Thread: ASME B31.1 Power Piping
  1. Arrow ASME B31.1 Power Piping
    Hi Friends,
    Im looking a formula to calculate minimum wall thickness of pipe to ASME B31.1, and also the formula to calculate Maximum Allowable Working pressure
    Thanks in advance
    Nov 2009
    Kuala Lumpur
    Look in ASME B31.1 in Chapter II, Part 2.
    Notwithstanding the strength, tolerances and corrosion allowance of material being used, MAWP for a piping system is determined by design pressure & test pressure.
    "The client is always right - except when he is wrong"
  4. Can you give download link of B31.1
    ap8229@gmail.com
    Thanks in advance
    Quote Originally Posted by Jazz79 View Post
    Hi Friends,
    Thanks in advance
    - For MAWP see the following thread of Forum CR4:
    [link Point to another website Only the registered members can access] - For pipe wall thickness calculation as per ASME B31.1, see the following example:
  1. Bioprocess Piping ASME BPE and cleanroom piping
    By rect_vijay in forum Pipeline And Fluid Flow
    Last Post: 02-12-2014, 08:44 AM
  2. asme 31.1 power piping
    By rajesh119 in forum Engineering Certificates
    Last Post: 05-13-2013, 02:09 PM
  3. power piping(B31.1)
    By raji@singapura in forum Mechanical Engineering
    Last Post: 04-20-2012, 09:54 PM
  4. ASME 31.1 power piping
    By mlk in forum Pipeline And Fluid Flow
    Last Post: 12-09-2010, 05:46 PM
  5. power piping
    By richukichu in forum Mechanical Engineering
    Last Post: 09-21-2009, 05:55 AM
