!
    I've to design an anti-splash mechanism to control the fluid (liquid) level in a prssure vessel.
    Any body help me urgently.
    Thanx in advance.
    I think you will have to anti splash mechanism inside the nozzles or just at the mouth of
    the nozzles feeding fluid in to the pressure vessels.
    If it is the case then search for the relevant patents in google.
    Anti-splash
    Quote Originally Posted by raja687 View Post
    Hi there!
    Thanx in advance.
    The simplest way is to provide inlet converter and de-wave plate.
    Inlet convert can be simply elbow or similar.
    De-wave plate is vertical baffle with numous holes on it. If splash is servere, you provide two of them with 3 in distance in between. Stag away the holes when you use two plates.
  1. Pressure Vessels External Pressure Technology (get book)
    By SHEMYY in forum Mechanical Engineering
    Last Post: 08-28-2015, 08:40 PM
  2. Replies: 1
    Last Post: 10-22-2014, 11:39 PM
  3. Designing of PSA ( Pressure swing Adsorber)
    By anupkumarroy in forum Petrochemical
    Last Post: 12-16-2013, 05:44 PM
  4. Replies: 0
    Last Post: 06-23-2013, 12:35 PM
  5. Pressure Vessel Designing Explained
    By parham71 in forum Engineering Spreadsheets & Presentations
    Last Post: 06-26-2012, 09:15 PM
