Hi
I have a question.
How to use to the ****** program?
When I type the system key and I press enter, there is not happen nothing.
thanks your answer forward
Hi
I have a question.
If you type the key properly, the OK button will be enabled.
Try it again.
Abhilasha
Chemcad 6.1.4 has been released ...
Hi!
Here I'm again. The ****** program (CC61_Calc) is open a Dos window and when I type the system key (100 777 345 238 40), there is not happen nothing.
Please help me.
Thx
Chemcad v6.1.4.3059 also worked using LND's ****** for v6.1.3.
download the new version from chemstation website with this login. (the website still showing v6.1.3, but when you click software update, you will see v6.1.4. The new version version has slight different layout)
login: ccdl
p/w: 3chlorine
File: C:\Downloads\setup.exe
Version: 6.1.3
MD5: F520B8BA585CE73F965C6F3848135355
SHA1: 78BECEEB7CF015E2F221A588373D4220CAF0E284
CRC32: 4EEE8373
File: setup.exe
Version: 6.1.4.3059
md5: 10ddc2c513ed7a912e4417b845945db3
the version 6.2 comming soon (october)
Chemstations CHEMCAD 6.1.4.3059 with cr****k
Arspi, Greece
Thank you very much, I need it
